Last Post 22 Jul 2012 04:46 PM by  Bullitt2954
Check Out This Sports Racer That Is For Sale !
22 Jul 2012 03:16 AM
    FEATURES ----
    HAS – SCCA fuel sample port
    HAS - new transponder.
    HAS – Aeroquip brake lines
    Thanks. Mike
    It sounds like a great car but, C'mon man - was 9 posts actually necessary to sale it?
