tire fitment question
Last post 05-29-2008, 4:40 PM by rankink. 4 replies.
  •  05-08-2008, 7:39 PM 299260
    I have a friend with an 07 STI that's essentially a STU car with a BSP computer program on it.
    It's lowered about 1 inch with Tanabe springs, and running either on the stock 17x8s or 17x8.5 Rotas.
    Question is....will the 275/40-17 that the AS guys run still clear on a lowered car like this? Or would we need coilovers on it with stiffer spring rates to control the travel? I remember seeing Stumpy or Stompy ;)  with BIG tires on it and stock fenders at one point.
    Just trying to figure out what is possible :)
    David Hedderick
    Pearland (Houston), TX
    08 Mazda 3s
  •  05-29-2008, 10:23 AM 302841 in reply to 299260
    Re: tire fitment question
    Davebs14:
    on the Tanabe springs you're going to be hard pressed to run a 275/40/17.
    you "should" be able to run the 245/45/17 V710s on a 17x8.5 +48mm without issue on your current suspension (since it works well on an 05 with STi Pinks on the 8.5 +48mm).
    to run the "big wheels/tires" you really need coilovers.
    here's a little Daily Driven BSP article.
    17×10s and 275s, the BSP Minimum! T3h_clap’s BSP STi
    -Drew
    Filed under: , , ,
  •  05-29-2008, 10:50 AM 302847 in reply to 299260
    Davebs14:
    Stompy had rolled fenders..... I believe Joel was running 315 wide tires as well.
    Meredith
    AS S2000
  •  05-29-2008, 2:01 PM 302878 in reply to 302847
    pinkwheels:
    Davebs14:
    only rolled?
    I thought he radius'd the rear fenders for added clearance.
  •  05-29-2008, 4:40 PM 302905 in reply to 302878
    wrx8xb:
    pinkwheels:
    Davebs14:
    only rolled?
    I am pretty sure he cut up the front fenders too.  I remember seeing it in a article on him and car.
    2005 Subaru WRX STi - AS #
