axle play in 2000 integra
Last post 06-08-2008, 1:43 PM by atcovan. 1 replies.
  •  05-24-2008, 1:12 AM 302054
    after replacing the passenger side axle seal for the tranny once before, and then seeing it continue to leak i think it has to do with the passenger side axle having play in it (up and down/front to rear). what is the likely cause of this, and do i need to tear apart the tranny to fix it?
  •  06-08-2008, 1:43 PM 304427 in reply to 302054
    Re: axle play in 2000 integra
    My guess is there is too much play and the seal can't cope. Make sure you lube it good to prevent chafing damage upon insertion. Hmm, sounds like another process Embarrassed
    James Plotkin
    '05 FSP Echo
