New Cobalt SS in DS? If so, does it have a chance?
Last post 08-20-2008, 1:06 AM by mwood. 140 replies.
Page 4 of 8 (141 items)   « First ... < Previous 2 3 4 5 6 Next > ... Last »
  •  06-11-2008, 1:06 PM 304991 in reply to 304989
    Re: New Cobalt SS in DS? If so, does it have a chance?
    Thanks!
    FM
  •  06-13-2008, 7:15 AM 305286 in reply to 304991
    I'd like to point something out....
    Just checked the solo class lists and the NEW SS is NOT on the list for 2008....
    Is there a Fast track, or addendum out there to allow it that I'm not seeing? If anyone IS seriously thinking about one for THIS YEAR, they might want to contact someone and see if they can.
    From the looks of things, it might be better to hold off on buying the 08 NOW, and just order the 09 the way they want it and be ready for next year.
    The local dealer got a yellow SS in yesterday.. I'm going to check it out in the AM.
    Brian Huber
    2006 Cobalt SS-Supercharged
    #58DS
    Official car of One-Wheel Drive Racing's 2008 Solo campaign...
    If you aint last, then you aren't driving this car.
  •  06-13-2008, 8:43 AM 305294 in reply to 305286
    • Jim Z is not online. Last active: 10/08/2008, 4:50 PM Jim Z
    • Not Ranked
    • Joined on 08-19-2001
    • Cincinnati, OH, USA
    • Posts 46
    • Points 1,470
    Darkhelmet:
    The 2008 is legal under the current listing of "Cobalt SS" in D/Stock.  There is no model year specified, and it also doesn't say "supercharged".  The non-forced-inducted version of the Cobalt SS is specifically listed in G/Stock as "Cobalt SS N/A".  Doug Gill was contacted about this, and he stated that the 2008 SS w/turbo is legal in D/Stock for this year, but not the 2009.
    Jim Z
  •  06-13-2008, 8:51 AM 305299 in reply to 305286
    In the 2008 rule book it simply states "D Stock ..... Chevrolet .... Cobalt SS " . There is no date range, no engine/option restriction. Certainly, there is an engine upgrade and better brakes on the '08 and the car should (and most likely WILL) perform better. But the G/S Minis were enhanced and stayed in G/S. That said, whoever might be tempted to make the long haul to Topeka for Nationals might want a letter from SCCA assuring that the '08 Cobalt SS is legal in D/S.
    Bob Buxbaum
    Lee's Summit, Mo.
  •  06-13-2008, 10:47 AM 305320 in reply to 305299
    snaponbob:
    Correct - as the rulebook reads currently, the 08 Cobalt SS(Turbo) would be D/S legal.  I would keep an eye out for more clarification in the next FT, there has already been a letter sent in on this subject.
    -- Drew
    AS S2000
  •  06-13-2008, 11:33 AM 305327 in reply to 305320
    Have to look there... in the pdf for stock classes by make on scca's site, they have the no years, but they have th engine listed..and it's listed as teh 2.0 supercharged.
    That's why i was concerned
    as a side note: they added the 'sport' trim level to the SS(NA) since it was dropped for the 2008 year..
    Brian Huber
    #58DS
  •  06-13-2008, 12:31 PM 305336 in reply to 305327
    Darkhelmet:
    Interesting !!!! But not surprising. In the downloadable 2008 Solo Rulebook (pdf) there is no reference to engine type.
    Bob Buxbaum
    Lee's Summit, Mo.
  •  06-13-2008, 1:29 PM 305347 in reply to 305336
    Yes... interesting indeed!
    that's what got me thinking last night as I was bored senseless.
    Brian Huber
    #58DS
  •  06-13-2008, 8:21 PM 305385 in reply to 305327
    Ok... so the dealer wasn't really eager to let me take the car for a drive today since it was less than an hour before closing, but I DID get to sit in the car, check it out and hear it running...
    The car in stock form sounds like the Solstice GXP with a cat-back.
    Did a nice job of packaging with the front-mount intercooler, and I think for ST class prep, the car could really use a CAI, as the airbox setup on the car seems a bit wierd and possibly a bit restrictive.
    Nice bit of turbo whistle when you get on the gas a bit... nice burble out the back too.
    There is very little clearance between the OEM wheel up front and the Brembo caliper. Wanted to pull it in the shop and try one of my Enkeis on it.
    More to come... there is a black one in NY that doesn't have a sunroof, and DOES have the LSD. The 08s are done, and what's out there is it. The 09's aren't being built for a couple more weeks, and Rallye Yellow is done after 2008 as well.
    Brian Huber
    #58DS
  •  06-13-2008, 8:46 PM 305389 in reply to 305385
    Found a red one close "buy"...
    Sunroof though. I wonder how much it weighs or causes flex in the chassis? Probably not a deal breaker I guess...10lbs? VERY minor chassis flex. I fit in the car fine with helmet on sunroof cars and I am tall so that isn't an issue.
    I really think STX could be interesting with fuel prices the way they are. That said, we have ST guys running race(cough-cough DOT) gas and pumping it out after events now....LOL!
    SEB is sometime interesting with how they look at things. It does make sense in DS but you never know!
    Where else are you going to put it? AS with the rally cars? Uhh...that would seem a little unfair.
    FM
  •  06-13-2008, 9:38 PM 305395 in reply to 305389
    I am 6ft tall and I just about rub the helmet on the headliner in my 06 with the seat cranked down. Since the sunroof moves OUT of the car when open, the inside isn't much shorter than a non-roofed car.  I don't think the wieght is THAT much different, but every lb helps in DS since you got ITRs that are in the 2500 range.
    I REALLY hope someone brings out one to a national event. The parts on mine fit on the new ones ( from what I'm told ), and with the wider wheel, they're easier to find aftermarket wheels for, so maybe someone besides me will make a run with a Cobalt.
    I'm still not decided what I'm driving next year, but it won't be this SS...
    Brian Huber
    #58DS
  •  06-16-2008, 9:36 AM 305532 in reply to 305395
    Woo-hoo! 245 Kumho's fit in the front with some room to spare for some camber adjustment.
    We'll see if the car is going to be competitive in the next few weeks.Hmm
     FM
  •  06-16-2008, 11:10 AM 305553 in reply to 305532
    Does that mean you bought one? Wink
    Sponsored by AgileAuto.com
    D.C./Philly Region - 3 STX
    cardomain.com/id/piknockout
  •  06-16-2008, 11:46 AM 305567 in reply to 305532
    FM is coming to the darkside...:D
    let me know what you think Mike... if you make it to nats, you can take a drive in my SC car and tell me your impressions..lol
    Brian Huber
    #58DS
  •  06-16-2008, 12:23 PM 305573 in reply to 305567
    After putting the 135 in DS, there's no way they're kicking the Cobalt out...IMO
    1991 Saturn SC-226k miles- HS #106
    1990 Miata- Blue, with black spots- daily
  •  06-16-2008, 2:47 PM 305604 in reply to 305573
    Let's just say I have very close access to a black one that might show up at a few events....
    Snicker-Snicker.
    FM
  •  06-16-2008, 7:00 PM 305655 in reply to 305604
    Way cool Mike !
    I want to hear your thoughts....
    Brian Huber
    #58DS
  •  06-16-2008, 8:06 PM 305671 in reply to 305655
    Stock legal wheels are turning out to be a hassle. At least ones that are lightweight...Just like it was with the ZOK Solstice at first. I have a set of Forgelines that I might be able to convert from 18x8 to 18x7.5 and keep a legal offset but what a hassle!
    Already have a plan with dampers...will use stock front bar for now. It seems sized well. Chop the muffler off to save weight. Align and throw some sticky's on it and see if we can win some pax battles. Results will be telling.
    FM
  •  06-16-2008, 8:32 PM 305683 in reply to 305671
    Fastmike:
    FM
    welcome to the class! or back to the class if it applies (im no historian)
    difficulty finding appropriate wheels seems an unwritten pre-req to DS assuming you dont own a honda product.  you think 18x7.5 is bad?  mazda cursed me with 18x7's +52.5's Angry
    hope the car works out well for you, but not too well Stick out tongue
    Scott
    07 Mazdaspeed 3
  •  06-16-2008, 9:50 PM 305703 in reply to 305683
    Thanks for the welcoming!
    I don't think I have ever run in DS.
    We'll see how the car works out. No promises yet. Hoping for good weather this weekend.
    FM
