Last Post 14 Apr 2006 12:12 PM by  rmyers
Use of Torque arm suspension in ESP and SM
Tom Slick
13 Apr 2006 11:28 AM
    I need to find out some information for someone I know as well as myself. This person I know has a 2001 mustang (bullitt) the car has factory bolt in subframe connectors. He is wanting to add a torque arm suspension to his car and run in ESP. The type of torque arm he is wanting to use is made by maximum motorsports http://maximummotorsports.com/panha...talled.asp which uses a member that ties the two subframes connectors together which I read the rules for SM doesn't allow for lateral connection between the connectors or am I mistaken, can be allowed to add the torque arm in these two classes? Can you please clarify this issue.
    Tom
    13 Apr 2006 11:59 AM
    Tom,
    Hopefully Andy will pipe in with his opinion on this. It seems as though the generally accepted premise as that adding the MM Torque arm provides lateral connection and therefore is illegal, requiring something like the Griggs with a floor pan mount.
    If it were my car, I'd be willing to install the MM against the factory sub frames and see what the protests bring. My claim is that the 3/8" bolts in a pivot mount that hold the TA cross member to the Sub frame connectors are not providing lateral stiffness.
    Keep in mind that I don't run Nationally in ESP/SM, nor have I analyzed this issue in several years and things may have been clarified either way since.
    A Steeda 5 Link is legal. :)
    HTH,
    carlakacarlos
    14 Apr 2006 11:26 AM
    Steeda 5-link FTW!!!
    rmyers
    Tom,
    You have correctly read the rules. I currently run the MM torque arm in ESP. I solved the issue by fabrication of a bracket utilizing the rear seat bolts of the front seat on each side. Seems to work so far. I have a '97 Cobra and the transmission crossmember already ties the two rails together approximately 12" forward of the MM part. If I only drove well enough to be protested!! I know the '99 and up cars only have a short trans crossmember up in the tunnel.
    The Steeda 5 link is legal and works as well if not better than the MM parts. I just prefer the torque arm setup.
