Last Post 06 Nov 2006 07:05 PM by  ITRacer07
switch from SOHC to DOHC engine in ITA Neon?
JeffS
31 Oct 2006 05:20 PM
    I'm having a little trouble interpreting the update/backdate rules on this subject. Any insight or opinions would be appreciated.
    Currently, I am running a '95 Neon ACR sedan in ITA. this car was only available new as a SOHC since it was a sedan, but IIRC, there were a few '95 Neons sedans produced with DOHC engines (I have a VIN to support this). In the later years ('96-'99), there were plenty of DOHC sedans.
    I am interested in utilizing the DOHC engine in my car per update/backdate. Assuming that I changed everything over and adjusted the minimum weight to 2650, would this be a legal change?
    thanks,
    ITRacer07
    The SOHC and DOHC are on 2 different spec lines. This means that the DOHC Vin should be on the DOHC car. IF you just drop the DOHC in the SOHC car it would be illegal.
