Last Post 01 Jan 2001 05:51 AM by  Jesse Prather
31 Dec 2000 03:00 PM
    I have a FP Spitfire with no alternator. Right now I use a very heavy deep cycle battery. I would like to save some weight in this area. What is everyone else using? If you use a dry cell, do you need a battery box?
    Rick Edwards
    Jesse Prather
    I use a battery box that is mounted to the floor and then an Interstate MT-34 that I mount through the battery box and into the floor also. If you use a battery that has tops to check the cell fluid, which is what we use, you are required to put it in a box. We don't use alternators either, check and charge between each session, but don't over charge either. Use a battery hydrometer and a volt meter together. Good luck.
    G-Loc Button
