Taking it to STS
Last post 07-16-2008, 10:34 AM by E30bulldog. 11 replies.
  •  07-15-2008, 11:31 AM 310233
    Taking it to STS
    Are coilovers legal in STS.  The rules state that the spring must be the same style as the original on your car(coil,leaf,torsion bar, etc.).
  •  07-15-2008, 12:40 PM 310255 in reply to 310233
    Re: Taking it to STS
    E30bulldog:
    Well if your car originally came with coilovers (i.e. struts), then absolutely.   Section 14.8A, where the rule you quoted is, later says "Coil spring perches originally attached to struts or shock absorber bodies may be changed or altered, and their position may be adjustable.  Spacers are allowed above or below the spring."  That would take care of adjustable coilovers.  And then Section 14.5A says any shock absorbers are allowed, with a few restrictions.  So, yes.
    But of course being in STS in the MS region puts you in the open tire class, so you might want to consider that before you make a change.
  •  07-15-2008, 12:53 PM 310257 in reply to 310255
    I don't plan on running STS in MS region, but when I go to tri-state I will run STS, or any other non MS race.
  •  07-15-2008, 1:17 PM 310267 in reply to 310257
    Dose your car classify as a STS class car?  When you did the chip did it mount in the stock location?  Look over all of the rules and see if your still able to run STS.
  •  07-15-2008, 1:26 PM 310270 in reply to 310257
    E30bulldog:
    Ah, well then you should be good as long as no 1989 Civics show up. Smile  I ran STS in Tri-State last year, and no one else even ran the required number of events, so I won it by default.
  •  07-15-2008, 3:45 PM 310319 in reply to 310270
    yep, the chip is on another ECU I bought.  So it is the stock location.  I haven't check if my car is on the STS list.  But I have looked at the rulebook and I fit every part of STS except the catalytic converter par (I will buy one soon, just for the occasion and take it off after).
  •  07-15-2008, 3:49 PM 310322 in reply to 310319
    Yeah Im pretty sure you would be legal with that new cat.  It will be good to beat you and taylor in the same class, haha.
  •  07-15-2008, 4:00 PM 310326 in reply to 310322
    Well Ben, I will remember that for when I put you car together.  I go back around Taylor and loosen all of your bolts.  You won't get far...hahaha
  •  07-15-2008, 4:26 PM 310334 in reply to 310326
    ha its a good thing you are not the only one there, just the one with the most tools.
  •  07-15-2008, 9:33 PM 310409 in reply to 310334
    Hay now I'll be running all the events with my car so we should have some good close racing.  I should have a faster car by then, getting the Ground Control Coil-overs for my car in the next few weeks.
  •  07-16-2008, 1:36 AM 310444 in reply to 310409
    Awesome! Is it a kit GC makes or are you just buying the coilovers.  Tell me how the install goes.  Do you have tires yet?  The Dunlops didn't even show wear after the Memphis event.
  •  07-16-2008, 10:34 AM 310481 in reply to 310444
    Oops, saw a rule about my limited slip, guess I will have to run STX.
