New sways!
Last post 08-06-2008, 12:53 AM by E30bulldog. 8 replies.
  •  08-05-2008, 4:12 PM 314049
    New sways!
    Here are some pics of my new sways.
    Old Rear
      New Rear
     old front
    New front
    this is an Ireland Engineering 22/25mm sway bar kit, makes a huge difference
  •  08-05-2008, 9:57 PM 314099 in reply to 314049
    Re: New sways!
    man this forum is dead...
  •  08-05-2008, 10:03 PM 314100 in reply to 314049
    Re: New sways!
    DANG!!!!
    You could have at least pressure washed the chassis so that we weren't looking at the south end of the north bound -------!!!!
    A little black paint to clean it all up ---- the new bars ------- then we'd thought you'd done something.
  •  08-05-2008, 10:23 PM 314105 in reply to 314100
    Re: New sways!
    sorry skip, i had a bit of an oil leak.  All of this was before I pulled my transmission, I took the time to pull the trans to replace the rear main seal and it ended up being the very rear of the oil pan, oh well I put in all that good stuff like a clutch, throw out bearing, rear main seal (of coarse), resurfaced flywheel, and pressure plate.
    Gene
  •  08-05-2008, 10:29 PM 314108 in reply to 314105
    Re: New sways!
    I was waiting on a new Gene post.
  •  08-05-2008, 10:56 PM 314114 in reply to 314105
    Re: New sways!
    OK> points for you tried.
    And, that wouldn't possibly be the 16lb flywheel/10lb clutch cover/3lb disc --- wouldn't it be?????
  •  08-05-2008, 11:02 PM 314115 in reply to 314114
    Re: New sways!
    georgebpainter:
    huh??
  •  08-05-2008, 11:21 PM 314120 in reply to 314115
    Re: New sways!
    Don't worry.
    We'll all know when your try to launch the car and it won't move at less than 6000RPM.
  •  08-06-2008, 12:53 AM 314133 in reply to 314120
    Re: New sways!
    Come on skip, you know i launch the car when its at 7,000 i have absolutely no low end power.  LOL
