Last Post 15 Apr 2015 05:46 PM by  Just@ruggedradios.com
*New Rugged Products*
07 Oct 2014 01:05 PM
    NecksGen is the leader in head and neck restraint safety and their new REV has advanced features that take comfort to a new level. The NecksGen REV has no frontal yoke so there's no pressure on the body or collar bone. The low profile design gives full range of head motion with no front or rear interference with your helmet.
    Thanks to the placement and angle of the lower tether mount, the NecksGen REV unit offers unsurpassed angular impact protection to provide safety from all sides.
    Made in the USA, NecksGen restraints are offered in four sizes to accommodate all drivers and sizing requirements. Includes quick release helmet hardware, carry case, tool kit, decals, and a bonus NecksGen Flexfit hat.
    For $599, you can protect your neck today! (product page linked in graphic)
    17 Nov 2014 01:11 PM
    Pro Pods- velcro mounted mono helmet speakers
    These soft, flexible, and durable "Pod" style speakers are perfect for mounting inside your helmet for clear, comfortable listening.
    The 3.5mm mono jack plugs directly into audio devices such as MP3 players and scanners. The easy to install velcro pad allows you to remove and replace the speaker pods as needed.
    26 Nov 2014 02:03 PM
    H42 Purple Headset with PTT
    If you have a passion for purple, you gotta pick up our newest addition to the Rugged H42 series!
    Available for a limited time and in limited quantities.
    03 Dec 2014 05:25 PM
    Have a couple of new products for you guys.Heavy Duty On/Off Power Switch ($15)SWITCH-HD-MD.jpg SWITCH-HD-BACK-SM.jpg This heavy duty, triple sealed, waterproof power switch is a must have for any vehicle. Don't get stranded from a dead battery. Sleep easy knowing your vehicle's accessories are not drawing power. The rubber coated switch withstands the harsh environments of any terrain, allowing you quick access to that extra light bar, wireless music device, etc.You might want to order it with our Toggle Switch Mounting Plate ($5.25)SWITCH-HOLDER-MD.jpg This 20-gauge steel mounting plate features a 1/2 inch hole that works great with our heavy duty power switch. Simply mount the plate to your panel using the two holes on the end and you're set to attach your switch or other hole mounted device. Black powder-coated for a clean finish.switch-and-hole.jpg
    23 Dec 2014 12:10 PM
    IMSA to Stilo Helmet Coil Cord Adapter ($45)
    Connect IMSA configured communication wiring to wired Stilo helmets. Simply connect the white plug into your Stilo helmet comms jack, and the black plug into an IMSA style harness and you're ready to race!
    23 Dec 2014 12:32 PM
    Rugged Badge $15
    The 3" metal badge with Rugged Radios logo embossed into it is a great accent for your dashboard, toolbox, MAC system, bumper, etc...
    A 1/8" hole drilled into both sides make it easy to mount using screws or rivets.
    23 Dec 2014 12:51 PM
    Submersible Heavy Duty Speaker Hand Mic for HX Series Handhelds $65
    The Rugged Speaker Hand Mics are built tough for heavy duty applications. The unit features a conventional side-mounted Push-to-Talk button for ease of operation.
    Built to last in your extreme environments such as Police, Fire/Safety, Emergency Services, Racing, Industrial, Security, Heavy Equipment Operators, and other places where you need to be heard.
    • Loud front firing speaker
    • Submersible
    • Tough Polyurethane coil cord
    • Easy grip Push To Talk
    • Large rotating clip
    • Clear noise canceling mic
    23 Dec 2014 01:26 PM
    Single Seat Kit for RH5R Radio $320.40
    Perfect for helmet applications in a single seat environment such as cars, sand rails, sand cars, Trophy Kart, UTV and offroad racing, etc...
    As the driver, this kit allows you to transmit via PTT over VHF or UHF frequencies to your crew chief, mechanic, support team or base camp. Easy installation and top components provide the best in communication.
    Unlike the Moto kit, this single seat system provides more reach with longer cables on the car harness, as well as a coiled PTT for mounting to the steering wheel.
    This Kit Includes:
    (1) RH5R dual band handheld radio
    (1) CJ-KEN (Radio Jumper)
    (1) PTT-VM-WP (push to talk)
    (1) CH-O Harness
    (1) HK-OFSP-3.5 Helmet Kit
    (1) CS-Music iPod/MP3 cable
    Easy connectivity combined with a PTT makes communication clear and easy. This communication kit merges the best in audio with powerful and clear performance.
    30 Dec 2014 12:40 PM
    AIRAID filter for MAC1 Pumper System ($30)
    The AIRAID filter for our MAC1 Pumper System provides multiple layers of defense against dirt and dust.
    Every AIRAID® Premium Filter is hand-built using high quality materials and all AIRAID® Premium Filters come with a Lifetime Guarantee. We start with a multiple layer breathable media combined with our unique filtration technology resulting in a superior filtration system. All AIRAID® Premium Filters trap the smallest dirt particles that ordinary cotton-gauze “performance” filters can’t capture.
    LIFETIME GUARANTEE
    All AIRAID® Premium Filters are built to last "for a lifetime", guaranteed. Each AIRAID® Premium Filter body is made from hand-poured urethane that won’t crack or shrink in the high-heat environment found under the hoods of today’s vehicles. Each AIRAID® Premium Filter is 100-percent washable and reusable and come with AIRAID's exclusive "No Hassle" Warranty.
    Filter Dimensions:
    Bottom - 4.375"
    Top - 4.375"
    Height - 3"
    30 Dec 2014 02:58 PM
    AIRAID pre-filter for MAC1 Pumper System ($21)
    AIRAID® Pre-Filters are highly recommended for applications that are used in extremely rugged environments. The AIRAID® Pre-Filters are manufactured from a durable water resistant polyester material. With uniform micro openings that filter out debris 5 microns and larger, dyno & flowbench testing has proven no significant loss in power or airflow using this product. Fits only MAC1 air pumper filter.
    30 Dec 2014 05:23 PM
    AIRAID filter for MAC4 Pumper System ($50)
    The AIRAID filter for our MAC4 Pumper System provides multiple layers of defense against dirt and dust.
    Every AIRAID® Premium Filter is hand-built using the finest materials available today and each AIRAID® Premium Filter comes with a Lifetime Guarantee. We start with a multiple layer breathable media combined with our unique filtration technology resulting in a superior filtration system. All AIRAID® Premium Filters trap the smallest dirt particles that ordinary cotton-gauze “performance” filters can’t capture.
    LIFETIME GUARANTEE
    30 Dec 2014 05:45 PM
    AIRAID pre-filter for MAC4 Pumper System($30)
    AIRAID® Pre-Filters are highly recommended for applications that are used in extremely rugged environments. The AIRAID® Pre-Filters are manufactured from a durable water resistant polyester material. With uniform micro openings that filter out debris 5 microns and larger, dyno & flowbench testing has proven there is no significant loss in power or airflow using this product.
    http://www.ruggedradios.com/images/MAC-Air-Pumper/BLOWER-PREFILTER-4.5/BLOWER-PREFILTER-4.5-MD.jpg
    http://www.ruggedradios.com/images/MAC-Air-Pumper/BLOWER-PREFILTER-4.5/BLOWER-PREFILTER-4.5-INSET.jpg
    New Rugged Foot Pedal PTT!!! ($90)
    Go hands free with this innovative new push to talk button for your car to car system. Simply mount this foot switch PTT to the floorboard and say goodbye to the steering wheel PTT. Co-drivers can use this PTT to free up their hands to adjust the GPS, check course notes, operate dash switches, etc.. Rugged housing is splash resistant and designed to be durable under the heavy foot of any offroader.
    Cable length: 6' Compatible with: RRP357, RRP660, RRP686, and RRP 6100 Intercoms
    Available Now for $90
