G Stock MCS Setup Question - regarding lifting the inside rear tire on corner entry
Last post 07-14-2008, 12:03 PM by solo-x. 14 replies.
  •  06-25-2008, 11:38 AM 307103
    Wise Folks,
    There's a bit of debate on another forum regarding whether lifting the inside rear tire on corner entry is:
    a. avoidable
    b. indication of a setup opportunity - not desirable!
    c. normal, not an issue
    d. overdriving
    My STX MCS does not do this but I'm running coil overs so I'm not surprised.
    Should this behavior be tuned out with shock settings?  Does it matter?
    Thanks very much for your opinions on the matter.
    Sincerely,
    Charlie
    Charlie Thompson
    '04 JCW Cooper [STX]
    NER Cannon Fodder
  •  06-25-2008, 12:03 PM 307109 in reply to 307103
    Re: G Stock MCS Setup Question - regarding lifting the inside rear tire on corner entry
    Perfectly normal
    The Brown Sean
    1988 Honda CRX Si (STS2 #48)
    Not DFL at DC!
  •  06-25-2008, 12:30 PM 307120 in reply to 307109
    thanks!  not wishing to sound skeptical, but if you had DA shocks would there be any point in adding compression up front and a bit of rebound out back to try and dampen the pitch/roll on corner entry?  it just seems intuitive to me that four wheels are better then three...
    in addition, would you think it odd if the car three-wheeled through the middle of the corner - after the brakes are released?
    cheers,
    charlie
    Charlie Thompson
    NER Cannon Fodder
  •  06-25-2008, 12:41 PM 307129 in reply to 307120
    On my yellow CRX with the Koni DAs at full stiff on the rear the car would three wheel through the entire corner.
    The Brown Sean
    Not DFL at DC!
  •  06-25-2008, 3:56 PM 307210 in reply to 307129
    thanks again - there's a picture worth at least a thousand words...
    Charlie Thompson
    NER Cannon Fodder
  •  06-25-2008, 4:04 PM 307212 in reply to 307120
    cmt52663:
    more front roll stiffness is required if the inside rear is coming up i.e. a larger front sway bar and/or the shock changes you mentioned (front bump first, then rear rebound).  what's more, sometimes the inside rear lifts because there isn't enough droop travel.
    Doug #81 STS2
    1990 Mazda Miata
    STU 2000 Audi S4 (retired)
    STU 2005 Mazda RX-8 (retired)
  •  06-25-2008, 4:21 PM 307218 in reply to 307212
    shinronin:
    cmt52663:
    thanks.  i can see the tradeoffs get tricky right away - for the MCS stiffening the front roll bar would seem likely to increase the native understeer.  if the stock bar permits enough chassis roll to exhaust rear droop in a steady state situation (those are rare though aren't they?) then there you are.
    that lovely picture of the CRX seems to me to illustrate that situation very well - the chassis has quite a bit of roll, although it looks settled and quick.
    i wonder though if the MCS has the same steady state characteristics, and wonder if any of our darned fast MCS folks are willing to comment?
    Charlie Thompson
    NER Cannon Fodder
  •  06-25-2008, 4:31 PM 307220 in reply to 307218
    cmt52663:
    shinronin:
    cmt52663:
    yes, in the case of FWD a larger FSB won't help (iirc most if not all STS2 CRXs run with no FSB), but the pic is deceiving because setting the rear to full stiff with DAs isn't tuning out the inside rear lifting.  in that pic imagine if the front wasn't rolling so much such that the car is not pivoting from front left to rear right.  most ST* FWD suspension setups rely on a much higher rear spring rate compared to the front to induce more neutral handling.
    but, in the case of GS suspension limitations, some inside rear lift is probably inevitable but you can limit it with shock tuning.
    Doug #81 STS2
    1990 Mazda Miata
  •  06-25-2008, 5:18 PM 307236 in reply to 307220
    The yellow CRX was in GS trim, not sure if that changes the perspective.
    The Brown Sean
    Not DFL at DC!
  •  06-26-2008, 11:12 AM 307390 in reply to 307236
    yep, gotcha.  my last post was done in a hurry and wasn't crystal clear but i was trying to describe both the MCS in STX and GS trim to address charlie's original post.  i was trying to describe what charlie correctly identified as the tricky tradeoffs in grip vs. roll stiffness on a FWD car in stock trim.  in GS, tire pressures, alignment, shock tuning are key.  i was just pointing out that addressing three-wheel motion by tuning the rear won't help.
    there's an article in the latest GRM addressing FWD setup on a MCS.  check it out.  Smile
    Doug #81 STS2
    1990 Mazda Miata
  •  07-14-2008, 12:44 AM 309997 in reply to 307390
    Just saw your post for the 1st time.  The wheel up attitude of the Mini is completely normal and common among all the top cars.  (see pic to your left) The R56 gets a bunch more air under there due to it's soft spring package.  Since I'm trying to dial more rotation into the car most of the time... maybe 3 is actually better than 4 after all.Big Smile
    Tony Savini
    2005 Mini Cooper S
  •  07-14-2008, 7:36 AM 310013 in reply to 309997
    racnmni:
    and that settles that!  Thanks very much Tony.
    Cheers,
    Charlie
    Charlie Thompson
    NER Cannon Fodder
  •  07-14-2008, 8:37 AM 310019 in reply to 310013
    I'm trying to think of any point in vehicle dynamics where dynamically raising the CG is a good thing. Aside from drag racing, I can't think of any. If you want to talk more about it Charlie, find me at the next Devens event.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  07-14-2008, 10:04 AM 310036 in reply to 310019
    • Stan is not online. Last active: 10/13/2008, 9:50 AM Stan
    • Top 150 Contributor
    • Joined on 10-28-2002
    • Ridgefield, CT USA
    • Posts 492
    • Points 6,925
    As far as I know the only two examples where low CGs are not beneficial for handling machines = karts and dirt track racecars.  On dirt a highish CG will help the tires dig into the dirt surface which increases total grip so the cornering speeds rise.  For karts...since there is no differential and a huge F/R tire bias favoring the rear they want to understeer.  So with a highish CG inside rear tire lift allows the thing to turn much more effectively.  I think that is because basic kart design = Engineering nightmares where you have to fix one problem by creating others.
  •  07-14-2008, 12:03 PM 310059 in reply to 310036
    Stan:
    Ah, didn't think of dirt, and karts I class under "anomalous". Wink
    Nate Whipple
    NER
    188/88 DSP ITR
