KUMHO WHERE ARE YOU?!?!
Last post 3 hours, 46 minutes ago by Kyle. 48 replies.
Page 2 of 3 (49 items)   < Previous 1 2 3 Next >
  •  02-24-2008, 7:33 PM 286583 in reply to 286449
    Re: KUMHO WHERE ARE YOU?!?!
    Below is another picture I found via searching of the new tread-to-sidewall interface design:
     http://www.imagebam.com/image/4bd1b9719131/
    Any thoughts on how this new design will fare on camber challenged stock-class cars? (i.e. 330i zhp).
    2001 BMW M5
    2003 BMW 330i ZHP 6MT
    2006 BMW 330i ZSP 6MT
    2001 Audi S4 sport 6MT
    1996 Volvo 850R wagon
  •  02-24-2008, 7:59 PM 286587 in reply to 286583
    Yep!  That's how my 225/45/17's looked when they were new.   But now after 3 events the outside shoulder has begun to round off and look like a normal V710.  I think that with this new design the camber challenged cars will have reduced shoulder wear for even longer tire life before cording.  But what I'm interested in is whether the tire behaves differently with a square shoulder compared to a rounded shoulder.  We're running winter events here so there hasn't been much grip available for consistent testing.
    2007 Mazda MX-5 MRS (C-stock)
  •  06-30-2008, 7:47 PM 307992 in reply to 286583
    I just received 4 V710s in 215/50-13 from TireRack a week ago. They have 5005 date code. In other words, they were on a shelf for 2.5 years (!).
    Should I be as unhappy as I am? I ran them for 1 event, 7 runs. They felt OK, I was playing with pressures. They wanted less pressure compared to my old set (also 5005 date code but on the car for about 80+ runs).
    In any event, the question is - does Kumho have newer 13" V710s and if so, what's different about them?
    Mike.S
  •  06-30-2008, 8:33 PM 308004 in reply to 307992
    They should be good. TR can only get tires as new as Kumho will send.
    Hoosiers are nice :)  AND given the Kumho price hike I can't see any reason to go back to Kumhos.
    They can't make new tires on time, they can't keep supply up when needed, they don't produce all the right sizes, should we go on?
    David Hedderick
    Pearland (Houston), TX
    08 Mazda 3s
  •  06-30-2008, 9:06 PM 308007 in reply to 308004
    Davebs14:
    Not to sound negative, paranoid or alarmist...but, is it possible, now that Kumho has built such a well known brand and has attained decent market share, that the importance of autocrossers has declined in their "big picture"?
    The price hike can easily be explained away, both in terms of oil price and Kumho no longer needing to use V710 sales as a loss leader for marketing...and, Kumho has long had a history of very, very slow boats from South Korea (where "May" typically means June)...but, I still wonder if they aren't as concerned with Solo II as they might have been 3-4 years ago. It wouldn't be the first time that a tire manufacturer had used the grassroots racing community to build brand, before either increasing margin in our space or outright bailing...
    In slow, out fast.
    In fast, out backwards.
  •  06-30-2008, 9:16 PM 308009 in reply to 308007
    We switched from kumho to Hoosier with this last set of tires.  Can say I want to go back to the Kumhos.  The price was about the same, the tires "feel" a lot better and they seem to be wearing a lot better than the original A6s.
    John Vitamvas
    Overweight, one-wheel drive tire-eater
  •  06-30-2008, 10:40 PM 308027 in reply to 284798
    boxboy:
    .... I'd expect the Kumho W710 Rains as late as summer.   I'm not sure arrival times on the new V710 are clear yet.
     -Andy M.
    Andy, doesn't that make the arrival of either tire moot for Nationals this year since neither would meet the requirements of 13.3 re. the 4/30 cutoff and thus wouldn't be eligible for use (at least in Stock classes) until next year?  Or am I misinterpreting the rule?
  •  07-01-2008, 1:21 AM 308055 in reply to 308027
    Yes, I believe you are right on the rains, no go for Nats this year.  Latest I had heard is that they would be available for Runoffs, but that won't work for us.   I'm just hoping it pours if it rains and SPT's will work well.;-)
    As far as new 710, it's not a new model so it would probably just need to be generally available and you could run it.  Your next question is for the latest news on that and I don't know when those will show up either.
     -Andy M.
  •  07-01-2008, 1:26 AM 308056 in reply to 307992
    Mike.S:
     Mike, I've run 05 tires as well and they've been fine.  I think it it less important how long the shelf life unused is vs. used.  I had one set that had a couple heat cycles on it that sat for a long time (~5 months) and they didn't seem to work again.  Even if they are 05 date codes I would think they will be normal as long as you run them fairly regularly and store them well in between usage.
    -Andy M.
  •  07-01-2008, 2:03 AM 308057 in reply to 284703
    nm, old thread
  •  07-01-2008, 10:10 AM 308080 in reply to 308056
    boxboy:
    -Andy M.
    Thanks, Andy!
    I have about a dozen events left between now and mid-October when we go into hibernation on the East Coast. I store the tires between the events in a basement where it's about room temperature and fairly dry. Someone suggested putting them into bags as well.Should I?
    I know that TireRack stores tires well. I'm only running local events. Maybe I'm overthinking all this. But damn, paying full higher price and getting tires that are 2.5 years old just doesn't sit well with me.
    Mike.S
  •  07-01-2008, 11:55 AM 308098 in reply to 308080
    I'd think that as long as you run / store them as you say they should work normal.  I don't bother bagging mine, but I have this CA climate thing going for me.
    Prices going up is never a desirable thing, but I think the Kumhos still represent a better competitive life for the dollar than any other DOT tire.
    -Andy M.
  •  07-09-2008, 2:18 PM 309348 in reply to 308055
    boxboy:
    They worked well for me during the Rain of heat #1 at Nationals 07. I did a side by side comparison between 710s and SPTs, and I was quite impressed with the grip the SPTs offered.
    Michael "MrPickles" Feldpusch
    #144 SM2
    Broomfield, CO
    rmsolo.org
    lefthandracing.com
  •  07-09-2008, 2:47 PM 309352 in reply to 309348
    Is there a way to tell when A6s were manufactured?
    Jer
    #196 ES
    #187 SS retired
  •  07-09-2008, 2:52 PM 309355 in reply to 309352
    The same way on the inner sidewall.  It has a 4 digit code.  The first two digits are the week, the last to digits are the year.
    Mark Davis
    1993 Toyota MR-2 White "Casper"
  •  07-09-2008, 7:13 PM 309403 in reply to 309352
    Come now Jer.  You don't know this ?
    Works for Hoosier, Kumho.....trailer tires.....truck tires.......
    (you might be out of luck with a bicycle tire...not sure)
    PS-----The word autocross starts with the letter "a"
    Trying to get faster
  •  07-09-2008, 7:19 PM 309404 in reply to 308098
    i believe the correct answer to the main question would be the southern half of the Korean peninsula.  The other Korea, where Kim Jong "Mentally" ill doesn't live.
  •  07-11-2008, 10:45 AM 309705 in reply to 309403
    David Lehman:
    And I still can't find the friggin numbers.  No, I didn't know this.  But I learn daily.  Someday I might learn how to drive.  Maybe not.
    Jer
    #196 ES
    #187 SS retired
  •  07-22-2008, 1:50 PM 311397 in reply to 308098
    boxboy:
    -Andy M.
    Just an update to that I practice what I preach. Wink   I've run a couple events now with 08 date code fronts and one 04 and one 05 rear.   Car seems balanced as normal and tires have worked fine through 30+ runs.
     -Andy M.
  •  07-25-2008, 9:30 PM 312235 in reply to 307992
    Mike.S:
    FWIW: I just got a fresh set of 13s from Kumho Canada, 2807 build date for all 4 of them.
