Last Post 21 Aug 2006 05:19 PM by  fenter
FS: Energy Suspension Formula 5 Lube
fenter
08 Aug 2006 12:15 PM
    FORMULA 5 Prelube
    "Formula 5" Prelube is a versatile, waterproof, non-melting grease containing teflon. It forms a tough, durable, chemical resistant film of lubricant. Prevents metal-to-metal contact even under severe shock loads. Only a small amount is required to properly lubricate bushings and metal components and to prevent corrosion.
    http://www.energysuspension.com/pages/univ1.html
    This stuff works great on poly bushings! I bought this lube at the beginning of the year not realizing how large the containers were. 8oz is a lot of lube, I only needed one! I have 2 additional tubs remaining.
    I can bring it to any Milwaukee or Chicago event so no shipping should be required.
    $12 each
    Chris Fenter
    fenter
    09 Aug 2006 09:54 PM
    I just recieved a PM from Mike, so one of them is gone.
    Thanks!
    John P
    14 Aug 2006 02:32 PM
    Just saw this post and thought I would mention this stuff works wonders on Poly bushings. I had some Poly bushing that would get loud and squeek like crazy after only 3-weeks with valvoline synthetic lube. This stuff has kept the same bushings quiet as stock for 8-months so far.
    fenter
    18 Aug 2006 02:29 PM
    I agree entirely John P. I have tried other lubes for my bushings and this is the best I have found.
    Thanks for the input!
    Chris
    Zauskycop
    21 Aug 2006 03:22 PM
    Chris, I will grab that other tube off of you. If you plan on coming to the Labor Day twins I will take it off of you then???
    fenter
    Sounds good Tracy! I will be planning to attend the Twin. That reminds me, I should make sure to register before it fills up...
    Take care,
    Chris
    SPS 88x31 Button
