Last Post 16 Sep 2016 03:51 PM by  OZMDD
OEM wheel options/restrictions?
roninsoldier83
12 May 2016 12:52 AM
    Hello!
    So, I own a base 2016 VW Golf R and would like to run the car in B-Street. The base model comes with 18x7.5" wheels, but there's an option package that includes 19x8" wheels. The caveat is that in order to get the 19x8" wheels from the factory, you have to order the Nav/DCC package.
    I know about he +/- 1" rule and it mentions standard wheels. With the rule, a Golf R that came with 19x8" wheels could run 18x8" wheels. Since the 19x8" wheels are optional on the car, can I run 18x8" wheels? Or would I also have to add Navigation and DCC?
    sjfehr
    12 May 2016 05:43 PM
    In order to legally use the bigger wheels, you need to retrofit that entire option package. You do have some recourse with respect to comfort & convenience options for things like the radio and trim badge on the trunk, but you otherwise need to retrofit everything in the Nav/DCC package to use anything in the Nav/DCC package. Is it something you can retrofit?
    Incidentally, I ran into similar issues looking to retrofit PASM (similar to DCC) on my car and recieved clarification via fastrack that the electronic components that drive the active shocks are NOT considered part of the shocks and need to remain on the car even if you rip out the active dampers and put in MCS or something.
    OZMDD
    You will not be able to run the extra width of an 8" wheel legally. You can go up or down 1" on diameter, but width cannot change, and offset can only change by a small margin. If it makes you feel better, the 0.5" of extra wheel won't make you significantly faster until you get to the pointy end of the class.
