Last Post 09 Mar 2016 03:37 PM by  Grintch
Camber Bolt Guidance on 05 STI
09 Mar 2016 11:54 AM
    I installed my Whiteline camber bolts (front) last night. I was at first going to put them in the lower strut mount, but to achieve negative camber, the directions say to have the large tab on the washing facing the hub. There is a (knuckle?) bolt there that it hits and will not sit flush with the strut mount. Any pros/cons to putting the bolt in the top mount? It seems it's not as adjustable then. Safety concerns? Possible to just put the bolt in the lower hole, but backwards (meaning put the bolt in from left to right vs right to left?
    The top hole is where the large and beefy stock camber bolt is. The hole is slotted on one side making it unsuitable for standard crash bolts.
    Reversing the direction of the bolt shouldn't be an issue.
