Last Post 01 Jul 2012 11:13 AM by  Malfred
Ecnomical Sports racer - new lower price !
    FEATURES ----
    HAS – SCCA fuel sample port
    HAS - new transponder.
    HAS – Aeroquip brake lines
    Thanks. Mike
