Last Post 11 Oct 2016 07:47 PM by  Zefy
Vorshlag Scion FR-S LSx Alpha Project
14 Apr 2014 06:41 PM
    Project Introduction - April 12th, 2014: This is the first of many posts where we will document our first GM LSx based V8 swap into an "FT86" chassis, or just an "86". That's the Scion FR-S and Subaru BRZ rear wheel drive sports coupe, for those of you unfamiliar with the nickname. Also known as "the twins", these two-door coupes are a co-creation from Toyota (ne Scion) and Subaru, and a revolutionary design for them both. These are two companies normally making plebeian FWD econoboxes (Toyota) or plebeian AWD econoboxes (Subaru) - and together they made this completely different car!
    This introductory post is a big one, so you might want to go grab a snack before you start reading...
    Some call it the modern day Miata coupe, which it really is in some ways, but not in others. True, it is a relatively lightweight 2 seater (there is a faux back seat) with a hard top coupe chassis, which the Miata never got, but should have. The power-to-weight ratio is similar to the MX5 Miata, meaning pretty poor. But it does give those "pure" sports car feelings, and some would argue that a "pure" sports car is always a light RWD 2 seater with lower power but good handling and gearing.
    Well, we beg to differ. An enjoyable sports car is anything with RWD, good handling, good brakes, and a GOOD power-to-weight ratio. The formula is simple: Lightweight, big power, rear drive, make it turn and stop. And the FR-S/BRZ chassis almost fits that bill, but it has a few glaring holes that we aim to fill.
    What's Going in and Why?
    Before you wonder what we are doing in this project, I will give you the quick summary: a customer brought us a 2013 Scion FR-S with a turbocharged FA20 motor, this car had several "major engine problems" previously, and now we are swapping in an all aluminum LSx GM V8 engine and a manual transmission strong enough to take it into this chassis. This LSx V8 swap will add a lot of engine displacement and horsepower, and some much needed powertrain reliability, yet still allow for affordable upgrade path for the future. This Alpha FR-S LSx will be used for both street driving and road course use, and already has some track oriented upgrades such as StopTech brakes, 17x9" wheels, racing seats, aftermarket axles, a roll bar, and a rear seat delete.
    Out with the old 2.0L engine, in with the big honkin' V8!
    Before we get to the "why a V8 swap?!?" question, let's look at this chassis as it comes from the factory. This Rear Wheel Drive coupe was introduced in 2012 as a '13 model year car and has been a popular car for people that liked the small, sporty handling of a RWD 2 seater like the Mazda MX5 but wanted a roomier interior, a much more rigid chassis via the hard top coupe design, and a nominal back seat. These cars are available as the Subaru BRZ and Scion FR-S (as well as the Toyota GT86 in other markets outside the USA).
    This chassis was jointly designed by Subaru and Toyota, and it shows, with some of the quirkiness from both companies survived in this final design. And a lot of "parts bin" engineering solutions, but that is going to happen on most lower volume cars like this. Some bad ideas managed to stick around, which we will address in this build. Many more details of this new-for-2013 model chassis are well documented on the interweb and we've talked about it extensively on our 2013 BRZ Project Build Thread (linked here).
    In that thread we document what we felt were many of the shortcomings on the OEM FT86 models and show our numerous fixes, updates and suggestions to make them better. We show parts we bought, built, or designed to make these cars stop, turn and go better. Things like replacing the underwhelming OEM tire and wheel package, upgrading the super soft springs and suspension bushings, and fitting some proper monotube coilover dampers and camber plates up front.
    Many thousands of FT86 owners have agreed that these cars work better with a few mods and the aftermarket has grown quickly for this chassis, with many offerings available to upgrade the wheels, tires, brakes, dampers, spring rates, alignment settings, bushings, exhausts, and more. An entire aftermarket segment has sprung up in the past two years to support FT86 buyers. You see it is perfectly normal to want to modify a brand new car, and real gearheads understand that virtually no car is ever built 100% perfectly for everyone from the factory, especially in the first year. The motorsports and enthusiast aftermarket exists simply because the demand to upgrade and modify cars, and the FT86 owners are no different.
    An LSx Swap Is Just Another Mod
    We see the LSx V8 swap as "just another modification" that can make this car better. Sure, maybe we're just taking the "mods" thing a little further than some, but here at Vorshlag we have done so many LSx V8 swaps on many makes and models of cars that nothing phases us. Not the "its a brand new car!" nor the "How can you make electrical bits work?!". We have lots of happy customers to show for all of that work over the past 12 years that we've been doing these LSx transplants. Swapping motors is fundamentally not any different than folks adding superchargers, turbochargers, or built FA20 motors.
    Will swapping in a Corvette V8 motor into an FT86 piss off some purists? Sure it will. Its not "JDM, yo". But we simply don't care about any of that. We are not brand loyalists in any way/shape/form; we simply use "the right tool for the job". Brand loyalty doesn't make a car faster, and ignoring this obvious engine upgrade prohibits 86 owners from these most affordable and reliable powerplant alternative on the market. Is this "brand loyalty snob" pushback something we've run across before? Of course. The BMW community was pretty cold to the idea of an LS1 V8 in a Bimmer when we first showed it in 2002, but many warmed up after they saw, heard and rode in the "hybrid" brand V8 powered cars we created and we are quickly approaching our 100th BMW LSx V8 swap sold this year.
    This V8 powered BMW E36 M3 with a Vorshlag swap kit makes 420 whp on pump gas and 5.7 Liters of LS1 goodness
    The simplicity, reliability, low weight, compact size, aftermarket support, power potential, and just RAW POWER of the OHV aluminum LSx V8 is hard to ignore. Since the early 2000s these "LS1 swaps" have become very popular in virtually any car it is stuck into: the 240SX, multiple generations of RX7, various Miatas, BMWs, classic muscle cars - you name it. And we've made a good dent in the BMW purists' armor, selling so many E36 and E46 LS1 swap kits over the past 12 years. Lots of folks with street or race prepped BMWs are running around on LSx power with help from Vorshlag.
    379036_10150691810963448_408074865_n-S.jpg 401503_10150691811158448_1736854426_n-S.jpg
    So don't look at this project and think, "What drugs are these guys on?!" There is a method to our madness, and lots of proven V8 swap packages on the roads due to the hard work we've done to develop them. There are also millions of all aluminum LSx motors just sitting around in wrecked GM cars and trucks that we can pick these motors from. This makes the LSx engine prices affordable, and with tens of millions of this engine family produced since 1996 (and still being built to this day) the market for go-fast parts for this engine is MASSIVE.
    There Are Many Things That Can Be Upgraded on the FT86
    We've done a lot of work on this FT86 chassis here at Vorshlag, including: developing camber plates for it, co-developing the MCS coilovers using our in-house 2013 BRZ, as well as performed track and autocross upgrades on multiple examples of 86 coupes. We've done big brake kits (however - these cars usually don't need this), pad swaps, made our own stainless brake lines, brake cooling ducts, lots of different coilover installs, bushings, swaybars, exhausts, control arm swaps, tons of wheel and tire testing, and much more. We know this chassis inside and out.
    We have tracked and autocrossed multiple examples of the FT86, including former Vorshlag employee Matt's blue BRZ, shown here. These cars are quite fun to drive in autocross or HPDE/Time Trial, once you perform a few basic modifications.
    We feel that the OEM 7" wide wheels and 215mm Prius tires are extremely undersized and underwhelming, but after upgrading to a 17x9" wheel and aggressive 255/40/17 street tire these things can make huge grip. The stock ride heights are also a bit too tall and the spring rates too soft for any serious track use, so we tend to go straight to coilovers (like those from MCS) and firmer spring and damping rates, then add our spherical top mount camber plates up front for alignment and handling adjustments. We've also have had good results installing Whiteline bushings and swaybars, among other solutions.
    Anyway, the 86 is a neat little chassis, which can be made to handle very well with the right parts, and with an upgrade to better track brake pads/lines/fluid they stop like a beast on track as well. Read our BRZ project build thread for more on our thoughts about the brakes and suspension, which we won't really cover in this thread.
    This thread is not about: suspension, wheels, tires or handling. What we are covering here is a better choice of POWER PLANT for the 86
    After those non-power things are addressed, our number one beef with the Scion FR-S and Subaru BRZ has to do with the goofy drivetrain it comes with. Yes, goofy is the only way to describe the flat-four engine in these cars. The engine that comes in these things is a giant headache with very limited potential and questionable reliability when modified.
    What's So Wrong With The Subaru FA20 Boxer Engine?
    We aren't picking on all Subaru engines, just this one. It isn't that much of a hindrance in low speed autocross competition (these cars are doing very well in C Street and STX classes!) but the deficiencies of the FA20 quickly becomes apparent on a road course. These cars are what you'd euphemistically call "momentum cars"... since they don't make nearly enough horsepower for the weight of the chassis, once you try to get going above about 30 mph. I say the same thing about all stock-engined Miatas, among other cars. These momentum cars are better suited running with the Miata run group on a road course, as the Mustangs, Corvettes, 911s and other powerful cars are going to be flying by your FT86 (if those other guys have a good driver, of course - no amount of power can make up for a lack of talent!)
    The Subaru built FA20 / Toyota 4U-GSE 2.0L "flat-4" (aka: boxer) direct injected 200 hp engine that comes in these cars is a novel piece of engineering, I suppose. It has a "low center of gravity" layout and all that, but it is also a staggering 31" wide. This is really one big ass little engine. It is so wide that the frame rails had to be pushed way out there, but even so the clearance between the cylinder heads and the frame is tight. I suppose you can remove the spark plugs without pulling the engine, but it looked tight. This layout reminds me of Porsche 911 repair nightmares (which has a similarly wide flat-6 engine).
    The engine block is short front-to-back (only 18" long) but it is placed in the engine bay way too far forward. So far, in fact, that more than 1/2 of the mass of the engine is in front of the front axle centerline. This is very strange, and I cannot say why the Subaru and Toyota engineers that designed this chassis and drivetrain placed the engine so far forward. They even had to use an extra long bellhousing and a crazy long shifter extension on back of the transmission to get the gear shift lever far enough rearward to mate up with the driver in the cockpit. My calibrated engineer's eyeball says this stock motor could be moved back by another ~10", which would help the front to rear weight balance significantly; in stock form we measured 56% of the weight on the front wheels, and our Alpha tester's modded FR-S has a 55%F/46%R weight bias.
    Rick's FR-S came to us with a turbo kit, StopTech BBK, rear seat removed, a 4-point roll bar and racing seats installed, weighing 2682 lbs
    So the engine is super wide, and fore-aft engine placement of this lump is not great - it could have been improved with just a little bit of effort. In my opinion this car was really built from a lot of older carryover Subaru parts and technology... Subaru GR design in the back, some Subaru GD front suspension design, a traditional forward biased engine layout (things like the starter, that sits way up high and would have interfered with the firewall if it was set back, would have had to be redesigned and moved down below), and all wrapped in some pretty new bodywork. Hey, it is economics, I get it... to totally design a 100% all new RWD coupe from scratch would have cost so much more, and that would have driven up the car's price. One of the saving graces of this chassis is the low cost: The FR-S starts at $24,500 sticker and the Subaru BRZ starts at $25,495.
    The engineers did do a lot of things right: it is a proper Rear Wheel Drive car, it has a rigid coupe chassis, the interior is roomy for those of tall stature, the seats are excellent, visibility is pretty good, and driver ergonomics are excellent (placement and adjustabilty of the seat, steering wheel, pedals, shifter, and other controls). Still, the specific examples of engineering compromises are numerous and the FT86 chassis contains many examples of when "the bean counters win out over the engineers". We're here to fix some of those compromises, to make a great little sports car into an EXCELLENT sports car with some serious track credentials.
    continued below
    continued from above
    The saving grace of the FA 20 engine is the height: this lump is a lot shorter than an average upright inline-4 or V-configuration engines, with the bulky DOHC cylinder heads sitting very low down in the chassis. That is all this engine does add - a lower center of gravity. But low weight isn't what this unusual engine layout offers, not hardly. As you can see below, we've already weighed the stock FA20 engine and transmission at 480 pounds. This is, by far, the heaviest 4-cylinder aluminum engine we've ever weighed.
    Weight of 2.0L engine and 5-spd transmission is 493 pounds with a 13 pound dolly; the aftermarket turbo was removed
    There are other things about the Subaru flat 4 engine that are unusual. With only 4 cylinders it still has an inordinate amount of parts and complexity: 4 camshafts, 2 cylinder heads, lots of cam drive chains and tensioners, and the block has to be split in half to disassemble the connecting rods and other internals. The compression ratio of the FA20 engine is also very high at 12.5:1, an uncommonly high value for a production gasoline engine. This means you have to run Premium (high octane) fuel and adding forced induction (super- or turbocharging) is a very risky proposition. The saving grace is the Toyota designed Direct Injection fuel system, which uses very high fuel line pressure and injects fuel directly into the combustion chamber (diesel engines went to this type of direct fuel injection a long time ago). These new "Gasoline Direct Injection" (aka: DI) systems tend to add 5-10% more power and 10-20% extra fuel efficiency over a more common "low pressure" (45-60 psi) port fuel injection system, and its how they can get away with that much cylinder compression. But since these DI systems are so new they are difficult to tune, upgrade and modify. Even the factory Toyota system used on the 86 includes a second set of "port fuel injectors", to help with low engine speeds and cold start problems (see this video for a better explanation of the factory DI and PI systema)
    All this high tech wizardry doesn't magically make this 2 liter engine produce awesome levels of power, however. Even the 1999-era Honda S2000's F20C engine made 240 hp with 2 liters, normal pressure EFI, and 11:1 compression. The 2013 FR-S makes 200 hp with the same displacement, Direct Injection and a higher compression ratio. When measured the FA20 is making about 160-170 whp, and the chassis dyno measurement shown below on one of our tester's stock 2013 BRZ is typical.
    The stock horsepower numbers are something an FT86 owner is never going to brag about
    The blue test car we worked with in 2012-13 made a best dyno pull of 167 whp (measured at the rear wheels on a DynoJet chassis dyno) in stock form, and with a measured curb weight of 2775 pounds (+ 200 for a driver like me) to push around, that makes for a 17.8:1 pounds per hp ratio, which I'll round up to 18:1. Pounds per hp is a common number that racers look at, as many road racing classes have strict limits there. Our NASA TT3 prepped 2011 Mustang has to conform to an 8.8:1 pounds per hp ratio, giving us twice the horsepower for each pound we haul around compared to an FR-S/BRZ.
    That 18:1 power to weight ratio is more inline with an early 1990s 1.8L Miata. For some folks, that's perfectly fine. For others, they need more power to create the higher acceleration rates that lead to more thrills, and on a road course this is amplified dramatically. Tens of thousands of people have made the comment about the 86 twins that they need more power. We've had dozens of owners ask us here at Vorshlag "When are you going to make an LS1 swap kit for the 86?" So we had been quietly looking for that perfect "Alpha customer" for the past year and a half.
    Each time I have driven these cars on track (see video above), the immense grip levels were notable simply because of their inherent lack of forward thrust the 2 liter boxer engine provides. It goes fairly well, and you can terrorize stock Miatas in a BRZ or FR-S, but that's about it. We've seen so many aftermarket parts pop-up to try to rectify the limited power levels: all manner of headers, cat-back exhausts, cold air kits and other bolt-on doo-dads, custom tunes and even E85 ethanol fuel conversions. All sorts of manufacturers and shops have been trying to unlock more power - but most solutions seem to come up short. There just isn't a lot of "easy" horsepower left to untap on the FA20 engine, and many of the claims of "300 whp!" end up being a bunch of internet hype or turbo ticking time bombs. Even a 200 whp FT86 build is somewhat legendary.
    Weight of a bone stock 2013 BRZ Premium package car came in at 2775 pounds on our scale
    Why I Hate Boosted Track Cars
    The main power solution now coming to market for this chassis includes forced induction kits using either a turbo- and supercharger. I lump both of these Forced Induction (aka: "FI") solutions into the same category, which I often label with the derogatory term "boost buggies". This Alpha build FR-S came in to our shop with an turbo kit installed, and was one of the first Ft86 car's in Texas with this particular kit. I don't know what brand of kit this is, but it almost doesn't matter - as these FI kits will all suffer the same fates in the 12.5:1 compression ratio FA20 motor. Detonation and premature engine failure until the engine is modified with new pistons that can lower the compression ratio.
    When the lowest part of your track-built car is the turbocharger and engine oil line, trouble awaits
    The layout of this particular turbo kit was less than ideal, in my opinion, especially for track use. The turbocharger was mounted low, underneath the engine, and both the turbo housing and the oil feed line to it were the lowest parts on the chassis. There was also an electric oil pump for the turbo oil feed. This would mean than an off-track excursion could easily rip the oil line off or damage the turbocharger first, which could turn into an expensive mistake. This car was supposed to be built as a reliable track car, but this kit pretty much precluded that, as you have had to make the bottom of the car safe for "offs" by adding skid plates, thus making ground clearance even worse. This turbo package and associated tuning also ended up killing two motors - first the stock 12.5:1 motor then a lower compression motor - both of which died on the dyno, according to what we heard. Before the final race prepped turbo motor was ever able to take a single lap on track, the car's owner went looking for a better solution.
    There's not going to be a blame game here - it was a commercially available turbo kit, but something obviously went awry. Several times. Even without multiple engine failures on the dyno, I think adding a turbo system to a high compression stock motor with cast pistons was always going to be a recipe for disaster. Maybe it would have lived with the final race built motor it received, but we will never know because that motor is no longer in this chassis. There were too many other things wrong with the installation to document, but needless to say, we're going to put it back together the Vorshlag way - with a big naturally aspirated V8 making a reliable 400 whp, a beautiful exhaust system that has a sound that will make you crave it, proper cooling and sub-system solutions, and a distinct lack of zip ties and bailing wire.
    A Pikes Peak team we sponsored with some suspension bits had decent luck with a turbocharged set-up on their FR-S race car, but it had some serious tuning hiccups and teething pains to deal with before it got to the mountain. For that extreme hill climb you see over 14,000 feet of elevation at the top of the 12 mile race course, and the only way to maintain horsepower at the top of the mountain is with FI or electric power. FI can make up for the lack of air density and electric motors don't ingest air, so they don't care.
    But most of us don't race at 14,000 feet, and in most cases a larger displacement naturally aspirated engine is much MUCH more reliable than any FI engine, especially engines that were not FI from the factory. I'm personally not a fan of turbo and supercharger "kits" installed onto stock motors, and I have seen and experienced a lot of bad examples of this first hand. I worked at a tuner shop that specialized in supercharged V8s back in the day and customers were always breaking pistons, head gaskets, and more. The only way to make them live, even on drag/street cars, was with very mild boost levels + a GOOD fuel system + a conservative tune + a very well built motor. That hasn't changed.
    Vorshlag has worked with FI engines for road course and hill climb use and we understand the REAL challenges to making these reliable
    The problem is exacerbated when the car/motor in question never came from the factory as a turbo model. You see, there is a LOT of engineering and development that goes into building a factory turbocharged car, with all sub-systems getting upgrades to deal with the extra power and HEAT of a boosted engine. To make a non-turbo car into a turbocharged set-up is a lot of additional work to get it reliable. It is so much more than "bolting on the turbo". All sorts of things need to be insulated and re-routed, all fluid systems need beefed up cooling, and heat soak becomes a major issue.
    And don't get me started on what it takes to make a turbocharged or supercharged engine car live on a road course. The things you need to make a turbo engine live in drag racing or street use pale in comparison to what you need to do for track use. Everything heat soaks... the turbo housing, the intercooler, the intake manifold, the oil gets cooked... you almost cannot make an intercooler big enough to shed the heat from a turbo to run on a road course for more than a handful of minutes. The intake air temperatures on most turbocharged engines used on a road course keep going up, up, up.... to the point where the pistons eventually melt or something goes BOOM. Even short road course use set-ups like Time Attack and Time Trial face huge hurdles and challenges to keep the motors together and reliable.
    Road course competition in any FI car includes a lot of extra prep and maintenance
    So we've explained why an FI build doesn't make sense for this dual purpose street/track car. What is our solution? If you've heard of Vorshlag then you already knew what we had in store before you read anything on this post - swapping in a lightweight V8 engine that will nearly triple the stock displacement. That is a common answer we have to the question of "I need reliable horsepower". Our plan is to use this particular 2013 FR-S as our "Alpha" or first prototype build, then perfect a bolt-in LSx V8 swap kit for FT86 owners to be able to swap in this aluminum V8 motor with as much ease as possible. We always start all new swaps with an Alpha build, which includes the following cars...
    Vorshlag is well known for LS1 swaps in chassis, as well as our production kit components that make installing these V8s easy
    If you do some research you will see that Vorshlag has developed and built LS1 V8 swaps for a number of different chassis, and our E36 swap kits are extremely popular with new sub-system parts and products released from 2007-2014. We released our initial "Stage 0" kit (the parts necessary to mount the drivetrain) for the BMW E46 chassis last year and those have also been received very well. We have done a number of other "one off" LS1 swaps such as the BMW E30 LSx that we built for the Grassroots Motorsports $20XX Challenge, which we won overall with in 2011. Then there was the BMW Z3, and we're also need into the development for an NB chassis MX-5 Miata V8 swap kit.
    The beautiful engine bay of the Z3 LS1 was worth opening the hood to see!
    continued below
    14 Apr 2014 06:42 PM
    Alpha FR-S LSx Swap Outline
    What we have planned is simple and meshes with the customer's needs and the shop that brought him to us. I will give the basics here, and show the step-by-step fabrication and development pictures as the V8 swap kit is developed. We won't give away EVERY detail, as we've had copycats try to duplicate our work over the years. So I won't give away part numbers, finite measurements and the like, but we will show more than enough to let you readers see how we do a new Alpha build.
    The owner of this car is named Rick and he found his was to Texas Track Works in late 2013, a shop in Ft Worth the specializes in track prep, race alignments and more - and is a Vorshlag camber plate dealer. Even though in some ways we are competitors we are we are friends with the staff at Texas Track Works and will partner with them to complete this Alpha build. They are the reason why we have the opportunity to work on this particular FR-S, and for that we are thankful. Rick rode in one of TTW's customer's track/street cars: a Nissan 240SX (above left) with a LS1 swap installed by TTW. We've raced against this car in NASA TT3 in our TT3 Mustang (above right) and that Nissan really scoots. This Nissan is a clean install - unlike some of the hack V8 swaps we've seen built elsewhere, the TTW crew gets the details right and has the race experience to know what matters. After that test ride in that lightweight RWD coupe with proper LSx V8 power, Rick knew what he wanted in his FR-S... LSx V8 power! After that decision it didn't take Texas Track Works long to make the call to us here at Vorshlag, and we came to an agreement: where Vorshlag would cover the development costs of this swap if we could see a way to make it as a kit. So they brought us the car in early January 2014 and we took a look...
    Once the OEM drivetrain and turbo kit were removed we got a closer look at the naked the engine bay. Wow, the underhood area is HUGE! The frame rails are a staggering 31" to 33" wide (they taper in at the back), to house the immense Subaru flat-4 cylinder engine, and I felt immediately that the LSx swap would fit well. We first took a LS1/T56 mock-up drivetrain we keep on hand for swap development and tried to stuff it into the car...
    Our first LSx V8 + Tremec T56 mock-up had the shifter portion was way too far forward, but we knew what to do.
    Hmm, the traditional 1998-2002 Camaro/Firebird Tremec T56 6-spd was too short, as was the next drivetrain we tried: an LS1 with a Tremec TKO600 5-spd. That transmission length was even worse, and no matter how far back we moved the engine the shifter location was still way forward of the factory shift boot and opening in the center console. The TKO600's shifter was way inside where the dash would be. Neither would work.
    These two secondary braces had to be removed, and after using our spot weld cutter on 6 spot welds each one fell right out
    After removing one spot-welded transmission tunnel brace (see above) and unbolting a few items mounted to the firewall, we did some more drivetrain mock-ups and got the engine back as far as we could without serious tunnel surgery, something we always try to avoid in any swap we want a customer to be able to replicate in their home garage. We measured the shifter location on a ZF S6-40 6-spd transmission we also had on hand, and it wasn't anywhere close either. We finally called our transmission expert, Joe D, and he mentioned the Tremec Magnum XL 6-spd that featured a direct mounted shifter about 5.5" further back than the normal direct-shift T56.
    The second drivetrain we swapped in was another LSx V8 and a Tremec TKO600 5-spd
    This transmission was developed for the S197 5.0 Mustang chassis as well as the 5th gen Camaro LS3, but never came from the factory installed in either car. Both of these cars come with factory transmissions that have remote mounted shifters, and in both cases the shift feel is terrible. We've installed T56 Magnum XL 6-speeds into late model Mustangs and the difference in shift feel is remarkable, not to mention the extra torque capacity these have (rated at 700 ft-lbs of torque!) compared to the stock Gretrag MT-82 in the 5.0 Mustang.
    The long-awaited and custom ordered Tremec T56 Magnum XL arrived!
    The problem was, Tremec hadn't yet made the production model of the transmission to work with the GM LS-series engines. Joe said he could custom build us one with an input shaft made to fit the flywheel depth and pilot hole diameter of the LSx, like he has done for Grand Am and World Challenge racers with 5th gen Camaros. So after many measurements and inspections on the FR-S engine bay and tunnel we took a gamble, ordered this custom Magnum XL transmission and waited for it to arrive. We also picked up an LS2 GTO 6.0L oil pan, which has a "front sump", hoping it would clear the FR-S crossmember. Based on previous swaps and where this FR-S crossmember was located, I felt this "front sump" oil pan would fit.
    The final LSx + T56 Magnum XL drivetrain placement was about as perfect as you can get
    After many weeks of waiting the Magnum XL arrived and we got to work on the final series of drivetrain mock-ups. We also bought a new LS3 intake manifold kit, complete with fuel rail and drive-by-wire LS3 throttle body. We want to use the later model Corvette LS3 PCM (power control module), as it has a faster processor and advanced CAN-BUS options, to better match the FR-S systems. That means we would use the LS3 intake manifold, which has an electronically controlled throttle and not a direct cable controlled throttle. The cylinder heads for the LS3 are different than what we have on our mock-up block, but at this step it didn't matter.
    After about 6 or 7 iterations and tweaks with the "LS3" + Magnum XL drivetrain in and out of the car we finally have the engine where we want it, as far back as the heater core and intake allow. We then tweaked the driveline angle (downward tilt of the engine) to match the factory diff angle. Then we started building the prototype set of motor mounts.
    That's where we are now, and today our crew removed the interior to help develop the transmission crossmember. After those bits are done we will develop a full length 1-3/4" primary stainless steel header with 3" collectors. Unlike what some other V8 swap kit makers like to do, we make real exhaust headers the hard way, because it makes SO much more power everywhere. The shortcut normally taken by others it so buy a cheap set of 1-1/2" "block hugger" shorty universal fit headers, heat them with a torch and smash any tube with a hammer that gets in the way.
    The BMW E46 LSx prototype headers were developed and built in house, with final production by a major US header manufacturer
    That short cut header is a huge restriction and can cost upwards of 50 hp, but making custom full length headers is so much work that most shops won't bother. We wouldn't have it any other way, and our production full length headers tend to add 40 hp over stock. Once the prototype headers are made here at Vorshlag we will ship them to our production header supplier, where they will make fixtures based on our prototype set. Then they will make a production run of stainless steel headers using a CNC bender, making our kit headers both more cost effective and improving fit repeatability.
    And yes, for you California folks we have tested many sets of OEM exhaust manifolds and found one that fits, so this swap could feasibly meet 50 state emissions and pass the CARB referees, but we won't likely do one of those for a while. Our installs will all have our headers, and if its a street car we will add proper catalysts as well.
    Vorshlag production 1-3/4" x 3" full length stainless steel headers fit the E36 BMW chassis like a glove
    Everything else will be built in-house, like our production E36 and E46 motor mounts are now. We use CNC laser cut flanges, bolt them into our production fixtures, then TIG-weld everything together. Each welded part is testing on another fixture, then they are powder coated for long term durability and good looks.
    After the drivetrain mounts and headers are built there are still a dozen of other parts and sub-systems to tackle, but its nothing we haven't done many times before: Cooling system hoses, reservoirs, radiator and fans; intake air tubing, filters, and MAF sensor; electrical wiring to the engine, gauges, OBD-II port and CAN-BUS integration; driveshaft, shifter and transmission crossmember fabrication; fuel pump, lines, hoses and regulator, from the tank to the engine; and last would be the relocation of various components that were in the way of the V8. There could be more than that, but so far that is a valid list.
    What About the Weight???
    The number one question we get on every build is "how much weight will the V8 add?" Don't worry... we know Newton's Second Law of Motion: F = ma. We're going to really up the "a" with the LS engine and keep the "m" as low as possible.
    We here at Vorshlag are fanatics about weight, even when we are racing in our 3800 pound TT3 Mustang, heh. We weigh everything during a build like this, and we have already weighed lots of FT86 bits in the BRZ project build thread. You will see lots of pictures with various bits on one of our digital scales in this thread also. Why? Because the internet is full of poor data, numbers that turn out to be bogus, and people that are full of crap. We bring the tech, and when it comes to weights we show pictures of anything we reference on a proper scale.
    Here's an example of a race-prepped BMW 3 series with LS1 V8 power at 2508 pounds. That's with a full road race legal roll cage, too!
    Often times, as with our BMW LS1 swaps, the additional weight of the all-aluminum and compact LSx series of V8s is nil, and we only gain weight in the transmission (the T56 6-speed is a brute and weighs over 125 pounds). Our full street duty/full interior BMW swaps are usually within 20-40 pounds of the stock set-up. The iron block inline-6 engines used in E36 3 series BMWs is HEAVY and long, and the LS1 engine is a hair lighter and about 12 inches shorter, which moves the drivetrain mass rearward for better front:rear weight bias. We feel that the FR-S LSx is going to be much along the same lines, with more rearward weight bias and a gain of 40-50 pounds, at most. This isn't some wild guess, but based on dozens of previous swaps, and weights we've taken of these engines before.
    Remember the 480 pound measurement of the factory FA20 and 5-spd, shown above? Well a Tremec T56 Magnum XL is 128 pounds and a factory LS6 weighs 457 pounds, with a lighter than stock flywheel (which we always do - it doesn't need a 48 pound 2-piece factory flywheel, even for street use) plus the heavy OEM exhaust manifolds and a power steering pump. This 86 chassis has electric assist power steering built in the steering column, so we will remove the hydraulic power steering pump from the LSx engine we end up with, and our exhaust headers always save weight over OEM cast iron manifolds. After we do the math it looks like it is going to be pretty close to the stock weight, which is good. The weight of a turbocharger and intercooler from our before weight here is not insignificant, either. If we're wrong on that guess, we'll show it here, too. Look for the final weight of the FR-S once this V8 swap is done, which we will compare with the "before" weight.
    What's Next?
    That's enough for now. Tune in next time when we have the motor mounts completed and start to tackle the next bits like the driveshaft, headers, fuel system changes, and wiring. And yes, we have an OBD2 expert already on the case to make the GM computer talk to the factory FT86 computer, and our build here will have functional gauges and electric power steering.
    Please note: ANY NEWS about the swap kit, swap parts availability and pricing will be posted here AS SOON AS WE HAVE IT. Please don't call our over-taxed employees at Vorshlag or the folks at Texas Track Works to ask "when will the kits be released??" - we will post any news here first.
    Terry Fair @ Vorshlag Motorsports
    10 Jun 2014 09:18 AM
    Project Updates for June 9, 2014: It has been a hectic couple of months at Vorshlag since my last update. We were buried in early 2014 season preparations and parts sales for many of our customers as well as prepping and racing one of our cars (2011 Mustang in NASA TT3). We also have to pace our V8 swap kit development projects like this one (where Vorshlag writes off about 75% of the hours towards kit development) with paying customer service and race prep work - that pays the bills. I got a little busy myself as well, but after a nasty 150 mph crash I had at Road Atlanta a month ago, that side-lined me from racing for a bit, I'm getting caught up on a lot of project build posts like this one (and this, and that, and even this). During these past two months our shop has made some good headway on this FR-S V8 swap and the NB Miata LS1 Alpha project, which I'm writing an update for next. Let's go ahead and dive into where we are now on the FT86 V8 swap...
    Drivetrain Mounting in Kit Form is Tricky
    As I've said before, making a one-off V8 swap is relatively easy. Bring us a car, choose the drivetrain, and we can get it in there in a couple of months for a race car (we did just that for a customer in January-February, as well as full race prep, custom brakes, custom cage, all safety gear, and a full re-wire and re-plumb from front to back). One-off V8 swaps go much faster because you can cut things out of the way and just fabricate the best solution in the tie allotted. Making the custom motor and transmission mounts even for a one-off V8 swap is still relatively easy - its takes about a day and a half on something like this FR-S, once you have the drivetrain in the right spot.
    Left: Big ugly hole in firewall patched with aluminum, held in place temporarily by Clecos. Right: A big hole was filled with shiny new steel
    We could just stuff the drivetrain in there wherever we wanted; cut away the firewall or tunnel or whatever is in the way; measure everything to get the driveline angles perfected, leveled and centered; then cut a hole for the shifter. After that was done we would go back and plate over the holes with aluminum or even patch in sheet steel to make it look OEM, like we did on the firewall for this one-off Ford Coyote 5.0L V8 swap above last week. This was a one-off V8 swap that was brought to us to complete. To fill some holes in the firewall we used two methods: aluminum panels in the left picture and seamlessly integrated welded steel panels on the right, as shown above.
    Making these custom panels to cover up holes or other sins is common on a race car, and they can be done on a street car and look seamless and factory, but not easily in kit form. The pictures below were on a car that never had this particular transmission installed by the factory, and it didn't fit the trans tunnel. So part of the tunnel was cut away then a new cover was custom fabricated out of aluminum and bolted in place.
    With the finished transmission cover panel bolted in place (with captured "rivnuts" so you don't have to hold a nut on the back side) and later covered in thermal insulating material, it was no longer an unsafe gaping hole in the floorpan. This particular aluminum panel structure can be unbolted to access the tailshaft, add fluid to the shifter opening or replace/re-grease shifter mechanism. It also makes drivetrain removal even easier when removed, yet it is still heat and fireproof. On a street car this could all be under carpet and fully functional.
    But for an engine swap that we want others to be able to replicate in their garage using our parts, this type of significant tunnel or firewall surgery and custom fitted panels is not an option. You don't want to have to try to copy where we cut out this piece of sheet metal then make patches to fit, no no no. Yet there are some popular LS1 swaps out there that do expect you to strip your street car down to the bare tub, cut out the transmission tunnel or firewall and just "make it clear the engine where our mounts put it". Significant welding and custom fabrication work is not what we'd call a "do it yourself swap kit"
    Our BMW swap kits are made to bolt-in without any welding or fabrication needed, and that's how we're designing or FT86 LSx swap kit - as much as possible. To make a swap kit that is easily repeatable takes a LOT more work involved in the initial design. Our choices of drivetrain parts and locations are narrowed considerably when you cannot cut the tunnel or firewall out and replace pieces or entire sections with new bits. You have seen how many transmissions we've tested on this swap (4). We could have made any of them fit with enough custom fabrication work on the tunnel and firewall, but that's not a "production swap kit", that's a "one-off swap". And we are making a production kit here...
    The remote coolant reservoir above, which we make for our BMW E36 chassis LS1 swap, bolts into 3 factory threaded holes in the chassis. It has an integrated mount for the factory heater control valve, relocated from across the engine bay. It houses the factory BMW level sensor on the bottom side, which fits in a channel that happened to be there. The heater hoses clear the routing for our A/C lines. Making new parts fit with all of these constraints takes lots of extra time to plan for and build around. We have to make all of our swap kit components key off of and/or bolt into factory holes. This ensures everyone can locate the drivetrain or other bits we are changing in the same exact spots as we designed. We also go to great lengths to prevent the need for a welder, or cutting off of huge chunks of the chassis, firewall and transmission tunnel.
    This extra work required to make everything function as factory looking swap, with proper engineering principles, takes tons of extra time. Time we get to pay for, not the Alpha customers that work with us. They just have to be patient while we go to these extra lengths, on our dime, but our Alpha swap customers have all been great.
    The way we make the mounts also has to take into account production manufacturing techniques, like computer CNC Laser Cut portions of sheet or plate steel or aluminum. We even add things like holes, slots and tabs to key or bolt together during fabrication, using our custom production fixtures, to have make each motor mount or transmission crossmember to be as accurate to the original. And fit the chassis as well as as possible. Making a one-off set of mounts would be SO much easier.
    FR-S LSx Drivetrain Mounts Version 2.0
    The more we looked at the hood clearance, the less we liked the old LS3 intake and throttle body location. It was time for Ver 2.0
    We have already made one set of motor mounts for this swap, but after closer examination, I had the guys chunk them in the recycle bin and start over. We had left an extra 1/2 inch that we could move the engine rearward after removing one additional, bolted-on factory part off the firewall. That meant 20+ hours of measuring, mock-up, re-measuring, tweaking and fabrication were thrown away. Moving the engine back as far as possible without cutting the firewall is THAT important, especially when we could make a lot of these FR-S swap kits (we've officially surpassed 100 kits for the LS1 BMW E36 chassis now).
    Our crew here was cool with it, just more development hours. Once the engine was moved back to the final, optimum location Olof and Brad noticed one or two factory bits that were really in the way of a better mounting solution. Our new head fabricator Ryan H expressed his concerns over a couple of stamped sheet metal bits that he thought should be removed, so we had a meeting and after a few spot welds were cut, the remaining tunnel structure was much more favorable to the mounts we wanted to build.
    As you can see in two pictures I originally posted in my first update, shown again above, the Tremec Magnum XL was getting awfully close to one of the transmission tunnel support brackets. This is a U-shaped stamped sheet metal structure spot welded into the sheet metal tunnel that the OEM transmission mounting bracket supports were then spot welded to (see my original post describing the removal of those). After we moved the drivetrain back that crucial 1/2 inch this U-shaped piece interfered with the Magnum XL. Instead of having our customers just "clearance here" on this structure we decided to simply remove them. And in any case, after we had removed the two little brackets (post #1) this big U-shaped support was no longer needed (it was simply a place to mount other brackets to).
    With the U-shaped structure finally removed (about two dozen spot welds) the transmission tunnel had lots of room
    continued below
    10 Jun 2014 09:26 AM
    Our 2nd set of motor mounts and new drivetrain location required removing these 3 spot welded brackets
    Above you can see the U-shaped brace that was removed, as it no longer served any purpose and was just in the way. At right are two little funky, angled, bent steel pieces were barely attached to the steel front subframe welded assembly and after a couple of spot welds they were gone.
    Left: Our first set of mounts had weird bends. Right: After removing two stamped steel bits our motor mounts will fit a LOT better
    Removing these slotted black brackets removed a big angled protrusion from both spots on the subframe where we wanted to land our mounts. The first mounts we built had weird bends to try to go around the factory bits (above left), but now with a nice square section of crossmember to mount to (above right) the new lower portion of the motor mounts will sit flush against this vertical wall of steel - and still bolt into factory drilled holes. This makes our new LSx motor mounts (version 2.0) a little easier to make, but it will now have an additional hole to secure them to the subframe and sit more securely there. Removing these 2 brackets was super easy - 2 spot welds per side and they popped right off.
    Here is the U-shaped transmission tunnel structure that was interfering with the big Tremec Magnum XL 6-speed manual, so after some spot welds were cut it was removed. There were a decent number of spot welds, but it came off in about 30 minutes. See my quick write-up for Spot Weld Removal tips below - its fairly easy and takes no special skills, just a $5 spot weld cutter and a drill.
    Olof made the new Tremec Maxnum XL specific crossmember fabrication (above) that squeezed into the tunnel nicely. Two side plates will bolt to and key off of the chassis, then have 4 holes per side that are drilled into the transmission tunnel (see them bolted in place, two rows above). Then our new U-shaped transmission crossmember will bolt to those side plates, which have some bolt-together attachment points integrated into them. One of our Vorshlag bolt-through 95A polyurethane T56 mounting bushings will go between the transmission crossmember and the Tremec 6-speed.
    These brackets and mounts have since been finished welded, templates were made and reverse engineered from each piece, and CAD drawings produced for laser cut production runs of these mounts and crossmembers. I'm happy where the drivetrain ended up, as this gained us more room at the throttle body/hood and moved the weight back even more towards the rear.
    Here are the semi-finished prototype motor mounts and transmission crossmember pieces that we will use for the LSx V8 and Tremec Magnum XL. Unlike some shops that never show off their swap parts, we're showing the unfinished prototypes. I'm sure some of you arm chair engineers will want to comment, but remember: 1) these are prototype parts and 2) we have made 100+ V8 swap kits over the past 8 years and have had zero failures. We still have a few more gussets to add to the transmission crossmember mounting pad, then these welded parts will be painted, assembled with the correct poly bushings and hardware, and installed back in the car next week. They are light and strong, and we will road/track test them before going into production for anything.
    Cutting Spot Welds Is Easy
    This V8 swap kit installation is going to require a little bit more work than some of our swaps we developed in the past, but it is nothing insurmountable by any able bodied person with a drill. There are 5 factory stamped sheet metal pieces we have removed - three from the tunnel and two from the factory engine crossmember. These are attached with simple spot welds. It is unfortunate that we need these removed for the kit to work well, but it is worth it for a better engine placement.
    In this section I will show the process for removing two pieces of sheet metal parts that are spot welded together. I did an entire roof panel removal in my home garage, which had hundreds of spot welds, and it took less than half a day. These 5 pieces on the FR-S will take even less work.
    This "roof swap" wasn't much fun, but all of the hard work was in the welding. Removal of the old skin was easy
    Several years ago I owned a BMW 330 Coupe that had a sunroof and full interior, which I raced in an SCCA class (DSP) that didn't allow for gutting the interior or adding a sunroof delete panel (there are carbon fiber panels you can bolt or bond in place of the sunroof cassette). I couldn't sit in the car upright without my head in the roof panel, so I converted the BMW to the factory non-sunroof structure for more headroom. This conversion included a new roof skin, an addition of one more roof bow, and a new headliner. We started by removing the entire roof skin that was both bonded and spot welded to the surrounding structure in about 200 places around the perimeter. Some of these spot welds were hard to get to, as we had to remove the front and rear glass and all of the interior to even see them. But once we had access, we had the roof skin off in a couple of hours using a drill, a spot weld cutter and some elbow grease.
    Left: Typical spot weld cutting tool (small hole saw with a spring loaded centering pin). Right: Spring loaded center punch marks the spot
    A spot weld cutter is essential a tiny hole saw with a spring-loaded alignment pin. The goal is make a small dimple in the middle of the spot weld, align the pin in this dimple, then use the tool to cut around the spot weld. This releases the top layer of steel from the base layer. If you do it correctly only the outer layer has a (1/4" diameter) hole in it - and this is the layer we want to discard - while the base layer ends up with the little "bump" of extra weld material left. This bump is the weld and steel from the outer metal layer, which can be ground smooth or in this case, ignored.
    On the FR-S, we're just removing some things that are no longer needed to make room for the new transmission or engine mounts. Luckily we don't have to weld anything in place of these removed parts, or even grind the remaining bumps smooth (that's optional - and we did that for better aesthetics). These stamped steel parts are spot welded together without any bonding agent and come off with relative ease. Sure, the joints have a bit of seam sealer smeared over the edges, to prevent water from getting underneath them, but with a little coercion they still come right off once ALL of the spot welds are gone. The spot welds are easy to see - each one leaves a small round blemish in the outer layer of steel.
    The spot weld cutter is simply a tiny hole saw with a guide pin that aligns with the punched dimple you add in the center of the spot weld
    The FR-spot welds we were after are all easy to see and easy to access, with the drivetrain out. Only the outer layer of sheet steel needs to be cut with the spot weld cutter - the inner transmission tunnel metal should be left alone. Once the spot welds are gone from the outer section these stamped parts can be pulled off with your hands, but if you get a stubborn spot weld (or don't drill it from the center) a chisel or screw driver can be used to pry the metal apart.
    On this car there was a bonding agent in addition to the spot welds, so they had to be pried apart. On the FR-S the panels were only spot welded
    Rest assured, this step is not too difficult and you won't be welding things back onto the car once these bits are removed. Just be prepared to spend a few hours with a $5 spot weld cutter and a drill before our production motor mounts and transmission crossmember will have enough room to bolt into place. We will show more of this step after the kit is in production, with some videos.
    What's Next?
    Right now the FR-S is sitting with the drivetrain temporarily held in place (below) by an engine hanger while the prototype motor mounts and trans crossmember are being welded, painted and assembled. Then we can get the final engine in place and gather the parts needed for the engine accessories (Corvette LS2 or something compact like these). After the engine is fully assembled and the radiator is back in place we can finally begin prototype header construction, a custom 1-piece aluminum driveshaft can be measured and built, and a cold air inlet tube can be design and routed.
    In our next installment I'll show these steps listed above and detail the final motor being used for this car. It will likely be an LS1 5.7L with an LS2 intake manifold in this Alpha car, but since many folks doing this swap will opt for the "easy button" 430 hp 6.2L LS3 crate motor from GM (about $6500, with a warranty) and the includes LS3 intake manifold, we will make sure both LS2 and LS3 variants fit. While there are no external differences in any of the LSx V8 family of blocks/heads, these two intake manifolds (LS2 vs LS3) have small changes that we need to design around. The LS1/LS6 intake manifold are very different (and have a mechanical throttle body, which we don't want; this car has an electronic throttle pedal) and push the throttle body way too far forward, but we'll test and show that in the next build thread update.
    More soon!
    11 Jun 2014 09:24 AM
    What an education, thank you again and as always.
    11 Jun 2014 02:47 PM
    this is insane
    18 Dec 2014 12:50 PM
    Project Updates for Dec 17th, 2014: A lot has happened with this project - and at Vorshlag - since my last post in this thread. There should have been about 2 or 3 updates since then, but I'm horribly behind on updating project threads, so you guys get a BIG one today. Vorshlag has been busy with new shop construction, a move to a new space twice as large, adding fabrication equipment and CNC machines, going to SEMA/OUSCI, etc. Our service shop has been cranking out race car builds, custom suspension/chassis/aero/safety upgrades for various track cars as well as production work. I talk a little more about the shop move and SEMA in this recent Alpha Miata LS1 update (link).
    We are really pushing to complete this FR-S V8 project. Luckily we already have lot of initial parts development completed with this car Alpha build, and we should be able to produce our typical "Stage 0" kit sometime early in 2015. Stage 0 is usually - motor mounts, transmission crossmember, oil pan, headers, and driveshaft. We will also have the front drive accessories, most of the cooling system parts, and maybe a few other items completed and ready to go to production by Spring. We will then fine tune production solutions for "everything else" on the next "Beta" build - wiring, gauge integration, fuel system, etc.
    Drivetrain Mounting Solution
    Last time we checked in on this Alpha build we were wrapping up the transmission crossmember and attacking the motor mounts. We really made two sets of mounts, but somebody didn't follow my instructions and the first set was tossed straight into the trash. A second set was made properly and this pair + all of the pieces to the transmission crossmember were removed, finished welded, cleaned up and powder coated gloss black in early August.
    The transmission crossmember assembly is shown above, with the motor mounts next to these parts and all of the hardware needed shown. There are also two reinforcement plates on the inside of the tunnel that we will add, similar to what we did on the Alpha Miata V8. The final powder coated parts were installed onto the car after they were photographed in our little in-house photo studio.
    The motor mounts have the proven polyurethane bushing used in 100+ LS1 swaps built by Vorshlag since there was no reason to reinvent the wheel. The transmission mount busing is also something we've used many times, and we make this in both 95A durometer polyurethane or in a harder Nylon material for pure race cars. These design features have been used on both street and race applications and the polyurethane bushings damp engine vibrations well while keeping drivetrain movement to a minimum. The Vorshlag motor mounts (shown below) bolt into existing holes in the crossmember and have massive exhaust header room.
    These are near-production ready versions, with the major aspects and mounting points positioned right where we want them. This means the drivetrain is now set in the car where we designed it to be - after many iterations, measurements, and discussions - so the shifter location, drive line angles, fore-aft placement, left-right and up-down positioning are all locked down. We have scanned these final prototype bits and from that data we have made CAD designs with about 3 revisions in SolidWorks. The production versions of these parts will be made from CNC laser cut plate pieces that will be altered ever so slightly for repeatable volume production. We will make production welding fixtures during the Beta build.
    With the drivetrain locations set we could move to the next big phase of this swap - construction of the exhaust headers.
    Long Tube Header Development
    This is a huge step, and usually the biggest challenge for home-built engine swaps, but it is something we have done many times. The prototype FR-S swap headers were completed a couple of months ago. Let's go back look at the process so than I can explain how we go about making one-off and production exhaust headers in a cost effective way, with zero compromises to the fit, performance or quality.
    We have a certain set of rather expensive header development tools we use on these engine swaps that allows us to make multiple primary tube routings very quickly, which cuts down on development time and leads to a better final layout. The prototype process still took over 50 hours for this first pair of headers, even with an experienced fabricator and all of the trick tools.
    First we acquired 304 Stainless Steel exhaust port flanges and 3" merge collectors, then a big box of stainless mandrel bends in 1.75" diameter. We used our production header supplier to source these parts, so they would match the production CNC bender's sizing for this sized primary tube. The flanges were bolted to the cylinder heads and the collectors were placed where they were appropriate. These were locked down in place with temporary brackets tack welded to the collectors and bolted to the chassis, with proper ground clearance as well as the best primary tube length distances.
    Next, four primary tubes at a time were laid out up in the plastic mock-up tooling and many iterations of these tubes were tested until the best routing and packaging were made with the least number and severity of bends. This takes many hours and a lot of clicking and unclicking of these orange plastic bits - but its kind of fun seeing it all come together. Eventually the most logical routing is decided on and that process is complete.
    The hardest side to do is always the driver's - to route around the steering shaft, which always seems to be right in the way. As the final four tubes are completed in plastic, each one is turned into stainless steel tubes and mandrel bends, tack welded (or taped) together, perfectly matching the plastic mock-up tubes in length, diameter, bend radius, and angle of cut.
    While it looks like we work from the top down, its really the collector that dictates a lot of the constraints, and that's where the focus usually lies - and around the steering shaft. The wide engine bay of the FT86 gives us liberal room to make nice, straight runs out of the exhaust port before turning, which we almost never get to do on most swaps. This should mean we will see at least the typical power gains over LSx exhaust manifolds that we usually get with our V8 swap headers.
    The passenger side went much more quickly since nothing was in the way. We did round up an air conditioning compressor and bracket first, to make sure the primary tube routing up front was clear, but that proved to not be much of an issue with the final accessory drive set-up we chose (see more below). We also had sourced a new LSx starter and mounted it to the mock-up engine, as the passenger side set of tubes needed to route around that with as much room as possible - to avoid heat soaking the attached starter solenoid.
    Once routing aspects were perfected, each tube was tack welded at each junction, then removed and fully seam welded at each joint. These 8 completed prototype primary tubes were then tack welded to the exhaust flanges and merge collectors. Again, this entire process took over a week of solid work (53.5 hours, to be exact). Some of the extra time comes from trying to make these reproducible - knowing the distance between bends that the CNC bender's clamps can make - but even one-off headers usually take 40-50 hours to make for a V8.
    The final layout we ended up with follows the contours of the chassis, which dictates a lot of the shape of the final product, but it also uses good fabrication, the best materials, and proper header design to maximize power gains. Our previous LS1 swap headers have proven to pick up 40-50 wheel horsepower over stock manifolds or worse, the block hugger shorty header designs some folks use on these swaps - because making one off custom headers that flow well is so difficult.
    Although we could have sent the headers off with the tubes just tack welded together at the many junctions, Olof seam welded each tube. Why? To be able to get this car back on the road quicker than normal for a typical Alpha swap development timeframe of 12-18 months. Once these prototype tubes return we will finish weld them and get this set ready to go into this car. The customer met with us today and wants his set ceramic coated, so we'll have that process added to his set as well.
    Our crew carefully packaged and shipped the final prototype FRS LSx headers (above) to our US header manufacturer, who then made a production fixture from that set, then blew apart each assembly into individual tubes. They then measured and modeled each tube and replicated all eight in CNC bent tubes, then they put together a pre-production header assembly and sent it to us for testing. The passenger side fit perfectly on the first try but we just received and tested the 2nd production iteration for the driver's side and it is almost perfect. We just have a few small interferences to work out around the steering shaft.
    continued below
    18 Dec 2014 12:51 PM
    Real Engine Install + Clutch/PP/Flywheel
    Check out how wide the OEM 2.0L engine above looks in the engine bay compared to the 5.7L V8 shown below
    While the headers were being manufactured and test sets sent to us for trial fitting (a 2-3 month process) we used that time to tackle other aspects of this swap.
    Mock-up motor was removed and the rebuilt 5.7L aluminum LS1 was put in place
    First we wanted to get the final LS1 engine into this car. The final engine choice was chosen by the customer from several choices we offered, from 5.3L aluminum longblocks to 6.2L LS3 crate engine, and included a rebuilt 5.7L LS1 engine from HK Racing Engines that we had on hand for another project. They chose the all aluminum 5.7L, so out came the mock-up motor (which was spending time jumping between the FRS and Miata) and in went the rebuilt 5.7L V8. This 5.7L is all aluminum and should make for great acceleration levels in this 2650-ish pound package.
    We just put an identical 5.7L LS1 set-up with our swap headers and full exhaust/catalysts into a customer's turn-key BMW (see above) and it made 344 whp / 364 wtq on pump gas. This is a stone stock 5.7 LS1 engine, built to last 100K miles under a factory warranty, and is not stressed in this 3000 pound BMW. Drives like a beast, but idles at 600 rpm and is quiet as a mouse. We built that car with a double muffler set-up to keep it super quiet, too. An LS3 engine tends to make an extra 50-60 whp over that even in stock form, and there are dozens of tricks to pump up the power beyond stock levels in any LSx. The 340+ whp number this motor will likely achieve in the FR-S is slightly more than the customer wanted, but its hard to make less than that without going to a smaller 4.8L or 5.3L engine.
    After consulting with our supplier, then talking with Texas Track Works and the end customer, we sourced an aluminum flywheel and clutch kit for this car. The flywheel is a Fidanza aluminum 1-piece design, which is substantially lighter than the stock dual-mass steel unit at only 12 pounds. I have used these in countless LSx powered vehicles, both street and race cars, and there are no adverse side effects to performance - just the potential for a little more NVH transferred to the cabin. The OEM dual mass flywheels are HEAVY but they do damp a little transmission noise. Its worth nearly 30 pounds and it makes the motor much more responsive, so for most folks this upgrade is a no-brainer. On a track use car it is pretty much a requirement.
    A new pilot bearing was installed in the end of the crank then the flywheel was installed to the crank flange with new ARP bolts. The chosen Stage 1 SPEC clutch and pressure plate were aligned to the crank and installed and torque with ARP bolts as well. This should easily handle the torque of this engine while giving a light clutch effort. All of the bolts torqued were paint marked to remind us that they are done, of course.
    A variation of our popular and proven Vorshlag T56 Hyd. ThrowOutBearing Kit with remote bleeder was built to fit the FR-S and installed behind the pressure plate and onto the input shaft of the Tremec T56 Magnum XL, first (see below, left). This kit is based around a new hydraulic TOB but the stock hydraulic line bits are replaced with new stainless braided hydraulic lines and new quick-connects made by one of our suppliers to our specs. The OEM quick-connect is a non-standard size, so getting the mating piece for the chassis side isn't possible without buying an OEM piece from GM and scavenging the connector. We also added a remote bleeder hose and bleeder for this car, to make bleeding the clutch hydraulics a breeze within the tight confines of the FR-S tunnel. We have built many of these kits for our BMW swaps, so that was easy for us to create here.
    We also took a picture while the transmission was out of the slight tweak that has to happen to the T56 Magnum XL to fit the tunnel without using a hammer. There are two small aluminum "prongs" that need to be ground down (shown above right). There is an excess protrusion on both of these that is made to protect the nearby sensor , but trimming these down flush still keeps the sensor safe from getting banged up during installation and makes room for the FR-S tunnel. The picture above at right shows the lower two of these four protrusions, and the only ones close are the top pair. Just trim those down level with the sensor and you won't have to dimple the transmission tunnel.
    Oil Pan + Baffle Kit
    The final piece of the drivetrain tackled in this step was the oil pan and associated bits. The GTO (front sump) oil pan we are using for this swap is different than almost all other LSx (rear sump) oil pans, both from the factory or the aftermarket. I showed this before, but not with any real details.
    The unusual placement of the front crossmember and "rear steer" placement of the steering rack on the FT86 chassis requires the use of this front sump pan, which is obvious when you see the image above. A more typical rear sump LSx oil pan would never work here. Initially we had notched two little webs at the back of the pan for clearance. After the 1st set of motor mounts were rejected, I had our guys push the engine back another full inch and make the new mounts, to perfect the shifter location as well as try to improve the front to rear weight balance. Now an unmodified GTO oil pan will fit this swap with our production mounts.
    We are occasionally asked if our swap parts will work with parts from other companies, or homemade parts. For the most part, the answer is "no". The parts we make are all made to work together, and the tolerances for the whole drivetrain and header package can be pretty tight. The headers fit only if the drivetrain is in the exact placement we use, which our motor mounts and transmission crossmember locate. Most shops that buy our kits buy everything we make, even when they know they could replicate some of the pieces on their own. Why? Because they know that time is money, and the hundreds of hours of development time we invest during these new swaps saves them from having to churn through the same hours to make the same things. Just something to consider - we will sell the various swap pieces individually, of course.
    We learned that an oil pan "trap door" style drop-in baffle kit is a good idea on this LS1 V8 BMW
    Since I've seen first hand that high cornering loads can lead to oil starvation, I always recommend an Improved Racing oil pan baffle kit for any LSx engine that will see autocross, road course, or aggressive "corner carving" use.
    We've had excellent results with these on high horsepower road course builds, and it didn't take much convincing with the Texas Track Works crew to sign off on this upgrade. The GTO oil pan version was installed into the pan we had already acquired and that was the last piece that went onto the rebuilt 5.7L motor before it went in the car.
    Using the proper bellhousing to engine bolts, the drivetrain was finally fully assembled for the last time. Olof and Ryan slid it back into the car and bolted it up to the motor mounts and transmission crossmember. That was one of the last steps completed at our old shop - the car was trailered to our new shop in October and we got back to work a few weeks later (moving sucks).
    Front Drive Accessories
    Once the LS1 was in the car it was time to dress the front of the motor with the engine driven accessories. When you buy a used engine it rarely comes with the accessories and brackets, and even on the rare occasions it does they are almost never the right parts for your application. Most of the new LSx "crate motors" come without the front drive bits as well - so sourcing new brackets and accessories like the alternator and water pump for a V8 swap is common. The costs can really sneak up on you, too.
    Between the various GEN III and GEN IV LS-series engines (displacements from 4.8L to 7.0, with both iron and aluminum blocks) there are dozens of different front accessory drive layouts. Some are wide, some are tall, some poke out in front of the engine, and some are compact. Luckily we've worked with virtually all of the cars and trucks that ever came with an LSx V8 and we know what works best in different swaps.
    1998-02 "4th gen F-body" (Camaro/Firebird) LS1 engine accessory drive layout is compact and narrow
    Traditionally we have used the 1998-2002 Camaro/Firebird LS1 engine accessory drive layout (see above), but some of the brackets are getting harder to source new or used (GM has stopped making one of the brackets) and the pulleys are longer front to back than would fit in this FR-S (about an inch longer than what we chose). They work great in just about any BMW, which comes with a long inline six engine and deep engine bays, but not so on the FR-S. For the longest time this was the only choice for a lot of swaps that had narrow engine bays, but in the past decade many other LS engine accessory variations have popped up, and the FT86's short engine bay pushed us in another direction.
    Choosing the right accessories may seem trivial but actually ate up of dozens of hours in research, parts ordering, testing different configurations, chasing down the bolt/stud/nut hardware, machining custom parts and even finding the right length belts. Since we found the right set-up - and its a bit unusual - we will make a "kit" for the FR-S/BRZ LSx swap that includes the alternator, balancer, and water pump, plus all of the necessary brackets, bolts, studs, nuts, pulleys, tensioners, spacers, and other parts needed.
    An optional second kit will have all of the parts needed to mount an air conditioning compressor - the compressor, bracket, belts, idlers and bolts. The A/C runs on a separate belt on LS-series engines, so that can be added later without affecting the main serpentine belt routing. We chose a short front-to-back OEM set of LS-engine brackets and accessories for this build because the engine bay was tight in that dimension - this car was was only made to house the small (front-to-back) boxer 4 engine that is only 2 cylinders deep. The width in this engine bay, however, is immense so there was no problem there. The height to the hood is tight, so that was a consideration in our decision as well.
    The tricky bit was making an arrangement that could work without a power steering pump, since the FR-S has electric power assist steering (EPAS) built into the factory steering column (other EPAS systems are electric assisted down in the rack and pinion). We have that "no power steering pump" option straightened out with some extra pulleys, some custom machined bits, and a new belt routing that should work great (after half a dozen belts were tested). We've seen this done elsewhere but it took a bit of legwork to track it all down and make the parts needed for this car. We picked up an SFI balancer form our engine builder along with a massive ARP 12-point crank bolt, which is reusable (unlike the OEM LS engine "torque to yield" bolt, which is a one-use bolt). There is no keyway on the crank, and this is a "neutral end balance" crank and balancer, so you can put the balancer on oriented however you like (there's not even a need for a timing light reference mark - that's all done automatically in the computer). The keyway is cut into the balancer anyway, in case you have a belt driven supercharger where you would add the slot and a pin or key to the crank so keep it locked to the balancer. Not needed in this case.
    continued below
    continued from above
    Cooling Solution
    While we could have just left the stock radiaor in place, we knew that was a bad idea so we sourced a Mishimoto radiator early in this project. We had already test fit the Mishimoto radiator in place earlier, but now that needed it to be bolted down so some radiator hoses could to be built. We also needed to alter some other factory cooling systems parts to gain clearance for this big V8 up front.
    The change in power level from the stock 2.0L engine to this 5.7L engine would be substantial, and unlike on some of the the BMW LS1 swaps we have used, I doubt the Toyota/Subaru engineers added a LOT of extra cooling capacity to the stock radiator. It was also a plastic/aluminum assembly, which, in our experience, fails quickly with track use.
    We use Mishimoto radiators on a lot of OEM powered and V8 swap builds for street and track use, including our TT3 prepped 2011 Mustang. They are 100% TIG welded, all aluminum radiators (avoiding the cheaper, failure prone, OEM style bonded plastic tank ends) with usually at least double the stock fluid capacity (with thicker cores). This means it can help the big V8 engine run cooler, which is always a safe choice for track use here in Texas. We can see 100°F or more in the Summer, and Texas racers want to run on our many road courses year round, so we have to make our cooling systems capable of this heat. Additionally this car's owner wanted air conditioning to get him to and from the track, so we have to make provisions for a the factory A/C condenser - which luckily bolts right to the front of the Mishimoto radiator using the same OEM hardware (above right).
    The Mishimoto looked like it had all sorts of room until you consider where the balancer would end up. The factory double fans also work in a "puller" configuration, so they sit behind the radiator (whereas a pusher style sits in front). And the two factory fans, mounted in a plastic shroud, were VERY DEEP (about 5"). Running right between the two side-by-side fans was a stamped steel brace that bowed inboard and bolted between the upper and lower radiator support structures (shown sitting on top of the motor in the above right pic). No way would the fans or this stamped piece fit with the V8.
    So we came up with a "compact" fan solution using "slim line" electric fans. They will move PLENTY of air but we wanted a nice shroud to mount them to, to ensure that the fans draw through the entire surface of the radiator. Olof built the aluminum fan shroud above to fit to this radiator with the 12" Mishimoto fans.
    A piece of aluminum plate was measured, marked, sheered, cut, bent, drilled and welded to make a shroud that stood about 1/2" off the back face of the radiator - with a foam rubber gasket isolating this metal structure from the aluminum radiator. The tabs we added are bolted to the OEM radiator mounting holes for the factory shroud, and the end result was pretty much perfect - and about 3" inches shorter, front to back. This set-up now allows room for the front engine balancer.
    The stamped steel brace was removed but our guys will fabricate another bolt-on brace that doesn't "bow" into the way of the pulley - there's plenty of room, it just needs to be a different shape. The upper radiator support is VERY weak without this top-to-bottom support installed, and it needs to be strong because the hood latch mounts up there. As you can see in the above picture the full front accessory drive layout is complete, with the balancer and serpentine belt in place, and there's room to spare. I've also shown one of the two main radiator hoses mocked-up using Mishimoto silicone bends and some aluminum tube - we've used this arrangement many times.
    These two 12" Mishimoto electric fans pull 1150 CFM each and will be controlled by the GM engine computer, based off of the GM temperature sensor that is placed in a cylinder head.
    What's Next?
    We've been getting a lot done to our two current Alpha swaps, the Miata and FR-S, and some solutions figured out on one car have helped us on the other. We are trying to keep both of these going in between "day work" and other non-development builds.
    The FR-S needs a driveshaft, after-header exhaust, some plumbing and wiring, then the CAN-BUS programming. Its getting there...
    Until next time!
    Terry Fair - www.vorshlag.com
    03 Jul 2015 11:37 AM
    Project Updates for July 3rd, 2015: Once again a lot has happened with this V8 swap project - and here at Vorshlag - since my last post in this build thread (Dec 2014). Some of you that follow Vorshlag on Facebook or our Blog know that we've purchased CNC machines and are now making all of our machined suspension products in-house, which was a big investment and a steep learning curve.
    A new CNC machining operation, new fabrication tools, and new projects have kept us hopping at Vorshlag
    We've finished a number of big customer car projects and taken on a couple more. The two current "Alpha" V8 swap projects (Miata and FR-S) both have had a lot of work done, especially the FR-S. Just this week I took the little Scion on the first test drive with V8 power, so I figured this project was long overdue for a forum update. The customer (Rick) has been incredibly patient, and over the winter we changed the shop-to-shop arrangement (with TTW's blessing) to speed up communications, by working directly with him.
    It runs! It drives! It shreds tires! And yes, its almost ready for kit production!
    It has been a busy six months, but after the test drive - which was a major milestone - it was an obvious time it was long past time to talk about the progress publicly. No, its not 100% ready, and the kit production has not started, but it is close and drives, and the car will be at Cars & Coffee Dallas this weekend (July 4th, 2015) if you want to stop by for a look. Let's get caught up!
    Massive Delay Waiting For Production Headers
    We finished the prototype headers in August of 2014, but we do not have a $250,000 CNC tubing bender in-house, which is needed to make production quality header primary tubes, to keep the cost of the headers down. So we have always relied on an outside vendor here in the USA to make our production LS swap headers from our prototypes. We have worked with 3 different header companies over the years and each one has been a struggle to go from Prototype headers we make in-house (below left) to Production headers we can order in batches, that fit as well as our prototypes (below right).
    In the past it has been a 3-4 month/1-2 iteration process where we send them our prototypes, they make a fixture, cut apart the headers and measure each tube, turn each primary into a CNC bent tube, then assemble the CNC bent primaries into a header assembly and send it to us to test. And back for re-fitting, and back for testing again. It doesn't sound difficult, but this time it was a NINE MONTH delay. I cannot explain that, and this ran the development way past my predictions, but we finally got a production header that matched our prototypes in April (3 months ago). A lot has happened since then to make this a running and driving car, but I am never waiting that long for a production header again.
    Cooling System Mods
    While we waited on the seemingly endless production header delay we worked on other systems, like the cooling hoses, tank and lines. We left off before with a Mishimoto FR-S radiator, dual fans and a shroud installed, with radiator hoses being built. In hind sight it might have been easier to modify the inlet and outlets on the Mishimoto radiator, to better match the layout of a typical LS series engine, but we left it all stock and just made the hoses longer to match up to the radiator.
    We tried several sources to have custom hoses made but we have to order about 500 sets to get the prices to work, which is nuts. For the first set of radiator hoses (and likely production sets) we used some silicone hose bends, aluminum tubing, and some fabrication to make hoses that fit this swap.
    There is also a specific "straight" thermostat housing we used, to facilitate this hose layout. Yes, they are long-ish hoses but it doesn't hurt the performance of the cooling system and still left plenty of room for the Cold Air tubing to feed the throttle body (see below). Next up, we worked on the heater hoses and coolant reservoir...
    We started with a pre-made coolant tank but modified it heavily. This FR-S already had the battery moved to the trunk so the OEM battery location ended up being the perfect spot for the new coolant reservoir and GM engine control module (ECM), or computer.
    For a variety of reasons we picked up a 2005 Corvette LS2 computer. Its the only year that works with a 24 tooth LS1 crank trigger yet can control an LS2 style throttle body, drive-by-wire pedal, and LS2 intake manifold. We needed the LS2 bits to clear the hood, and the LS2 intake manifold also matches the cathedral port shape of the LS1 cylinder head. The engine the customer chose is a mild 5.7L aluminum LS1 engine from a 2002 Camaro SS (rated at 320 hp in stock form), unlike the "LS3" we had original envisioned.
    I bring up all of that engine/computer stuff because "everything depends on everything else". Picking the specific Corvette computer was necessary at this step because we wanted to mount the coolant reservoir and ECM on the same bracket, which Ryan made and added to the car.
    The dual mount arrangement can be seen above and makes for a good location for the ECM (which is usually inside the engine bay) and the reservoir (as high up as possible, which helps self-bleed air from the cooling system).
    Once the threaded aluminum bungs were welded to the tank, fittings were added and rubber heater hoses were routed from the water pump to the heater core, with one leg passing through the coolant reservoir. That is complete and leak free.
    Fuel System and Lines
    So this car had already been modified before it got to us. It had several turbo motors built by one shop, and they really butchered the fuel system in the car, so we had to rebuild new hard lines to make a fuel system work.
    The factory body clamps were still in place to we built stainless hard lines for the supply and return lines that clipped in like stock. The ends had welded AN fittings added so that -6 AN lines could attach directly (typical 37-degree flared ends).
    We picked a Holley return-style regulator and Ryan built a bracket to mount it to the driver's side strut tower, then ran braided -6 lines from the two hard lines up to the regulator (feed and return). The return line and vacuum lines for the regulator are not shown in the images above. From the regulator a -6 pressure line was plumbed to the Holley EFI fuel rail kit. We could have re-used an LS2 OEM fuel rail, but that requires some ugly adapters and this billet fuel rail kit was a great price, was set-up for -6 AN fittings and came with fittings, and the final setup looked really good. With the black fittings and black braided lines it made for a tidy package that will flow more than enough fuel for this powerplant.
    The in-tank fuel pump setup on this car was already modified, but for E85 fuel, so the tank was removed and pressure washed to get all of the old funky alcohol out of it. The pumps were flushed and one of the two was re-used to feed this motor with 93 octane Gasoline.
    continued below
    03 Jul 2015 11:38 AM
    Intake / Throttle Body / Pedal
    Early on in the build, when the motor was not yet selected, we had picked up a brand new LS3 intake manifold, sensors, TB, fuel rails and injectors. These are actually still cost effective to buy new because the LS3 was still being built on a production line. We picked up one of these LS3 packages and used it in initial testing and mockup (see below).
    The same "LS2" version of this "complete intake package" was no longer available, so we had to piecemeal these parts together, which was time consuming and more costly. As I showed above, we skipped the OEM fuel rail from an LS2 and went with the Holley bits (almost the same cost). But why was the LS2 intake needed? The images below explain some of the reasons.
    First of all, the project switched from what I had hoped would be an easy to work with 6.3L LS3 engine to a less costly/less powerful and in this case, more difficult to swap 5.7L LS1 engine. The LS1 has the tall "cathedral" ports whereas the higher flowing LS3 heads are rectangular port. So we could no longer use the LS3 intake, and had to go with an LS1, LS6 or LS2 intake.
    Of those 3 "cathedral port" intake options, the LS2 intake manifold has the shortest "throttle body neck" and uses the largest diameter throttle body, which itself was shorter than the LS1 or LS6 cable operated throttle bodies (some LS6 cars also had drive-by-wire TBs). The combined length of the LS2 intake + LS2 TB allows the throttle body fit under the FR-S hood with no trimming, unlike the LS1 or LS6 options (which we tested and didn't fit). GM has gone up, up, up in throttle body opening diameter over time and power seems to keep going up as well. So we built the car around the drive-by-wire LS2 throttle body, pedal and computer from a 2005 Corvette (again, this computer will work with the earlier 24-Tooth crank trigger and the DBW throttle). This should add some power over the LS1/6 intakes.
    The electronically controlled LS2 throttle body looks very similar to the LS3 TB, but they are not interchangeable. Identification is easy as the LS2 has a silver throttle blade whereas the LS3 has a gold blade. The connectors and controls are completely different.
    Once the intake manifold and TB were installed Ryan could build the cold air box for the air filter. This uses OEM attachment holes on the driver's front corner of the engine bay, and brings in air from behind the light and underneath. It holds a big K&N cone style filter in a heat shielding box that seals to the hood, to block the filter from hot underhood air aft of the radiator.
    Aluminum sheet was cut and bent from cardboard templates and bent up in our sheet metal brake to make the box. A hole was cut and the 2005 Corvette MAF assembly was mounted on the outside with the K&N on the inside of the box. The upper edge of this box that meets the hood was trimmed to fit the underside profile of the OEM hood.
    A rubber seal was added to the upper edge to seal the box to the hood and all of the various silicone bends were clamped. There was some aluminum tubing and bends used to change diameters from the LS2 TB to the LS2 MAF, and to make the routing fit the car. Its all wrapped up in the top right picture.
    Electrical and Wiring Harness Integration
    The throttle pedal we used needed to match the TB and computer, so we went with 2005 Corvette again. Instead of trying to make the OEM Scion pedal talk to the GM computer, we just replaced the assembly with the Corvette bits and modified the OEM Scion pedal to work in place of the Corvette pedal.
    There are a variety of ignition coils, brackets, sub-harnesses, and wiring connectors for the main engine harness. We picked the style of coil and bracket we wanted, and had the harness built to match these components. We mounted all of that with metric button head stainless hardware, which looks better than the OEM hardware. The engine wiring harness was built to our specs with the correct computer connection, coil pack sub-harness connection, the wired pedal, a sub-power circuit, A/C controls, and fan controls. The placement of the computer, pedal and fan relays were all spec'd and it was delivered in a few weeks.
    This company has made most of our LS swap harnesses for years and they rock. The ends are all clearly labeled, every connector, pin and wire is new, and the colors match the OEM GM harness layouts and pinouts.
    Integrating the harness to the chassis wiring took a few days. This part is the least fun part of any swap, but we ordered the engine harness correctly (which takes some experience with wiring and LS components and a little pre-planning to do) and have technicians here that excel at automotive wiring. Ryan got this one wired up, tied into the chassis harness, and all of the plugs for the pedal, TB, coils and everything were spot on.
    There are all sorts of other electrical work we had to do to make the starter and charging systems work and integrate with the OEM key, but its all fairly straightforward. Ryan bent up the black bracket and mounted it to the strut tower for the auxiliary fuse block that comes with this engine harness, and mounted the OBD2 connector under the dash.
    Exhaust and Driveshaft
    You need a driveshaft in place to make the after-header exhaust, but our custom ordered driveshaft took much longer than expected so we mocked up a 4" piece of PVC pipe in place to build the exhaust around temporarily.
    The stainless O2 bungs were welded into the collectors and our 3" V-band clamp flanges went on the collector ends. Then a pair of 3" ID Magnaflow stainless catalysts were added and 3" 304SS mandrel bent tubing was used to merge these two pipes into one.
    This FR-S already had a 2.5" inlet/dual outlet stainless Magnaflow exhaust system, and after searching we figured out this was still the best muffler and tailpipe layout for this car, so it was kept. But the 2.5" inlet tube on the muffler was cut off and a 3" inlet tube welded in place, for more flow.
    The fuel tank and rear subframes both has a big indention for SINGLE exhaust tube routing, so we kept it simple and made a dual 3" into a single 3" pipe, ran it back to the 3" inlet muffler with the dual outlet tips to match the OEM rear bumper.
    The entire system is 304SS now and should last for many decades. It has excellent ground clearance, a subdued sound at idle, but sounds great when you rev the V8 up, too.
    The driveshaft took a while to be built, and we had to send multiple engineering drawings to make the rear driveshaft flange mate up to the Scion R180 rear axle flange, but when it arrived it looked great. Its a big 12.9 pound one-piece aluminum unit with beefy U-joints and a slip yoke at the front to match up to the Magnum XL.
    Headers, Delays, and More Delays
    I'm not going to get into all the "jiggery pokery" we had to go through, and additional re-work we did at Vorshlag to get the production headers to fit and have them reproduced correctly, but it was easily 100 extra hours of work beyond the 56 hours it took to fabricate and fully weld the prototype headers that are typically destroyed during when measuring for CNC bending.
    Both headers were not here and correct until into April of 2015. Once they were installed, it took a little extra work to make a functional dip-stick with the GTO pan and G8 accessories, but we developed a functional and reproducible solution for that as well.
    The exhaust and driveshaft development were very frustrating and we got to eat hundreds of hours of development work on this build, so we HAVE to make a kit for this swap to recoup our losses. Look for more info about production dates for all of these bits soon.
    Programming, Bug Chasing, and First Fire
    Click the image above for one of our videos of starting and revving the engine
    There were other setbacks and delays along the way, of course. This project was a bit of a monster, but the first ones are never easy.
    Sean from True Street came to our shop for a "house call" to turn off the VATS (GM key security) in the first ECM, then back again to diagnose a communications problem from the LS2 ECM to the Pedal to the TB.
    After a lot of testing, probing, looking at wiring schematics, and laptop communications with the ECM... it turned out to be a bad GM ECM. Ugh, what are the chances?? Sean had to come back a third time to reprogram the new ECM when it arrived, where he and Ryan tested a bunch of systems and got it ready for the test drive.
    continued below
    03 Jul 2015 11:40 AM
    Shifter, Clutch Master, and Test Drive
    The Magnum XL transmission was purchased new, and converted to GM input shaft format. It came with a shifter base but no shift handle, which is normal.
    It is made to have two positions for the base shifter unit and there are aftermarket shifters made for this style shifter with all sorts of offsets and adjustments, but this transmission fit the OEM shifter opening in the FR-S perfectly. A straight shift handle would work, no offset or weirdness needed. THIS is why we ordered the T56 Magnum XL - it was the right length for this engine and chassis application. Sure, a remote shifter extension like this might work with a regular T56, but that would add complexity and cost.
    We ordered a shift handle and knob that we thought would work, but it wasn't the right mounting bolt pattern at the bottom, and I was tired of waiting and delays - so I had Olof make the steel shift lever assembly above. We put this in place under the fire-proof racing style shift boot we use on almost all swaps, which goes under the leather OEM shift boot. I whittled a shift knob out of Delrin on the lathe and Brad got the lever painted and the knob polished (hehe) and bolted it to the included Magnum XL shifter, shown below.
    This is hardly a "production solution" and there are likely dozens or more off-the-shelf shift handles and hundreds of knobs that can be used with this shifter base, but this got us on the road this week. This "prototype" shift handle and knob length functioned perfectly on my test drive earlier this week, as I like the shift knob close to the steering wheel. This way I can keep my hands on the wheel when driving, pop over and make the shift, and get my hand back to the wheel quickly. When Rick drives the car he might want the shifter/knob positioned lower, in which case we can shorten the shift knob, which I made long for this purpose.
    On our many previous LS swaps utilizing a T56 transmission, we have used a hydraulic Throw Out Bearing / Clutch slave assembly that we make (above left) with a long remote bleeder and a quick release line so the transmission can be removed easily. That TOB/slave assembly goes onto the input shaft and has the right stroke to move the pressure plate enough to disengage a typical single plate T56 clutch, like the Spec Stage 2 we used on this project. The OEM clutch Master Cylinders (above right) on BMWs always hace enough stroke to move this TOB. This was how we tried it initially on the FR-S, but it didn't work. The clutch wouldn't disengage.
    No problem, we know what MC bore size the BMW swaps use, so we ordered up an aftermarket Tilton clutch MC set-up in this same bore diameter, part of a complete kit with several reservoir options. Above is the final solution, completed yesterday.
    Of course that takes some work to fit the Scion chassis, so a custom adapter plate (above left) was machined from billet aluminum, shown above left. This has two sets of holes - one pair of thru-holes that match the FR-S firewall using the OEM bolts, and another pair of threaded holes for studs that fit the Tilton bolt spacing/rotation. A custom length Clutch MC pushrod (above right) was machined, which actuates the Tilton from the OEM pedal. This rod threads onto the FR-S factory clutch pedal fork, which attaches to the OEM clutch pedal like normal.
    Our hose and fitting specialist stopped by this week and made a new upper braided hose (from the quick-connect up) to attach to the Tilton MC, which comes out the front. It was a little close to the valve cover but with a banjo-style end fitting and copper washer it all fit. This combination of parts we bought or built makes for a 100% bolt-in solution and looks great. Well... other than the bore of the first Clutch MC we initially bought. I test drove the car (below) and it was only disengaging the clutch with the pedal right off the floor, which made it clumsy to drive and slow shifts.
    Video of the first test drive around the block, which turned into a tire torture test!
    So the next day we went up 1/8" in bore size with a new Tilton MC, mounted it in place of the first Tilton MC, re-bled the clutch system, and now it drives perfect. The clutch releases about halfway through the pedal travel and feels natural. Sometimes all of the engineering calculations just don't fit (in this case it was an unusual clutch pedal arm ratio) and you might have a bit of trial-and-error to get to the right solution. We will make the Hydraulic TOB/bleeder/hose assembly + final Clutch MC/mount/pushrod assembly into a product we can sell with this kit, of course.
    The test drive was short but a LOT OF FUN! Low weight, big torque, RWD and street tires = TOTAL HOONAGE. I couldn't stop giggling and laughing on the brief test drive. And yes, the owner was cool with seeing some wheelspin, as I'm sure he's going to do the same thing. I just wanted to make sure it could handle it. Success!
    What Does It Weigh?
    This is the question we get asked the most, and I want to back up and show some data from a stock BRZ (nearly identical to the FR-S) that we weighed when these cars first came out.
    The 2775 pound number should be remembered, but also the 56% Front / 44% Rear weight balance. As we showed in earlier posts or in that BRZ project thread, the designers and engineers put the 2.0L flat four cylinder engine way far forward in the engine bay. This pushed the drivetrain forward quite a bit, which pushed the heaviest mass on the chassis forward, which skews 56% of the car's weight over the front axle.
    The engine is also incredibly wide, since it is a "boxer" or flat 4 layout, with a measured width of 31". This made fitting the "big" V8 (which is significantly narrower) into this massive engine bay fairly easy.
    For our LS series swap we moved the back of the motor 11" closer to the firewall and set it as low in the chassis as the stock front subframe and oil pan allowed. This moved a significant amount of mass rearward, as did the addition of the T56 Magnum XL 6-speed transmission - which is farther back and heavier than the little 2 liter's 6-speed box.
    So without further ado....
    The initial car came to us at 2682 pounds (no back seat + 17x9" wheels + roll bar + race seats + front BBK) and with the LS1 + T56 it is now 2816 pounds, for a gain of 134 pounds. I'm a little surprised by that amount of gain, honestly, because my initial best-case estimate of a 50 pound gain wasn't that accurate. Some of this gain is added fuel weight; the car came to us with less than a gallon of E85 in the tank, and now has a 1/3rd of a tank of 93 octane - maybe 35 pounds more fuel than before. So the real gain from the LS1/T56 Magnum XL swap was about 100 pounds. Then look at the front to rear bias... it went from 56% Front bias on a stock FR-S to 52% Front now. That is a HUGE improvement to balance and handling.
    And did you see that driving video? It SHREDS 245mm tires!
    CANBUS Programming, Gauges, Electric Assist Steering: In Process
    We still have some work to do before turning it over to the owner. Its a bunch of "little stuff", but I cannot predict how long it will take... "days to weeks", probably. There's NOT a good CANBUS-bridge solution to make the GM and Toyota ECMs play nice, and we had two different programmers that came by and talked a big game but totally flaked out and disappeared. I have spoken with multiple CAN experts across the country who make it sound like going to Mars would be easier. And of course there are dozens of arm-chair software programmers who think "this is so easy!", and a few who can even capture CAN data, but we have Jack Squat to show for all of these internet opinions. If there was an easy solution to this CANBUS bridge we would have found someone who could pull it out by now. Please, don't clutter up this build thread with links to doo-dads and gadgets - we're good.
    We're going a different route, and we have what we feel is a good bridging solution coming next week (like everything else on this project - its late, of course). This will send data from the GM ECM and translate it for the FR-S - and it is all tunable/programmable. We still have to do the programming, and have been doing the groundwork for some time. We also have an HP Tuners programming suite purchased and en route, which we will use to help read and "tune" the outputs from the GM computer, and verify the OEM gauge readouts. This should provide a flexible and elegant solution, so bear with us if the OEM gauges and steering assist matters to you.
    Once we have the tachometer and speedometer working, the electric assist steering can be made to work. Driving the car was nearly effortless without power assist, mind you, but it is noticeably heavy below 5 mph. We will also make the factory coolant temp gauge work, and the fuel gauge already works now. We might even try to make the idiot lights work, but the Traction Control system is definitely NOT getting any attention from us. If you want that, go buy a stock vehicle. This V8 swap package is going to be a tire smoking machine, and might require A Real Man (TM) to drive it. The "electronic nanny switch" will be ignored.
    The engine's dyno tune will happen at True Street Motorsports (using their HP Tuners system + dyno + LS tuning knowledge) as soon as they can squeeze us into their schedule (likely next week). The A/C system still needs to be plumbed, charged, tested (its wired) and programmed, which we can test with the HP Tuners software.
    What's Next?
    I'm going to say this once - the BRZ/FR-S LS Swap Kit is NOT ready for production. We will NOT release this "in secret", trust me. It will be posted in this build thread, our Facebook page, blog, Youtube channel, and more - when its ready. First we HAVE TO DO SOME REAL TESTING on the Alpha components, with Rick driving and tracking this car, before we dive into kit production. Making fixtures and production batches of the various fabricated components is a big investment in time and capital, and I want to make sure this stuff is right before we reproduce more of the same.
    SO PLEASE DON'T ASK US WHEN THE KIT WILL BE READY. We already get a dozen emails and calls every week about an FR-S swap kit, and cannot afford to take a bunch of calls about something that isn't in production yet. It will be done when it is done.
    "How much will it cost?" is the next question, which we are already seeing. We don't know yet, but you can look at our BMW E36 LS1 product page to see solutions and costs a similar V8 swap. Most of the hard parts will cost the same, but the wiring harness solution (not shown on the E36 LS1 page) is going to be $1000-1500 or so, depending on how our bridging interface works. Again, DON'T ASK BECAUSE WE HAVE NOT SET ANY PRICES YET.
    That's all for this time. Thanks again for Rick's patience but we have something driving and this is exciting. We have sold over 140 swap kits for LS V8s in BMWs and fully intend to make the FR-S a production kit, when it is tested and ready. Stay tuned here for more news - we are at the 1 yard line now, and just need to push the ball past the goal line.
    Thanks for reading!
    10 Aug 2015 04:36 PM
    Project Updates for August 6th, 2015: We made some really good progress on the Alpha FR-S LS1 build in the past month. But, well... I've got some good news and some bad news on this update. The good news is - we're moving forward with the "Stage 0" kit production much sooner than expected. The bad news is - its because the customer had to pause the development.
    Now nobody involved is mad at anybody here, the customer just had to temporarily take the car back with a few things unfinished. It wasn't what anyone wanted, and sure - I'm disappointed about this delay - but everyone has a budget and that's just putting a dent in the next steps on this build. The car was returned to the owner last weekend and he drove it home in hot, stop-and-go traffic, and reported that it ran great even with a few things unfinished. Hopefully he can bring the car back for the last finish work soon.
    That's out of the way, so let's cover what we finished in July plus note the small amount of remaining development and labor needed to complete this build.
    Mistake on Weight Bias Changes
    So in my last post I showed the before and after pictures of a stock 2013 BRZ and this LS swapped FR-S. One thing we do around here is weigh lots of cars, and I probably have pictures of 200+ cars we've corner weighed over the years. Chassis and component weights are a big thing to me, as we know that lowering mass always improves performance. When weighing a given car I like to remove as many variables - like driver and fuel weight - to make comparing cars as easily as possible. We try to always show fuel level if its not on "E", then remove the "trunk junk" that every racer has to pull out of their cars when they take their car to an autocross or on track. This includes spare tires, the factory jack, floor mats, and removable trunk mats.
    We don't just weight cars, we often corner balance cars, and that means we look at the diagonal cross weights. Then we raise or lower different corners' ride heights (if adjustable) to alter the cross weights with the driver sitting in the car. The goal is to get the cross weights to both equal 50%, so the car handles the same when turning left or right.
    Massive engine/transmission setback (left) as well as driver setback (right) are helping this 69 Camaro push weight bias to the rear
    Altering front to rear weight bias is tougher, and you can't just change ride heights to move weight from the front wheels to the rear. Virtually every car ever made (except some rear engined cars) have a front weight bias, with 51-60% of the total weight on the front wheels. Moving parts around to put weight on the rear is common on race car builds, and helps to get a more "equal" front to rear bias (50F/50R). Approaching that takes a lot of work, but some RWD race cars can even get to the "ideal" bias of 52-53% rear... usually with a mid or rear engine placement.
    I was super excited that I thought we had moved from 56% to 52% front weight bias with the V8 swap. But it was too good to be true. I screwed up and didn't read the picture correctly. Our guys had the scale readout to show corner bias, not front to rear bias, and I should have noticed this. So the mistake is 100% mine, I own it. A sharp eyed reader on one forum caught this mistake from my last post, and the front-to-rear bias actually didn't change at all - still 56% of the total weight on the nose. But considering what the car gained (134 pounds), with all of the added weight in the middle and front of the car, to manage to keep the same front-to-rear bias was still a good thing. Most AWD and FWD cars we've weighed are closer to 60F/40R, so this V8 FR-S is still ahead of many competitive cars out there. My apologies for posting bad info - mistakes like that drive me crazy - and I have already corrected this mistake on many forums where this thread is posted or re-posted.
    Cars & Coffee Dallas - July 4th, 2015
    Amy and I towed the FR-S out to the Independence Day Cars & Coffee event with this American-ized Scion FR-S. Nothing says "Murca" like a domestic V8 swap, right? Since the car hadn't been dyno tuned I didn't want to risk driving it across town, so our enclosed trailer was the right way to transport it. We parked and unloaded a block away and drove up at 6 am with many hundreds of people craning their necks as this V8 powered Scion rumbled into the parking lot...
    We parked with several other Vorshlag cars and the SCCA folks, but the Scion dragged in a couple of dozen fans the instant it pulled in. The little silver FR-S looks pretty unassuming from afar, but with the hood up it drew them in like moths to a flame... "Whoa... is that a V8?!"
    We had several other Vorshlag customers parked with us, including the heavily Vorshlag modified "Roush Stage 3" Mustang (above left) and the C7 Z06/Z07 Corvette (above right), which has our new production C7 harness bar.
    We were all there parked with the Texas Region SCCA, who had a tent up with a screen and speakers playing autocross videos. Shop manager Brad had his STX prepped BMW E36 parked there as well, and it has a full array of Vorshlag goodies on it. Even with a brief (2 minute) sprinkle of rain it ended up being a great day and I talked to hundreds of people about the FR-S swap. The owner of the car also got to take a ~10 minute test drive in the car as we left, and then met us back at the trailer for a tow back to Vorshlag. We had the dyno tune scheduled for a week later...
    First Dyno Tune + Cold Air Tube Version 2.0
    I took the car to True Street Motorsports on Monday July 13th and the car made 328 whp & 331 wtq. Which is probably spot on for a bone stock/rebuilt 2002 Camaro 5.7L LS1, but I had hoped for about +10 whp than that. Their head tuner Sean noted a funky air:fuel ratio issue at higher RPMs and suspected that the cold air induction tube we built for the original throttle body and adapted to the current throttle had some reversion into the MAF sensor. And from looking at the design we made, I was in agreement. So mistake number two, also on me, but we made it right.
    The first tube (version 1.0) went from 3.75" at the MAF (2005 Corvette LS2 OEM MAF sensor), necked down to 3" in the aluminum bends, then opened up to 4" at the throttle body elbow (into a 2005 Corvette LS2 throttle body). So, the thought was, that as revs increased, the incoming air was getting backed up by the 3" bends and wrecking havoc upstream at the MAF.
    The cold air tube "version 1.0" had a change in diameter from 4" to 3", which caused some tuning issues
    This whole area gets tight, not only from the radiator hose but the very low hood line, and this first smaller tubing cold air intake system had better clearance than it probably needed. Sean put a solid dyno tune on the car with a work-around to make the air:fuel ratio not lean out up top, but he wanted to re-do the tune after we made a new intake tube - predicting a possible 10-20 whp gain.
    Of course I insisted that we re-make the tube, and the customer didn't pay a dime for this reworked "version 2.0" intake tube section. We researched the parts, ordered up some 4" (ID) silicone bends and some 4" (OD) aluminum mandrel bends, then got to work. Ryan knocked out the all new tubing layout in a short time, and it fit under and around all of the neighboring parts.
    As you can see the main aluminum tube had to be "ovaled" a bit near the top, to clear the unmodified inner structure of the factory aluminum hood. But its stays 4" all the way from the MAF to the TB on this version, and I'm much happier with the final layout. Having driven the car before and after, it does feel more responsive with the new 4.0" inlet tube.
    Oil Catch Can + PCV System Added
    Another thing we wanted to wrap up before we took the car back for a re-tune was to plumb the Positive Crankcase Ventilation system, plus add an oil catch can for road course use.
    The routing we wanted to use is shown above right. This more or less uses the factory LS2 PCV system routing, and adds a fresh air / vacuum source in front of the TB. The weld bung added to the new 4" inlet tube setup (in the section above) was for a fitting to feed vacuum/air to the PCV system. The oil catch can we had picked up from Mishimoto had no internal baffling or metal mesh - which is needed to trap oil droplets from the excess crankcase pressure. It was just a catch can with a sight glass, which isn't what we needed here. So we scrubbed that (above left) and picked up another model made with the internal baffling we needed.
    We ended up choosing this Detroit Speed oil catch can setup, which is made for LS1 use. The included bracket bolts to an existing hole in the LS cylinder head on the passenger side, and it was plumbed with a feed from the crankcase cover vent (under the intake) and a vacuum source from behind the TB. Nice little oil catch can kit can is made by Kyle Tucker and his company - who race in and sponsor the Optima series - so now I know what catch cans we will go to first, from now on.
    continued below
    10 Aug 2015 04:38 PM
    The final underhood shot we got is above right, and shows the new cold air inlet tube, catch can and all of the PCV routing.
    Quick Clean-up, Inspection, and Customer Pick-up
    After the new cold air tube and catch can system were in place, we had the car back at True Street. It waited there a couple days (Sean was out sick) waiting in line, but after the customer changed our plans, I went and picked it back up and brought it to our shop before they got a chance to re-tune it.
    After it was here I had our crew look over the car, test drive it and try to get it as road worthy as possible in the 2 days we had before it was to be turned over. They tightened a few suspension bolts (that we hadn't touched) that had always been loose, replaced the driveshaft bolts with better hardware (below), and more importantly - pulled the motor mounts and transmission crossmember off the car to make production fixtures.
    Since we don't know when the car will return, it was time to make the production fixtures. Each of the 7 components of the drivetrain mounts came off and all plate sections were measured and drawn in CAD. These can now become CNC laser cut parts. Ryan then made the production welding fixtures for all 7 pieces of the mounts, which will accept the laser cut pieces + tubing to make the various parts.
    This means we will have the drivetrain mounts, driveshaft and headers in production before this car is finished. Again, not the original plan, but due to these circumstances it moves up production of these "Stage 0" pieces. These parts will help others get the LS series V8s into the cars quickly, and then they can tackle wiring and plumbing on their own.
    We hope to get this car back - to develop and produce the black box interface we already have on hand. We were "ones of days" away from implementing that, but what can you do? We have programming software and a laptop just for use on this build also, but those tools can and will be used on other LS swaps we tackle in the future.
    Amy wants to build an FR-S/BRZ in the next year, but if our budget can allow for it we might start another build LS1 86 built soon - to be able to finish the wiring, gauge interface and air conditioning system quickly. We also need to complete the replacement swaybar (a tubular, splined swaybar, as seen on the 69 Camaro above) as the rear of the engine and headers are blocking the rear routing of the OEM swaybar location.
    Speaking of the 69 Camaro, we have made a build thread for that car (on Vorshlag and 3 other forums). This tube framed monster is coming together very quickly - being a one-off and not a "production kit" development deal, there are so many fewer compromises - plus not the 100+ hours of development work that goes into making a reproducible swap kit. You can read about the tube framed 69 Camaro project starting here.
    What's Next?
    This is a tough one to answer - because I don't know when this Alpha car will return. The only real unknowns left on that car were the CAN-BUS box integration, but we have the software and have done dozens of hours of research on the Scion and GM wiring systems, to know what to wire where. The air con bits are fairly straightforward, and the swaybar is easy for our crew to fabricate.
    Custom/swap integrated air conditioning and gauge wiring is a pain, but we've done it before...
    If we have another customer that shows up and wants this same V8 swap we can jump ahead quickly on that build as well - as there are no more months long delays on header development or other long drawn out deals. If we can swing the costs of buying our own FR-S/BRZ, I'll do it and get it into the shop soon, to quickly get it to this state with production mounts/headers/driveshaft, then move forward to the CAN-BUS interface (we have everything on hand!) and then the swaybar and A/C bits.
    Like I said earlier, right now the plan is to move forward with production of the drivetrain mounts, headers and driveshafts soon. Its all good.
    10 Oct 2016 05:19 PM
    Project Update for October 1st, 2016: Yes it has been a year since my last update in this thread. A lot has gone on behind the scenes. I have started to write this update a half dozen times but each time we were either super busy on other projects or waiting on an outside vendor to finish something on some component for this swap.
    While this car left our shop after my last post it did come back a couple of times for some upgrades and more development. A few "non-V8 swap" related upgrades were added and it left here "more finished" than it ever was each time. It has since racked up 8,000 miles of street use with the LS1 V8. It has been re-dyno'd and the updated cold air intake we added to the car made a bigger differences in power than we had expected.
    While the silver FR-S has left, we purchased this red FR-S for Vorshlag specifically for V8 development
    We were in the middle of development on a front swaybar when the car left. Yea, the Alpha car is no longer being worked on at my shop (its complicated) but we have since purchased our own 2013 FR-S (above) here at the shop to develop more details of this swap kit as well as some upgraded drivetrain parts. You can read about the red FR-S we purchase in this Vorshlag BRZ/FR-S Development thread. When the V8 swap starts on this red car we will update both that thread and this one concurrently.
    It was not all smooth sailing behind the scenes here, however, as V8 swap development sometimes has hiccups, delays, unforeseen challenges, and gotchas. Let's get caught up on this first V8 swapped 86 we've done and see what's in store for our next build and the release of the kit components.
    To tide the customer over until the CAN-BUS translator could be built we added some auxiliary gauges to the FR-S. These could show water temp, oil pressure and oil temp. The only gauge on the OEM cluster this replaced was water temp, which has a vague non-numbered 1/4 sweep coolant temp gauge. The oil pressure is a dummy light and there is no OEM oil temp reading of any kind.
    Track Rat Miata had aux gauges that were the basis for what we added to the FR-S
    Since this FR-S was destined for track use, the additional full-sweep analog gauges were desired by the customer. We always recommend real gauges or a digital dash for cars driven regularly on a road course, to show accurate readings for water temp, oil temp and oil pressure, at the very least. The OEM gauges are rarely accurate enough to show these critical readouts for a track car. The track rat Miata (picture shown above) we built during this same period had these 3 main gauges added, and when the FR-S owner saw that setup he wanted the same thing. Ditching the factory radio in the Miata above freed up some great real estate on the dash for additional gauges and switches - and the FR-S' radio was already long gone, so we figured we would do something similar.
    These are the gauges added to the Alpha FR-S in the stock radio location. Red buttons are for program/recall
    We also had a round digital volt gauge in stock and the FR-S owner wanted that as well. The three main Marshal electric gauges are full sweep (not 1/4 sweep) and have programmable high and low alarms, data memory for the last time the car was run (can show high-low at the press of a button), and work very well for the amount they cost.
    These gauges come with sending units but you have to source the adapters and fittings to make them fit your particular setup. Nothing too difficult, and the images above show the oil temp and oil pressure sensor hook-ups. The coolant temp sensor was located in the cylinder head, as shown below. This is the passenger side, which is normally plugged. The GM (computer read) coolant temp sensor goes in the opposite corner on the driver's side head.
    All told it took 7 hours to source the fittings, wire in the sensors, build the gauge panel, then wire up the 4 gauges and lights into the panel shown below. Which is nearly exactly what we quoted - as these auxiliary gauge installs always take time to mount and wire correctly and cleanly. You also also burp the coolant system, test the temps for accuracy against an IR gun, and program the high/low alarms on the 3 Marshall gauges. Materials totaled $450 for 4 gauges, the fittings, wiring, loom, hardware and adapters.
    The main wires to this series of 4 gauges were all terminated in WeatherPack connectors, to make removal of this panel simple and quick. As always, the wiring was soldered and shrink wrapped at each connection. The three main Marshall gauges are LED back-lit for night use, and also have different color LED lighting to show "alarm" conditions. Admittedly that is hard to see in full sunlight, but that is still visible in most cars with a roof.
    Normally we would also add a weatherproof dual USB port and a 12V cig lighter port to this gauge panel (the Miata shown above has the dual USB port added). These are marine grade units with rubber boots that cover them up when not in use. But the FR-S comes with a factory installed USB port and this customer had something else in mind for the blank spot above, so we left those two ports off.
    This image above shows the Marshall gauges with the back lighting turned on, for night use
    This set of gauges made everyone feel safer - the most essential data of the engine would now have proper readings, better than the factory ever showed. It would supplement the OEM gauges which were still waiting for the CAN translator. Not having a tachometer was a bit annoying, but the customer didn't want to add one at this time so we all waited on the CAN solution.
    In late 2015 the availability of bolt-on tow hooks was pretty light. The owner was talking about doing more track days and what you don't want to happen there is to get stuck off track without proper recovery hooks. It is safest to have one of these on each end.
    In a rush to clear the track of a stalled or stuck vehicle, often the tow truck driver will just "find something" to hook onto, and you don't want to think about the damage that could do. So we made some proper tow hooks for this FR-S, which we might someday market and sell.
    The main parts we needed to create were the threaded shafts that went into factory tow hook holes in the front and rear bumper. These were hand machined and tapped on our manual lathe, as our CNC lathe was tied up with production work. Our guys made them specific to the front and rear of the 86 chassis and we made drawings off the final bits.
    These shafts were then painted and these red anodized aluminum screw-in hooks were added. These hook portions are commodity parts we use on lots of cars, so we know they are rugged and the price is right.
    These can be installed quickly if you leave the plastic plugs on the bumper covers off, but the customer wanted to keep the hooks in all the time so our guys spent about 25 minutes marking, aligning, and trimming the plastic plugs to fit tightly around the shafts for the tow hooks. Looks cleaner this way, and you don't have to install/remove each time you come back from a track event.
    After something happened to the tune loaded on the ECM (see CAN-BUS fiasco, below) the customer took the car to another shop and had it reflashed and dyno'd, where it made 372 whp back in March of 2016. That was a big jump from before! Remember - this is the weakest LS engine made for any car ever, a bone stock 1998-02 Camaro 5.7L LS1 long block, a stock LS2 intake/throttle body, our headers, catalysts and an exhaust that led into a stock FR-S Magnaflow rear section. That updated cold air intake seemed to be the only part that was changed from before, when it made 328 whp & 331 wtq in July 2015. Not bad.
    We started development on a replacement front swaybar in the middle of last year, and got pretty far along, then this got stalled while we waited for the swaybar manufacturer to deliver the prototype piece.
    The picture below shows the OEM swaybar with Whiteline end links mocked up with the V8. The swaybar is hanging in mid-air, and as you can see, the long tube headers needed that slot between the frame rail and the bellhousing. The stock swaybar was hitting the headers, hitting the tie rods, and was shifted down several inches in that image. If we tried this not only would it bang up against the tie rods, it would also hang very low, and be the lowest part of the car. Just wasn't possible while using real long tube headers. And the long tube headers add a LOT of easy horsepower we didn't want to give away.
    We had seen this interference when we developed the long tube headers, so we had planned to make a new swaybar to clear the headers and bellhousing. How hard can it be, right?
    It was surprisingly difficult, actually. Swaybars seem like such a simple thing - just a hunk of round bar end to fit around stuff, which ties to two end links, that are then tied to the strut or control arm. As one end rises (in body roll), the endlink from that side makes the swaybar twist, which resists the movement, and reduces body roll. Easy.
    We have created custom splined-end swaybars for several race cars, like this tube framed car above. When you have room for a straight shot across the car laterally like this, it is relatively easy to do. We can make the splined ends have all sorts of bends to route around stuff.
    The problem on the 86 chassis was that our long tube headers were right where the funky shaped stock swaybar needed to be. There is no "straight shot" across the engine bay on this car anywhere near the spindles - the motor (forward) and headers (rearward) are in the way. So a straight splined "NASCAR Style" swaybar would never work here. Well technically it could, but it would also be the lowest part of the car, by a lot, and could get dragged and ripped off the car pretty easily. We thought there was a slim chance that we could just re-mount the stock bar lower and make it all fit.
    We made several versions of new swaybar mounting brackets, which lowered the main bar by about 2 inches lower than the OEM mounting brackets allowed. The picture at left was the first mock-up, and the one at right was the 3rd set we tried, which looked like the best routing and the strongest shape.
    Once the mounting bracket was finalized we could test with the OEM swaybar relocated at this lower height to see if it could work. We mounted that on new bushings, then moved the suspension through its range of motion and the steering from lock to lock, then noted a bit of binding. This meant we needed to extend the length of the ends of the swaybar to allow for proper articulation and suspension travel. That means - new swaybar. And it had a somewhat complex shape to it.
    We made a couple of mock-up swaybar shapes and sent them to a swaybar vendor, where it took 10 excruciating weeks of waiting before the prototype bar above arrived. Our original mock-up bar was now missing and this new bar we got didn't fit. We tried to get the mock-up bar back to verify the delivered piece against them, but were unable to receive it. We needed a prototype bar that was symmetrical (this wasn't) and matched our mock-up (it didn't).
    Around this same time the customer wanted his car back, so we never got to finish this swaybar work on the silver FR-S. Finishing this relocated and reshaped front swaybar was one of the many reasons why we bought the red FR-S shown here. We will start development on this new swaybar routing in the using our shop car very soon.
    We have already got some "baseline lap times" in this bone stock FR-S at Motorsport Ranch Cresson on their 1.7 CCW track back in August. It will be fun seeing how much we can knock off that stock lap time with a V8 and some better bits underneath.
    continued below
    10 Oct 2016 05:21 PM
    To make the LSx engines emissions compliant and to allow the OEM gauges, electric steering assist, HVAC and the rest of the factory Scion/Subaru systems work, there needs to be a "bridge" between the GM engine control module (ECM) and the Subaru/Toyota ECM. The goals were seemingly simple: send some data over the CAN-BUS network from the GM ECM to the FR-S' ECM to allow the stock gauges to work, the HVAC to function, the ABS system to operate, and the electric steering rack to actually have power assist. Every programmer on the interwebs seemed to say "oh, that's easy!" but so far we have worked with 3 different groups and have little to show for it.
    Why is this necessary? Well for a pure race car it isn't - you can use an aftermarket ECM and then just add a digital dash or a separate set of analog gauges. But for most folks, they want emissions compliance, functional OEM gauges and air con to work. The main Subaru/Toyota ECM controls most systems on the body these days - unlike in the 1980s-1990s, where several smaller computers were dedicated to different "body" functions. The main ECM send signals to various systems all over the car via the CAN-BUS network.
    Jason had reached out to several groups and individuals familiar with CAN programming two years ago looking for some help with the dual ECM / CAN integration. This was the solution needed to help "finish" this this type of swap in a street-legal, kit-able form. We have been looking for a CAN-BUS integration for our existing BMW E46 LS swap for 5+ years already, too. No, those solutions aren't 100% there yet either, and these attempts were started long before the 86 swaps began.
    Initially it was two different local programmers that answered our call. They both showed up at different times, met with us, started some work, then went radio silent. A third guy here in the USA - who was working with an Australian group Jason had talked to a earlier - actually flew in to work on the Alpha car. It was a complicated deal, where he was trying to work directly with our customer, even though we had talks with him months earlier. This programmer installed a CAN translator module (shown above) but after many hours of wiring and testing it didn't work as promised. Somehow this install wiped out the custom dyno tune loaded onto the GM ECM, so the car ran poorly afterwards.
    I've done just enough programming to know when a job is harder than someone thinks
    I also met last month with a friend of a friend who worked in the same field I did 15 years ago - controls systems, ladder logic programming, signals and wiring. He did controls on gas compressor systems (natural gas) and I worked in gas fired turbine power plant controls, but those both use similar controls systems, programming, GUIs, etc. So we knew a lot of the same systems, programs, and products. He was also a car nut, and more up-to-date on CAN systems (from Caterpillar diesel systems he works with) than I will ever be. Finally this was somebody that I could talk to and who might be able to understand what we needed to do here?
    I explained the goals of the CAN integration for the FR-S/BRZ LS swap, then he spent about 12 hours over the next weekend researching, looking at Subaru and GM CAN systems and encryption. The next week he came by and had some daunting news - this is never going to be "easy". Why? GM is known to encrypt a lot of their CAN protocols, because they don't want people doing exactly we're trying to do. Same goes for most other car manufacturers. And none of them use the same encryption. The "CAN-BUS" architecture is not universal among differing car companies, either.
    As I suspected, he said this will never be an easy "programming job" where you can hook up a $200 "CAN Sniffer" to both computers' CAN network wires, "sniff" the two different sets of CAN signals, then just make a black box to convert them into the same language. He described it more like a FAX system... where you have two computers talking over a network, but they have to talk back and forth... call, receive, handshake, then talk. When you encrypt the signals at both ends, and they are not made to talk to each other, you get a bunch of "dropped calls". So while a few things might work for a short period, long term communication between two different company's ECMs is going to be "a big challenge".
    As bad as I have been making it sound, and as hopeless as it had seemed - Eureka! This CAN integration box now exists, and it happened very recently. A German company called MRS Electronic, who Jason had first talked to in 2014, seem to have just come up with a marketable, working solution for LSx to 86 CAN integration as of 9/25/2016 (see above). They were the only group we spoke with originally who had "downplayed" the easiness of this integration early on, and yet they are the group who developed a working CAN integration solution for this chassis first.
    They put the call out for testers recently and happened to link up with our old Alpha customer's FR-S. As of last weekend that car has a working set of OEM gauges, power steering and more, as shown in a video posted to the FRS/BRZ LS Swap Facebook group. His car has a GM "E40" series ECM, made for the LS2 engines which used a 24 tooth crank reluctor (also known as "24x"). We used that ECM because the engine chosen for his swap was an older 5.7L LS1 longblock (which has a 24x crank reluctor) with an LS2 intake manifold and drive-by-wire throttle body (which was needed to clear the hood). A more common ECM to use is the GM "E38" which is made for the later LS3 engines with a 58x reluctor. This is the ECM that MRS apparently cracked first, then they worked on the E40 (shown below) for the Alpha customer's FR-S LS1.
    The Alpha build had an E40 ECM, due to the 24x LS1 long block and LS2 intake
    Now that his enigma has been cracked, we here at Vorshlag can stop hunting for this solution and concentrate on making the fabricated driveline mounts, the plumbing and cooling solutions, and leave the CAN integration to others. This is a big deal and should make 86 swaps much easier for all GM LS engines, and has accelerated our in-house FR-S V8 swap build.
    We actually began a small production run of CNC laser cut components to make motor mounts and transmission crossmembers last month. We will soon be able to help anyone quickly make a race car V8 swapped 86 chassis using our "Stage 0" parts.
    We just got word from our powder coater that these initial pieces are ready and should be available for sale a few days after I posted this. These were made off of our production fixtures with CNC laser cut parts, which were made off the Alpha car's proven LS driveline brackets.
    Since the MRS folks figured out the CAN Integration we have accelerated the timeline for the V8 swap in our shop's red FR-S. This "Beta Build" will help us develop even more solutions to make this V8 swap easier and more complete, as well as tackle the unfinished business such as our front swaybar solution.
    The Beta FR-S - A New Hope! It was fun but underpowered on the MSR 1.7 mile course
    There is an aggressive schedule laid out and we are acquiring parts now to make this build happen. Even when you are a shop like us, this is not an inexpensive swap, and that's one thing I wanted to write about here - this swap is not ever going to be a "cheap upgrade". There are too many known weak links we will need to address on our Beta Build (which should have 150+ more hp than the Alpha), as we will likely "break a few eggs" in testing. But adding significant, reliable horsepower is never cheap - not even a boosted FA20.
    What might break? Well I was over at "a major Subaru tuning shop" last weekend and talked to one of their top guys there for an hour about FR-S/BRZ power mods and upgrades. He had little good to say about the factory ECM and aftermarket tuning options, and even fewer good things to say about the viability of the FA20 engine. He noted the abundance of low quality supercharger and turbo kits made for these cars - most of which are sold at a "very low price point" and, as always, you get what you pay for. He said there are better aftermarket turbo/supercharger kits, which cost a great deal more, but even those often need some tweaking and re-work by the installation shop.
    Also, whenever you are adding boost to an engine, you aren't making it MORE reliable, you are making it markedly LESS reliable. This is why we tend to prefer LS swaps with larger displacement N.A. engines vs boosting smaller engines to increase power. Boost just adds problems...
    As you might imagine, he noted that boosting a stock FA20 with the factory 12.5:1 compression ratio was a very short term power solution - they all eventually blow up. The right solution for adding boost to the FA20 is to properly rebuild the entire engine to handle this: adding lower compression forged pistons, stronger rods, and maybe throw in some head work - then they don't blow up as easily. We started talking costs on 86 cars they had built "the right way", with real reliability and power approaching 250 whp, and the total price was quickly approaching or even exceeding the costs for an LS swap.
    The factory R180 Subaru differential above is more suited to 200hp than 500 hp... it is not overbuilt
    But then once you get into the 400-500+ hp range, other stuff will likely need to be addressed. Another thing our tuner shop manager friend mentioned was the relatively low strength of the R180 rear differential (shown above) and half shafts, and the somewhat poor function of the factory installed Torsen LSD. Once you add higher strength axles ($1000+) and an OS Giken ($1700 + install) or another good aftermarket LSD, the prices start to climb yet the strength is still limited by the relatively small 180mm diameter ring gear of the R180.
    In the past with BMW LS swaps (a car that does have some overbuilt factory parts), we've put "big power" (500-600 whp) through the medium case (188mm) and large case (210mm) factory BMW differentials, but those are both bigger and heavier than the little R180 in the 86. This extensive "abuse testing" we have done in BMW V8s included standing start events (autocross) and road course events on foot wide Hoosiers. Our Alpha E36 LS1 had 490 whp and 315mm Hoosiers on 17x11" wheels, as shown above. We beat on that car mercilessly for many years without issue on the 188mm housing, but some of our customers were able to break those. The 210mm BMW rear housing was a difficult swap back then, but it is more common now and this is one of those cases where "bigger is better".
    So... maybe it makes more sense upgrading the FR-S to a Ford 8.8" IRS housing from the 2015 Mustang? (shown above) This "224mm" ring gear is inherently much stronger, has dozens of alternate gear options, and many more limited slip differential choice - all at much lower costs. It comes in both a steel case (V8 Mustangs) and an aluminum case (Ecoboost 4, shown above), but both are very strong. We will look at the work needed to adapt this 2015-up Mustang S550 8.8" rear differential to our shop car, as we are shooting for north of 500 whp on the little red FR-S. With an LS3 or later V8 that 500hp goal is actually not very hard to accomplish.
    But we will see how far the R180 can go first. Our red FR-S will still be an air conditioned street driven car, which my wife wants to both race and daily drive. That is toughest possible goal to reach, but that's what most people want (street car + track car), so we're going to build it that way to see what fails and make fixes accordingly.
    More soon,
    Terry Fair - www.vorshlag.com
    11 Oct 2016 07:47 PM
    Cool to see this back in development!  The rear diff in the frs/brz is not an R180 though. It is very similar to the factory toyota diff used in the IS300 and other cars. Should have a 205mm ring gear from what my research tells me. Decent size, but probably not enough for a 500hp LS engine on a reliable basis.
