Last Post 09 Jan 2001 04:48 PM by  jrem72
Miata SSB
jrem72
08 Jan 2001 06:33 PM
    I am making the transition from a Neon to a Miata SSB car. Any info would be greatly appreciated.
    DHMichael
    09 Jan 2001 11:51 AM
    [QUOTE]Originally posted by jrem72:
    [b]Miata SSB car...Any info...[/b]
    Join the Mazda Support program. It will help financially and technically.
    [url="http://www.mazdausa.com/motorsports/racing/default.asp wrote:
    http://www.mazdausa.com/motorsports/racing/default.asp[/URL]
    You will want Hawk pads from the competition department. I would suggest "Blue". You will use two sets of front to 1 set of rears.
    I would suggest Hoosier tires.
    The K&N air filter is a good choice.
    - Michael
    jrem72
    09 Jan 2001 12:33 PM
    Thanks for the suggetions. How much time and what do you do to set your car up before a race? What seems to be the most important stuff to watch? etc.
    MiataRacer
    09 Jan 2001 12:41 PM
    I would suggest Kumho tires. You will get very good wear and they are good for quite a few heat cycles.
    The other info is on par. Congratulations on your choice, the Miata is hard to beat in SSB! Ask anyone not driving one.
    DHMichael
    09 Jan 2001 01:32 PM
    [b]How much time and what do you do to set your car up before a race? What seems to be the most important stuff to watch? [/b]
    I usually change the motor oil, plugs, set camber, front/rear toe, examine the rotors, and bleed the brakes as a minimum.
    I have gone through a few wheel studs believe it or not. I now carry a full set of spare studs, front and rear rotors, spare brake pads, and plugs. I have three sets of wheels. Two with dry tires and one with what I'll call my rain tires (actually they are just a set of RE730's until I can afford a set of real "wet" tires).
    The front runners and those with more dollars at their disposal probably have a better spares setup and may go about preparing their cars a little more before each race. I hope some of them will join in with their recommendations.
    - Michael
    jrem72
    I have 8 alloys and 4 steel wheels. Do you think I can get away with the steels for the rain tires. I have and abundance of Goodyears leftover from the Neon. I am planning on using them up before I get new tires. I also have a set of Toyo's which came with the car. I bought the car from Dave Moran in Colorado which was a Bob Schader car. It is a 96 red, does anyone know the car?
