KUMHO WHERE ARE YOU?!?!
Last post 7 hours, 44 minutes ago by Kyle. 48 replies.
02-24-2008, 7:33 PM |
CSBM5
Joined on 11-29-2005
NC
Posts 34
Points 425
Re: KUMHO WHERE ARE YOU?!?!
Below is another picture I found via searching of the new tread-to-sidewall interface design:
http://www.imagebam.com/image/4bd1b9719131/
Any thoughts on how this new design will fare on camber challenged stock-class cars? (i.e. 330i zhp).
2001 BMW M5 2003 BMW 330i ZHP 6MT 2006 BMW 330i ZSP 6MT 2001 Audi S4 sport 6MT 1996 Volvo 850R wagon
06-30-2008, 7:47 PM |
Mike.S
Joined on 09-13-2003
Boston, MA
Posts 37
Points 590
I just received 4 V710s in 215/50-13 from TireRack a week ago. They have 5005 date code. In other words, they were on a shelf for 2.5 years (!).
Should I be as unhappy as I am? I ran them for 1 event, 7 runs. They felt OK, I was playing with pressures. They wanted less pressure compared to my old set (also 5005 date code but on the car for about 80+ runs).
In any event, the question is - does Kumho have newer 13" V710s and if so, what's different about them?
Mike.S
06-30-2008, 8:33 PM |
Davebs14
Joined on 10-10-2001
Houston, Texas USA
Posts 1,759
Points 20,335
They should be good. TR can only get tires as new as Kumho will send. Hoosiers are nice :) AND given the Kumho price hike I can't see any reason to go back to Kumhos. They can't make new tires on time, they can't keep supply up when needed, they don't produce all the right sizes, should we go on?
06-30-2008, 9:06 PM |
mwood
Joined on 05-11-2005
Alamo, CA
Posts 826
Points 10,365
Davebs14:
Not to sound negative, paranoid or alarmist...but, is it possible, now that Kumho has built such a well known brand and has attained decent market share, that the importance of autocrossers has declined in their "big picture"?
The price hike can easily be explained away, both in terms of oil price and Kumho no longer needing to use V710 sales as a loss leader for marketing...and, Kumho has long had a history of very, very slow boats from South Korea (where "May" typically means June)...but, I still wonder if they aren't as concerned with Solo II as they might have been 3-4 years ago. It wouldn't be the first time that a tire manufacturer had used the grassroots racing community to build brand, before either increasing margin in our space or outright bailing...
06-30-2008, 9:16 PM |
John V
Joined on 01-12-2004
Columbia, MD
Posts 766
Points 9,265
We switched from kumho to Hoosier with this last set of tires. Can say I want to go back to the Kumhos. The price was about the same, the tires "feel" a lot better and they seem to be wearing a lot better than the original A6s.
John Vitamvas Overweight, one-wheel drive tire-eater
06-30-2008, 10:40 PM |
AStockVette
Joined on 10-08-2003
Allen, Texas
Posts 111
Points 1,380
boxboy:
.... I'd expect the Kumho W710 Rains as late as summer. I'm not sure arrival times on the new V710 are clear yet.
-Andy M.
Andy, doesn't that make the arrival of either tire moot for Nationals this year since neither would meet the requirements of 13.3 re. the 4/30 cutoff and thus wouldn't be eligible for use (at least in Stock classes) until next year? Or am I misinterpreting the rule?
07-01-2008, 1:21 AM |
boxboy
Joined on 06-27-2001
Posts 268
Points 4,540
Yes, I believe you are right on the rains, no go for Nats this year. Latest I had heard is that they would be available for Runoffs, but that won't work for us. I'm just hoping it pours if it rains and SPT's will work well.;-) As far as new 710, it's not a new model so it would probably just need to be generally available and you could run it. Your next question is for the latest news on that and I don't know when those will show up either. -Andy M.
07-01-2008, 1:26 AM |
boxboy
Posts 268
Points 4,540
Mike.S:I just received 4 V710s in 215/50-13 from TireRack a week ago. They have 5005 date code. In other words, they were on a shelf for 2.5 years (!).
Mike, I've run 05 tires as well and they've been fine. I think it it less important how long the shelf life unused is vs. used. I had one set that had a couple heat cycles on it that sat for a long time (~5 months) and they didn't seem to work again. Even if they are 05 date codes I would think they will be normal as long as you run them fairly regularly and store them well in between usage. -Andy M.
07-01-2008, 2:03 AM |
TeamRX8
Joined on 04-18-2003
Posts 1,585
Points 21,615
nm, old thread
07-01-2008, 10:10 AM |
Mike.S
Boston, MA
Posts 37
Points 590
boxboy: Mike, I've run 05 tires as well and they've been fine. I think it it less important how long the shelf life unused is vs. used. I had one set that had a couple heat cycles on it that sat for a long time (~5 months) and they didn't seem to work again. Even if they are 05 date codes I would think they will be normal as long as you run them fairly regularly and store them well in between usage.
-Andy M.
Thanks, Andy!
I have about a dozen events left between now and mid-October when we go into hibernation on the East Coast. I store the tires between the events in a basement where it's about room temperature and fairly dry. Someone suggested putting them into bags as well.Should I?
I know that TireRack stores tires well. I'm only running local events. Maybe I'm overthinking all this. But damn, paying full higher price and getting tires that are 2.5 years old just doesn't sit well with me.
Mike.S
07-01-2008, 11:55 AM |
boxboy
Posts 268
Points 4,540
I'd think that as long as you run / store them as you say they should work normal. I don't bother bagging mine, but I have this CA climate thing going for me. Prices going up is never a desirable thing, but I think the Kumhos still represent a better competitive life for the dollar than any other DOT tire. -Andy M.
07-09-2008, 2:18 PM |
MrPickles
Joined on 07-24-2006
Denver, CO
Posts 71
Points 640
boxboy:
They worked well for me during the Rain of heat #1 at Nationals 07. I did a side by side comparison between 710s and SPTs, and I was quite impressed with the grip the SPTs offered.
Michael "MrPickles" Feldpusch #144 SM2 Broomfield, CO rmsolo.org lefthandracing.com
07-09-2008, 2:52 PM |
devomgd
Joined on 06-24-2004
Atlanta, GA
Posts 87
Points 1,110
The same way on the inner sidewall. It has a 4 digit code. The first two digits are the week, the last to digits are the year.
Mark Davis 1993 Toyota MR-2 White "Casper"
07-09-2008, 7:13 PM |
David Lehman
Joined on 01-27-2004
Plantation, FL
Posts 959
Points 12,910
Come now Jer. You don't know this ?
Works for Hoosier, Kumho.....trailer tires.....truck tires.......
(you might be out of luck with a bicycle tire...not sure)
PS-----The word autocross starts with the letter "a"
Trying to get faster
07-09-2008, 7:19 PM |
David Lehman
Plantation, FL
Posts 959
Points 12,910
i believe the correct answer to the main question would be the southern half of the Korean peninsula. The other Korea, where Kim Jong "Mentally" ill doesn't live.
07-11-2008, 10:45 AM |
Surferjer
Joined on 09-17-2004
East Coast
Posts 699
Points 6,840
David Lehman:
And I still can't find the friggin numbers. No, I didn't know this. But I learn daily. Someday I might learn how to drive. Maybe not.
Jer #196 ES #187 SS retired
07-22-2008, 1:50 PM |
boxboy
Posts 268
Points 4,540
boxboy:I'd think that as long as you run / store them as you say they should work normal. I don't bother bagging mine, but I have this CA climate thing going for me. Prices going up is never a desirable thing, but I think the Kumhos still represent a better competitive life for the dollar than any other DOT tire. -Andy M.
Just an update to that I practice what I preach. I've run a couple events now with 08 date code fronts and one 04 and one 05 rear. Car seems balanced as normal and tires have worked fine through 30+ runs. -Andy M.
07-25-2008, 9:30 PM |
mxqisit
Joined on 04-23-2004
Toronto, Canada
Posts 55
Points 460
FWIW: I just got a fresh set of 13s from Kumho Canada, 2807 build date for all 4 of them.
Page 2 of 3 (49 items)
2
