Last Post 07 Jan 2001 01:55 PM by  SuperToy
Aligment after messing with coil over height?
01 Jan 2001 08:37 AM
    I am thinking about getting the ground control coil over set up. I figure it will work well in colorado because i can raise the car in the winter and slam it in the summer. Will i have to get an aligment after i mess with the ride height?
    1994 Polo Green Camaro
    3.4 SFI M5
    SS Exhaust, B&M Ripper, Z28 Swaybars, Accel, Commando wing, Energy Suspension, Jet, and Ground Pounding Stereo
    Eric37
    02 Jan 2001 02:51 PM
    I was thinking about doing the same for my Subaru. I imagine you should get your alignment done if you drastically alter your ride height. I would probably get mine done right before autocross season, with the car lowered, then again after the season, with it up. But we're only talking about an inch off stock either way, at least that's the way I was going to go.
    '00 Subaru Impreza 2.5RS
    '00 Acura Integra Type R
    dplore
    04 Jan 2001 07:45 PM
    Changing ride height will change your alignment. For example, raising it will give you more positive camber, lowering will give you more negative camber. Toe, caster and bump steer will also be affected.
    -Darren
    SpecRX7 - [url="http://s7.nu"]http://s7.nu[/URL]
    Colorado Region - [url="http://coloradoscca.org"]http://coloradoscca.org[/URL]
    EP RX7 #96
    SuperToy
    I had to do that when I gave my Taco a lift... If you dont do it..You will get new tires every 2 months.... Not good..
    Dave
