New Cobalt SS in DS? If so, does it have a chance?
Last post 08-20-2008, 1:06 AM by mwood. 140 replies.
Page 6 of 8 (141 items)   « First ... < Previous 4 5 6 7 8 Next >
  •  06-23-2008, 8:08 PM 306645 in reply to 306643
    Re: New Cobalt SS in DS? If so, does it have a chance?
    I hope you get one.
    I am planning on setting the car up with oversteer coming into corners under braking or lift throttle situations. Get a data system if you want to really know what each tire does.
    Ask Mitchman how I like my FWD'ers....He has a MiniS. SHHHH!!! Don't tell all my secrets Mitch!
    FM
  •  06-23-2008, 10:57 PM 306684 in reply to 306637
    SDR 761:
    So..how do you think the new Cobalt SS will do in GS? Big Smile
     Stranger things have happened!
    Make GS the LSD FWD class and be done with it is one way to fix the oddness.
    FM
  •  06-23-2008, 11:14 PM 306689 in reply to 306684
    So, has anyone stumbled across any real information about grinding the struts and how far you can go?  Or if not, has anyone gained any neg camber without grinding?  I have a friend who just picked one up and I'm his alignment guy...
    Brian Coulson
    07 Mazda RX-8 BS
    Powered by triangles???
  •  06-23-2008, 11:44 PM 306696 in reply to 306689
    With a 2007 supercharged Cobalt SS that might serve as my "backup car" I started inquiring about the alignment options also.  There is documentation that follows along the lines of what was allowed with the J-Body cars.  The document does specify a range of allowable adjustment and if I didn't carefully review it myself and see it from different sources, I would have been cautious about doing this.  This document does not mention anything about having to replace the front knuckles which were the subject of replacement for competition use.
    Mark Valera
    2001 Chevrolet Camaro Z/28 "1NE"
    FS #93
  •  06-24-2008, 12:13 AM 306701 in reply to 306689
    Spogie:
    What I've seen on other Delta chassis cars: The strut tab is essetially a sandwich of two metal stampings pressed together.  One stamping has hole barely large enough for the bolt to pass through.  The other stamping has an ovaled-out hole. You're allowed to grind the small hole to match the larger oval.
    Can't confirm this yet on the SS Turbo, but will see if I can find the FSM reference tomorrow.
  •  06-24-2008, 3:42 AM 306711 in reply to 306701
    Hey, FM, you need any bags for all that sand you're looking to carry?Stick out tongue
    In slow, out fast.
    In fast, out backwards.
  •  06-24-2008, 7:04 AM 306715 in reply to 306711
    I don't know what the GMPD mechs did @ nats on my SS, but they got 1.3 out of it with no hammers, grinding, extra parts, or anything... I was IN the car while they did it, so I can't say what they DID do....
    Brian Huber
    06 Cobalt SS-SC (retired to DD Duty )
    02 Z06 ( Whole new ball o' wax )
    #??SS
  •  06-25-2008, 11:25 PM 307307 in reply to 306715
    http://www.cobaltss.net/forums/showthread.php?t=105562
    Hmmm $23K?
    I guess GM is listening...
    Kyle
    Kyle Freiheit
    Porsche 914 2.0ish
    92 Mazda Miata STS2
    2007 Season, Z0K Solstice
    2008 Roadracing?
  •  06-26-2008, 7:29 AM 307339 in reply to 307307
    Yes.. you can get an SS for under 23 with the discounts and stuff...
    I saw that new display in person last weekend @ Mid-Ohio... very cool.
    Brian Huber
    #??SS
  •  06-26-2008, 12:49 PM 307420 in reply to 307339
    Darkhelmet:
    Disclaimer - the following is an uncompensated comment.
     Look at the top of the page for the Superior Chevrolet link. They will order SCCA members the Cobalt SS of their choice at invoice cost and arrange "courtesy delivery" anywhere in the US. Just thought I would share that tidbit, as I will buy from there if I decide to buy one. The dealership G.M. is an road racing SCCA member and has been very supportive of the surrounding Regions and Division.
    Bob Buxbaum
    Lee's Summit, Mo.
  •  06-27-2008, 9:59 PM 307720 in reply to 307420
    Bob... thanks for the info... I am very torn at the moment between a used C5 Z06 and the new SS ( I know it sounds crazy... don't ask ), so not sure what I'll end up doing.
    Fall is the time to make tha choice.
    I could've used a diff today in Peru...
    Brian Huber
    #??SS
  •  08-04-2008, 9:32 AM 313660 in reply to 307720
    Looks like Dietz had a solid showing at Wendover in Mike's '08 Cobalt SS, finishing 2nd to Strelnieks. Mike, any word on how Kevin liked the car for a Pro? What tire sizes did you end up going with?
    Chike Dellimore - Blue Ridge/Washington DC Regions
    2006 Galaxy Gray 6MT Mazda RX-8 (B-stock)
    Former 2006 Steel Gray 5spd WRX (D-stock)
    "I have a lot to work on...crazy is still on the list."
  •  08-04-2008, 10:47 AM 313682 in reply to 313660
    Kevin was in his own car and, I believe, was on 245 Kumhos...and, evidently, was getting killed off the line by the very quick 135i. Interesting data point, though, particularly with the always fast Kinch in the IT-R in a close 3rd spot...I wonder how it would have looked if it had been a Solo II, rather than Pro?
    In slow, out fast.
  •  08-04-2008, 12:47 PM 313721 in reply to 313682
    mwood:
    Thanks Mike - I didn't realize Kevin had picked up a Cobalt SS turbo as well.
    I wouldn't be surprised if he was murdered off the line by the 135i - at the Toledo Pro both Beth and Erik were cutting 1.9 60ft's with the car.
  •  08-04-2008, 1:00 PM 313729 in reply to 313721
    Chiketkd:
    mwood:
    Could be an interesting Solo Nationals if they can all make it, i really really wish there was 2 pro's within 12 hours drive so i could attend the finale, but the 18+ hour treks makes them out of reach. My 60 foot on the TT be at or better then a 1.9 that's for sure so that could have been interesting.
    Bridesmaid Racing
    2008 SCCA Nationals DS Runner-Up
    2008 Kansas City NT DS Runner-Up
    2008 Milwaukee NT DS Runner-Up
    2007 SCCA Nationals DS Runner-Up
    2007 Milwaukee NT DS Runner-Up
    2006 ASN Nationals DS Runner-Up
  •  08-04-2008, 1:07 PM 313736 in reply to 313729
    I don't think it's the 60' that's the story with the BMW...more like the 200', those things pull HARD once fully spooled up (which is basically from 2000rpm). I drove a 335i recently and was amazed at the linear acceleration rush. Sweet.
    In slow, out fast.
  •  08-04-2008, 1:13 PM 313740 in reply to 313729
    There could not have been a better course for a BMW, in any class, all transitions with only one slow turn around. If you took out all the excess gates, that were really just hiding more slalom cones, you ended up with like a 27 cone slalom and a 180.
    I would not try to use this event as much of data point.... The high altitude really hurts NA cars, particularly those that need to rev Crying. I did not talk to Kevin about his set up, but I doubt the Cobalt is nearly as far along as Erik's 135.
    Jason Isley
    2005-2006-2007-2008 B Stock National Champion
  •  08-04-2008, 1:21 PM 313745 in reply to 313740
    I totally forgot about the air density thing...I do think Kevin and FM have done a fair amount of work on the Slobalt, though.
    In slow, out fast.
  •  08-04-2008, 3:27 PM 313770 in reply to 313745
    I thought Kevin did ok. Car is NOT set up for concrete and it is a Pro so don't look into the event too much. Interesting that another DS person knocked Erik out of challenge in the first round though.
    About the Cobalt: We have been working on it a lot and it is getting better. Not much left to do for set up on asphalt for more speed. I will be running it at Packwood Tour. I think Kevin is going to run his Vette.
    Maybe the SEB will move the Cobalt SS/CS/TC to GS for 09? Pretty please? I guess the thing looked like a skyscraper parked next to the TypeR.
    FM
  •  08-05-2008, 4:02 PM 314046 in reply to 313770
    And I'm sure your tires looked like Formula 1 tires in comparison to the Type R's...
