Last Post 01 May 2013 05:31 PM by  cbramey
Brake proportioning for four channel ABS
lowellmarx
01 May 2013 04:24 PM
    Need a way to balance the two rear brake channels on the ABS with four channels. Can't find a proportioning valve to accept two lines in and two out. What is a person to do with a modern cars system when removing the A B S wheel sensors and the default is one end of the car locks up the brakes?
    cbramey
    If you have any ideas other than change calipers or master bores, or putting a seperate prop valve in each rear line.
    Or buy bosch racing abs controls.
