Last Post 08 Jan 2009 11:10 PM by  andersonk24
Fox body SCCA American Sedan - For Sale
andersonk24
05 Nov 2008 10:38 PM
    Championship car. sorted, fast, reliable, Fox body notch back.
    5.0 Liter bored .030 over, GT-40P heads, Endelbrook Performer RPM manifold, Holley 600 CFM “double pump” carburetor, high performance aluminum radiator, custom 1 5/8 full length headers, 7 quart canton oil pan, 3 quart oil Accu-sump, remote mounted oil cooler, Ford Motorsports HD World-class T-5 transmission, Ford Motorsports HD clutch and pressure plate, Moser racing axles, Ford 8.8 inch 3.55 ratio rear, posi-traction limited slip differential
    Chassis modifications:
    full sub-frame connectors, full 8 point roll cage, custom built torque arm, height adjustable spring perches, racing springs, koni double adjustable shocks, front shock tower brace, camber/caster adjustment plates, custom built rear panhard bar, 22 gallon fuel safe racing fuel cell, PBR front and rear brake calipers, 12 inch Brembo front rotors, 12 inch rear rotors
    18 wheels and tires. many spares(brake parts, rotors, trans, gears, rear, rear gears, springs, etc...). 2008 annual SCCA tech.
    Horsepower: 391
    Torque: 386 Ft lbs
    Racing history / accomplishments:
    Year car was built: 1997
    past lap time record holder: Virginia International Raceway, Summit Point Raceway, Nelson Ledges Raceway
    Racing series results / Championships:
    1997 Washington DC SCCA Region – MARRS Champion
    2003 Washington DC SCCA Region – MARRS Champion
    2007 Washington DC SCCA Region – MARRS Champion
    $12,000
    pictures available, can be emailed. Located in MD, near Washington DC.
    Contact: Ken Anderson, c-301.788.6787, andersonk24@aol.com
    Also available:
    TRAILER - 1999 24 ft 10,400 GVW enclosed trailer available as a package ($17,500) or separate ($6000) after car is sold.
    andersonk24
    28 Nov 2008 08:35 AM
    Reduced price: need to make room for another car and trailer. Car $10,900. Trailer $5400. Car and trailer pkg $15,800.
    andersonk24
    Car SOLD!!!! Trailer still available. 24 foot 10,400 GVW. $5400
