Last Post 06 Jan 2005 11:44 AM by  planet6racing
engine mounts in ITA?
Quattro Jeff
28 Dec 2004 09:00 AM
    I just reviewed the '05 rules and it appears that you are not allowed to use aftermarket engine mounts in ITA. Am I correct?
    There is a note that allows "one engine stay". Could someone explain this a little better for me?
    x-ring
    06 Jan 2005 10:11 AM
    I think that for '05 the CRB added a rule to the ITCS allowing exact replacement aftermarket parts.
    I don't have a GCR handy to check.
    planet6racing
    If by aftermarket you mean Performance (i.e. non-stock), then you are correct, you cannot (and never have been able to) use aftermarket performance motor mounts.
    If you mean aftermarket (as in Napa, AutoZone, etc), then as long as they are the exact equivalents, you are fully allowed.
    The engine stay rule, as I interpret it, is essentially an additional mount that you can put where you want, except for replacing a stock mount. Check out the IT forums at http://www.improvedtouring.com/chat2 for more information (and faster responses).
    SPS 88x31 Button
