Last Post 17 May 2018 10:46 AM by  thirdgenrx7r1
BOGART RACING WHEELS- 16" x 11" and 12" wide - 18lbs. each
thirdgenrx7r1
30 Aug 2017 12:19 PM
    For Sale- Bogart Racing wheels- 16" diameter.  Bolt pattern 5-114. They came off a 94 Mazda RX-7
    These wheels were previously powder-coated, they have now been stripped down to bare metal ready to build and customize to your specs.
    I have 6 outer shells, so I can custom build these wheels in a few different configurations.
    I have 2- 2.5" outer shells and 4- 3.5" shells. The inner shells are 8.5" wide.
    With these options you can get 2- 11" wide and 2- 12" wide or you could make a square set of all 4 - 12" wide... All in 16" diameter.
    The wheels have 2 different backspaces. They were built for a Front and Rear fitment on a 94 RX-7. They will clear stock brakes.
    - Backspace is - 7.75"  and 8.25"
    --- The wheels are apart and bare metal. I will powder-coat and build to your specs if you want. Or I can ship you the wheels in pieces and you can build however you want.
    Price-
    --- As-Is, Bare metal, all pieces- $1600
    ---Powder-coated and built to suit- $2200
    thirdgenrx7r1
    13 Sep 2017 09:57 AM
    Bump...Make an offer, we can make a deal!
    rande
    13 Sep 2017 07:12 PM
    Any way to convert the bolt pattern to 4x100?
    thirdgenrx7r1
    18 Sep 2017 01:16 PM
    The only way that would work would be to use a hub adapter if you had the room to space the wheels further out. That would allow you to use these 5x114 wheels on 4x100 hubs. Something similar to this...
    http://www.ebay.com/itm/2-4X114-3-T...1291263317
    Keep in mind this would space the wheels out another inch or so.
    Let me know if you have any other questions...
    wrandleman
    18 Nov 2017 02:44 PM
    I've got some interest in these for an NC MX-5 (5x114.3)
    thirdgenrx7r1
    wrandleman, Sorry I completely missed that last post... Hit me up if you still need it, they are still available...
    Thanks!
