Last Post 10 Jun 2005 04:07 PM by  sccaITSsentra
Witch GT-40's For AS Mustang ??
Lerxst302
28 Oct 2001 12:56 PM
    I am gathering all of the info to build my new 302. I have a set of Iron GT-40's now. But, I am hearing alot of good things about the GT-40 "P" heads. I already know about the need for new headers. But what do you guys think would be the better choice ? I keep hearing about how well the "P" heads are doing in NHRA Trophy Stock. Thanx for any and all info !!!
    Wide Open 'Till You See GOD,,,,, Then Brake.
    Ken Grammer
    21 Nov 2001 08:20 PM
    Go to [url="http://www.asedan.com"]www.asedan.com[/URL] and subscribe to the Asedan e-mail list. You will reach more asedan guys on that list.
    Ken Grammer
    R.E. Alabama Region
    SEDiv AS Camaro #61
    Starter/F&C Worker
    sccaITSsentra
    09 Jun 2005 09:08 PM
    I belive a real gt-40 was an aluminum head, the P head is the only legal one, the real gt-40 was on lightning trucks and so fourth and had alot better flow then the P you can get the P heads of a ford exploder i think its 95-97 with the 5.0 junk yards sell em cheap if the motor is apart or you can get the whole assy and use it to build a motor. plus the intake,throttle body, etc is worth alot to an efi boy the gt-40 intake good for 10+ hp over stock 5.0 intake
    By-Tor
    10 Jun 2005 08:25 AM
    Thanks for the reply but I went with the "P" heads. I have learned ALOT since I posted this thread. The GT-40 heads were first available through Ford Motorsport SVO sometime around 1990 as a bolt on over the counter performance head and they were not aluminum. They were only available from the factory in the 1993 and 1994 Cobra. The aluminum ones are a different part number as well as a different casting called "Turbo Swirl". And yes the GT-40 does flow better than the GT-40P, BUT the P head makes more torque at the optimum spot for an A-Sedan spec motor. The P has better spark plug positioning promoting a better burn. I have heard from many good sources that the plug placement is a direct result of things learned in NASCAR racing. Since getting the motor all done and running a full season on it I gotta say I really like how the P heads work.
    sccaITSsentra
    yes all true I had lots of luck with the gt-40 p heads its an easy cheap swap and good for alot of power on street cars, I had a few stangs with those heads and like the performance alot
