Question for F/Stockers
Last post 07-04-2008, 12:16 PM by Bucketlist. 112 replies.
02-17-2007, 8:22 PM |
McCall
Joined on 12-15-2005
Plano, TX
Posts 152
Points 965
Re: Question for F/Stockers
Dick Rasmussen: One major question would be whether a STU Pony Car could utilize all that power and torque with 2 wheel drive on ST (i.e. non R) tires compared to the all wheel drive cars. Plus I think the Pony Cars are also heavier, longer, and wider all of which would seem to work against them. Maybe STU should allow R tires for the 2 wheel drive cars . . .
Dick
All true but they are the only cars that can fit the maximum tire size (besides the RX8) and definitely have the most hp/tq by far. I'm sure an Auburn Pro or equiviant would help put that power to the ground. WRT the current crop of STU tires, compare their grip to that of a Toyo RA1. We did some DL-1 testing on a M3 with the RA1 vs Advan and the Advan actually pulled some better numbers. So do you have any experience on how a FS/ESP car does with Toyos? If so, that's a pretty good example on how the car would do in STU.
Jason McCall #47 STU '00 M Roadster - XP (under construction)
02-19-2007, 5:17 PM |
Fastmike
Joined on 12-16-2001
Seattle Wa USA
Posts 1,654
Points 22,670
Spent some time at the Ford dealer today. I was drooling over the new $$$F-450$$$. There was a guy getting VERY close to buying a Shelby GT that was in the showroom. I wouldn't drive it with the stock hood pins. They don't even lock! It looks like they would open up and bang all over the front of the car while you are driving it. Kind of a joke really.
There was some other workmanship issues with the car too.
If you want one, go get one but look it over VERY well. The price is too high even without the $markup$ for the amount of parts that you are getting imo. FM
02-20-2007, 4:33 PM |
Mojave
Joined on 10-19-2005
Posts 54
Points 255
McCall: Dick Rasmussen: Alternately since FS cars don't really have a ST class that works, folks that care enough could propose an FS pony car specific ST class with or without R tires (I'm not sure an FS pony car would be worth the trouble without R tires).
Sounds like a fun class to me but I'm not interested enough to pursue it. I'll let the folks who are (IF there are any) pursue it.
You know a couple of us STUers were talking about this and wondering why know one has tried a pony car in STU yet. Seems like the rules allow you to fix all the inhert problems with the cars and that should allow one to be competitive. It would probably be cheaper than building an ESP car as well and it would still be very easy to drive it daily on the street. In STU you could do all the ESP suspension mods, upgrade the brakes, upgrade the diff, intake & exhaust mods, ECU tuning, real 25lb seats, lighweight hood, and any diameter and width wheel as long as you run a max of 275mm tires.
Let's look at the results of STU vs. ESP this last year at Nationals to see if this idea of a pony car in STU might hold true. For STU the top 10 spots ranged from total time from 105.7-107.7. ESP's top 10 ranged from 101.2-104.4. Basically ESP was 2+ seconds a course faster than STU. Now take away R compounds and some tire width(275mm max) and I still bet a pony car could compete for one of the top spots. Heck, the winning FS car would have won placed 2nd in STU this year.
Any thoughts?
I don't see how a pony car could ever keep up in STU. What good is 350+/- (LS1 + intake + headers) wheel hp if you only have 275 street tires? Heavier than the StEvos, with less tire to put the power down, and more power to put to the pavement.
What brake upgrades do you speak of? Since when are stock LS1 brakes not enough for auto-x?
Pony cars seem to lose way more time going from R's to streets than lighter, less powerful cars. And I would certainly think AWD really helps when grip gets limited.
-Chad Texas A&M Sports Car Club LT4 Track Project http://www.mowhineracng.com
02-20-2007, 5:44 PM |
McCall
Plano, TX
Posts 152
Points 965
Mojave: I don't see how a pony car could ever keep up in STU. What good is 350+/- (LS1 + intake + headers) wheel hp if you only have 275 street tires? Heavier than the StEvos, with less tire to put the power down, and more power to put to the pavement.
You make some really good points. I just wish someone would actually try it before we dismiss the idea because Ponys car would seem to lose too much time on STU-legal tires (which are not street tires per se). That seems very arbitrary. There's another factor to consider; the fun factor. A pony car with STU legal mods would definitely be a fun car to daily drive(350+ hp and better suspension) and could easliy be driven back and forth from events. ST classes are the fastest growing because of this and it seems like Pony cars fit the bill to a "t". If I hadn't been so far gone to SM with my LT1 formula (and it wasn't even competitive), I would have considered running STU.
As far as LS1 brake upgrades, think two-piece rotors. The cars that would be helped the most by upgraded calipers are the Mustangs. I'm not up to date on what comes on the current crop but I know during the '90s they weren't that hot.
02-20-2007, 8:12 PM |
Cito
Joined on 02-03-2003
Mason City, IA USA
Posts 428
Points 5,470
If I had an STU Evo, I would encourage others to buy ponycars for STU as well. You might get some players if they split the cars into two classes with one for awd and one for 2wd. But, the st classing has to reach a limit at some point. For STU, I would certainly go with a stievo.
02-20-2007, 11:08 PM |
Mojave
Posts 54
Points 255
McCall: Mojave: I don't see how a pony car could ever keep up in STU. What good is 350+/- (LS1 + intake + headers) wheel hp if you only have 275 street tires? Heavier than the StEvos, with less tire to put the power down, and more power to put to the pavement.
What about cost? I like race tires. How much do the hot ST tires cost in 275 sizes? I'm not up on ST tire trends, but I seem to remember the Yokohama Advan being mentioned.
275/35R18 Advan Sport: $281 each from Tire Rack 315/35R17 V710: $240 each from Tire Rack
Ouch. I for one never liked spending more on tires to go slower. Sure, the Advans will last longer, but for Nats, everyone will be on brand new shaved ones. I personally would rather go to ESP, where I know I can win with enough car prep and driving, than spend almost as much money to go slower and quite possibly not be competitive. I have no way to quantify the amount of time lost, but I certainly believe it is a lot. The car certainly feels very, very different, and my focus when driving often shifts to managing oversteer.
02-21-2007, 10:47 AM |
Stan Whitney
Joined on 10-04-2004
DFW
Posts 308
Points 2,700
SoftBatch:
This is what's stated in the FASTRACK
Stock: per the SAC, the following new listings are added, effective immediately upon publication:
Ford Shelby GT350, T82 and 54U factory option package only FS
NOTE: “Shelby” add-ons beyond T82/54U are considered “dealer installed” and are not stock legal.
Is this what you mean by the 54U package:
54U Package- Ford content at Mustang Plant GT/CS based (Fascias/Side scoops) 18" Wheels- White gets Polished aluminum, Black gets new Black aluminum Side air bags Tire Inflator kit (ilo spare) Bright aluminum pedals
and all of this is the "Shelby Addons":
Shelby Modifications FR Power Upgrade package Cold air intake Mufflers Premium fuel calibration FR Handling Package Front and rear sway bars Tuned dampers, springs, bushings Cross tower brace FR short throw shifter Upgraded rear axle (3.55 AT)
Appearance items Hood pins and hood scoop Shelby grill insert and pony badge Shelby racing and body side stripes Shelby GT Sill palte and floor mats with Shelby logo Shelby dash plaque, underhood engine plaque Powered by Ford fender badges.
Or do you mean things not on this list are Shelby addons (3.73 rear ends, superchargers, etc.)?
Back to FS for a second,
It reads to me that only the 54U Package- Ford content at Mustang Plant parts are FS legal. So basically, you can run a stock GT, plus the cosmetic Shelby parts only. That seems a lot more benign than requiring the full boat with all the Shelby suspension add ons to be the class dominating car.
So I guess until the new Bullit and Boss 302 arrive for '08, the GT is still the best new mustang platform?
02-21-2007, 10:57 AM |
SoftBatch
Joined on 09-27-2005
Madison, AL
Posts 86
Points 995
Stan Whitney:
According to the VP at Shelby you cannot order a 54U package unless you send it to Shelby for the extra parts.
James Lambert I tried throwing them away but the garbage man said that the city was not allowed to dispose of charred primates. I told him that I had a wet one. He couldn't take that one either. I didn't bother asking about the frozen ones.
02-22-2007, 12:00 AM |
McCall
Plano, TX
Posts 152
Points 965
Mojave:What about cost? I like race tires. How much do the hot ST tires cost in 275 sizes? I'm not up on ST tire trends, but I seem to remember the Yokohama Advan being mentioned. 275/35R18 Advan Sport: $281 each from Tire Rack 315/35R17 V710: $240 each from Tire Rack Ouch. I for one never liked spending more on tires to go slower. Sure, the Advans will last longer, but for Nats, everyone will be on brand new shaved ones. I personally would rather go to ESP, where I know I can win with enough car prep and driving, than spend almost as much money to go slower and quite possibly not be competitive.
18's? Try the 275/40-17. You can get Khumo MX's for $135 each and Falken 615's for $153. Both of those tires were represented at Nationals this year but yea the class favorite Yoks right now (and I stress that) is only available in 18" so I can see how that would be a negative cost wise.
I have a set of used 275/35/18 Falken 615's and I will see if I can rope some ESP guy in to trying them and see how they do. I just have to think that they will be within 2 seconds of their R compound times. As far as going slower than ESP, sure you will but when you are running against possibly 55+ drivers this year at Nationals that has to be a competive rush worth exploring. Of course since I drive an Evo I'm sure I'm getting discounted here and my 10+ years driving f-bodies doesn't count I guess.
Sorry for STU hijack, back to Shelby GT/FS talk (which I saw one today btw, pretty nice)
02-22-2007, 10:55 AM |
Mojave
Posts 54
Points 255
McCall:
I know you have been driving f-bodies a lot longer than I have (longer than I have even been driving, actually) but I will respectfully have to disagree. But hey, maybe I'm wrong and STU is the ST class f-body guys need to get into.
F Stock for me!
02-22-2007, 12:14 PM |
JT_TT
Joined on 03-01-2006
Winnipeg MB
Posts 258
Points 2,070
we have a local running an ESP 1LE and he did a couple events with the 275/35R18 615's and they were ok, but burning up alot of tire on acceleration. and was way far down in results compareds to his runs on the 275 V710's he was running. actually i think one event roger johnson co-drove and they did 2 runs on streets and 2 on R's they both pulled off over 3 seconds (roger more because he was learning the car) going to the V710's. I just don't think that there's a way to put that amount of power thru that sized tire with that grip level. that being said he's going to 315's instead of street tire class...
however he's running canadian rules and that allows a couple more changes in the motor department..so he's putting down 430 at the rear and you won't get that outta an STU camaro..
KEEP NATIONALS FROM CONCRETE! CAUSE I NEVER RUN ON IT! 2007 SCCA National DS Runner-up Badlands SCCA 2007 Nationals Runs
02-23-2007, 10:33 AM |
Soma07
Joined on 03-15-2004
Kissimmee/Orlando, FL
Posts 12
Points 120
McCall:
I ran my 93 Trans Am in STU last year on 275/40/17 RT615's. It wasn't aweful but I don't think it would've stood any chance against a well preped rally car. Most of the time I felt like I was just controlling wheelspin and trying not to hit stuff vs. actually driving the course. But then again i'm a hack and the car was hardly preped to the limit of the rules so who knows. The same car on race tires was a heck of alot more fun anyways
Jason 94 Miata
02-27-2007, 12:32 PM |
pknowles
Joined on 02-27-2002
Silver Spring, MD
Posts 182
Points 2,570
McCall:You know a couple of us STUers were talking about this and wondering why know one has tried a pony car in STU yet. Seems like the rules allow you to fix all the inhert problems with the cars and that should allow one to be competitive. It would probably be cheaper than building an ESP car as well and it would still be very easy to drive it daily on the street. In STU you could do all the ESP suspension mods, upgrade the brakes, upgrade the diff, intake & exhaust mods, ECU tuning, real 25lb seats, lighweight hood, and any diameter and width wheel as long as you run a max of 275mm tires.
Any thoughts?
I just don't see the point to build an STU Mustang or Camaro given that they are wider, heavier, live axle, etc compared to an STI. If the pony cars have these disadvantages then they have to do something better then the STI in order to run similar times. As far as I know a pony car has one advantage over a rally car and it's power/torque,
but street tires take that away because you can't put it down.
Phil K. 2002 Camaro SS, #68 ESP
02-27-2007, 1:53 PM |
01 FS Z28
Joined on 01-01-2001
Brookville, PA
Posts 545
Points 8,315
An STU f-body doesn't strike me as really wise if you are looking to be truly competitive.... Limited to 275's, and most of the mods needed are needed and usefull in ESP where you can not only run bigger tires, but stickier ones as well. And us lowly 2WD guys need all the help we can get putting down more the 300 ft./lbs at the wheels. Frankly we don't have enough traction in ESP on 315 or 335 R-comps. At least I don't.
Running the heaviest, biggest, worst traction, solid axle car you can in STU just doesn't seem to be the wisest move if competitiveness is the goal.,
Sam Strano Owner--Strano Performance Parts 800-729-1831
02-27-2007, 10:12 PM |
djb_rh
Joined on 07-16-2003
Chapel Hill, NC, USA
Posts 394
Points 3,840
SoftBatch: According to the VP at Shelby you cannot order a 54U package unless you send it to Shelby for the extra parts.
I could swear Marcus Merideth just bought one exactly that way. --Donnie
02-28-2007, 7:14 AM |
sjrife
Joined on 11-15-2003
East TN
Posts 323
Points 4,105
djb_rh: SoftBatch:
--Donnie
I was told the same thing by the general manager of a local Ford dealership. I explained to him why I was asking and told him that I heard that someone had ordered on that way. His reply was something along the lines of, "If you walk up off the street, I can't sell one to you like that."
Steve Rife ETRSCCA
02-28-2007, 8:56 AM |
slowSER
Joined on 12-29-2000
SoBWI
Posts 537
Points 7,220
01 FS Z28:
All I know is that it wasn't very fun* driving a 209 whp, 3300# F-Body on 245's in STX. Can't imagine an extra 30mm of tire on a 4th gen (slightly heavier car with more HP) would be much easier.
Pat
* OK, sometimes it was fun.
'92 Sentra SE-R, daily driver and track car '82 Camaro Z28, ESP, 65% prepared, 50% ownership Upset about Stock class proposals? Get PISST!
03-01-2007, 3:44 PM |
djb_rh
Posts 394
Points 3,840
sjrife: djb_rh: SoftBatch:
It goes to Shelby for the "additional parts" (the stuff designated in 54U), but that has been deemed stock legal. You can't get anything *else* done to it at Shelby, though, and Shelby will do one that way. (Well, there are probably legal things you could get Shelby to do that fall under C&C or whatever, but you know what I mean...no blowers ).
--Donnie
03-01-2007, 6:00 PM |
sjrife
East TN
Posts 323
Points 4,105
Right. I was told that one cannot order a 54U car without the Shelby add-ons (intake, handling package crap, etc)....or more accurately, one could order a car that way, but it'd show up with the Shelby crap on the car.
With that said, I'm not sure if the 54U has anything that'd make that big of a difference anyway.
Steve Rife ETRSCCA
03-01-2007, 8:37 PM |
