Head Gasket Change...what all I can do and still be in DSP
Last post 07-21-2008, 8:55 PM by junior schumi. 6 replies.
  •  07-19-2008, 4:55 PM 311009
    I have Integra GSR ...mildly modded..basic suspension stuff, Intake, header, exhaust etc.  As the title says, planning for a head gasket change. While doing it, what all I can do ( primararily to engine) and still be in DSP? I know that Cams are not allowed in DSP...
    Thanks a lot
  •  07-20-2008, 11:40 AM 311050 in reply to 311009
    • Storm is not online. Last active: 12/02/2008, 5:25 PM Storm
    • Top 200 Contributor
      Male
    • Joined on 12-16-2001
    • Willoughby, Ohio, USA
    • Posts 324
    • Points 4,270
    Re: Head Gasket Change...what all I can do and still be in DSP
    You can start with the rule book. I wouldn't go beyond what's in the rulebook though.....
    Gasket match the in/ex ports, blend no deeper than 1" from the face. The head can be skimmed up to the manufacturers limit, or .010" (doublecheck for accuracy) if no limit is shown in the FSM. That's pretty much it..... The headgasket must be same thickness as stock, so don't go crazy there.
    Jay Storm
    96 Impreza L FSP
    98 98 Impreza 2.5RS- co-driver DSP
    Wives are like SCCA rules...
    If she doesn't say you can...you can't
  •  07-20-2008, 4:48 PM 311065 in reply to 311050
    Thanks...I didn't put the question very clearly....
    I will be spending time for doing the head gasket......while doing it,  what else can be done?  what are the "most popular/bang buck"  engine mods for an Integra running in DSP? I have access to a buddie's shop who does work on Hondas.....
  •  07-20-2008, 10:07 PM 311095 in reply to 311065
    I think your question was clear, as was the answer.  Basically, when you read the rule book, if it does not say you can do something, you are not allowed to.  I think he pretty much covered what it allows you to do.  Not much.  Smile
    Patrick Washburn
    STU Evo - SOLD!
    <----- 2009 - Regain the coveted Tri Pod Trophy for the Hiedi's
  •  07-21-2008, 12:46 AM 311104 in reply to 311095
    Thanks for pointing to rule book....While I understnd some of what is said in the rule book, What I am trying to find out is that,  what all can be done wthin the rules, how effective they are?
    Ex. It says vehicles with variable timing may use alternate computer calibeartion to adjust cam/ valve timing...Is this something that is done for an Inetgra Vtec in DSP?
     Thanks again
  •  07-21-2008, 7:59 AM 311113 in reply to 311104
    Lets not confuse things here. Your original question is what can be done to the motor. Most of the items have been covered. I know the FSM doesn't have a limit to what you can deck the head to, so .010 is the allowed amount. (FSM says to replace the head if its warped out of spec) OEM thickness head gasket only. Gasket match 1" into the head (not necessary on the exhaust side, probably not necessary on the intake if you use the OEM intake). I'm waiting for clarification on the cam gears on VTEC engines, but for now I'd say they aren't legal. That is it for the head. The block, you can blue print  and balance (but not lighten) and neither of those are really necessary on a Honda IMO. Other then that, .047 overbore max, compression ratio and quench area of the piston cannot be changed from stock. ECU and intake manifold/tb/injectors are open. Underdrive pulleys, flywheel/clutch, header, catalytic and very little else.
    Answering your ECU tuning question, yes, ECU tuning is worthwhile and beneficial on these cars. Especially if you can afford to run GT260 and crank the ignition timing way up.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  07-21-2008, 8:55 PM 311259 in reply to 311113
    Thanks folks...For now, I will stay with OEM head gasketSmile
