AspireTec Engineering  468
Last Post 09 Jan 2008 06:36 PM by  KW78
2002 Orange #78 Mustang for Sale
KW78
29 Oct 2007 09:31 PM
    Leading 2006 Runoffs at HPT:
    KW78
    29 Oct 2007 09:35 PM
    Hey All,
    <!--[if !supportEmptyParas]--> <!--[endif]-->
    After painful deliberation I have decided that finances force me to sell my AS car.
    Instead of massive list of all the good parts, I wanted to talk about how the car was built. The new owner will be getting a compilation of some great engineering and workmanship of some top notch folks.
    I know that if someone called up 3R Racing and Fab here in Denver (Tommy Archer Vipers, World challenge pro prep shop, Porsche cup cars) to duplicate this car (and skip all R&D) that it would be a $60,000 bill. I use 3R as the example, because we’ve employed some of the same people and one of their aces was heavily involved in the construction of this.
    The car started as a new 2002 body in white from Ford, which was not cooked. This means the undercoating and seam sealer was not stuck on the vehicle. We picked the lightest combo of body panels, hood, and trunk and brought it home.
    Since I was driving a competitive Fox chassis, we were not in a hurry and took a very deliberate approach with the goal of building the best legal AS car possible. We (myself, a great independent machinist, a super talented fabricator/welder, and 2 race engineers, all heavily involved in SCCA) took the current 04-05 rulebook, and rule-by-rule maximized the car for rigidity, weight savings, low CG, reliability, and speed. The examples of this are endless, right down to the angles picked for a given cage mounting plate. Cage analysis software and Mitchell’s suspension software was well in the mix also (Mitchell even wrote strut software for us).
    This chassis has a smartly built minimum weight/maximum stiffness AS cage, integral sub frame connectors laid in the frame (Ala north American touring car) that is a very stiff and square package.
    This has gone thru several rounds of R&D for front suspension, and much more for the rear suspension. 3 front strut packages, and days of shock package building. We have moved front and rear roll centers around (legally!) for maximum benefit, and tuning. The 4th and final rear suspension package is based on an angle adjustable “floating” torque arm and a Mumford link that keeps the rear roll center centered and nearly fixed regardless of body roll, squat, etc, and adjustable in height from BELOW ground to axle centerline. The front suspension has a very small scrub radius, and multipiece front offset bushings.
    This car handles amazingly and is very tunable to track surface, conditions, and driving style. The ultimate result of this can be seen in the excellent even tire wear from all 4 corners. REAR weight balance (all important in the sedan world) can be up to 52% for a 180# driver, finishing a race at minimum weight.
    This vehicle holds numerous track records throughout RMDIV, and also some more notable ones like Miller Motorsports, Phoenix International, Mid-Ohio Runoffs Qualifying record, MAM.
    It has led several runoffs at Mid Ohio and Topeka (briefly, see Asedan Banner!) and taken a 2nd at the June Sprints. It was on the pole with a pole qualifying record at Mid Ohio.
    OK now for the parts list:
    <!--[if !supportLists]-->Ø <!--[endif]-->8 Kodiak 3piece wheels, their lightest design.
    <!--[if !supportLists]-->Ø <!--[endif]-->Light Wilwood aluminum hat, rotor assemblies F&R
    <!--[if !supportLists]-->Ø <!--[endif]-->Driver adjustable brake proportioning for Left and Right fronts, and rear
    <!--[if !supportLists]-->Ø <!--[endif]-->Freshened Tremac Transmission
    <!--[if !supportLists]-->Ø <!--[endif]-->Freshened Gold Trak diffential
    <!--[if !supportLists]-->Ø <!--[endif]-->Lightened Ring and Pinion
    <!--[if !supportLists]-->Ø <!--[endif]-->Mosier axles in a Cambered rear differental, w 9” bearing ends
    <!--[if !supportLists]-->Ø <!--[endif]-->4 Light Springs on adjustable perches
    <!--[if !supportLists]-->Ø <!--[endif]-->Custom rear light adjustable sway bar
    <!--[if !supportLists]-->Ø <!--[endif]-->Custom front adjustable sway bar
    <!--[if !supportLists]-->Ø <!--[endif]-->Custom valved Bilstein front struts
    <!--[if !supportLists]-->Ø <!--[endif]-->Custom valved, very trick internals Ohlins rear remote reservoir shocks
    <!--[if !supportLists]-->Ø <!--[endif]-->New CR radiator
    <!--[if !supportLists]-->Ø <!--[endif]-->Fresh Alternator, Battery
    <!--[if !supportLists]-->Ø <!--[endif]-->Ultra Light pressure plate, clutch, and custom center mass SFI flywheel.
    <!--[if !supportLists]-->Ø <!--[endif]-->Logging TechEDGE wide band O2 sensor, with 3 EGTs, tach input, and 4 analog inputs
    <!--[if !supportLists]-->Ø <!--[endif]-->Tri-ax Steeda shifter
    <!--[if !supportLists]-->Ø <!--[endif]-->Twin corner submerged corvette electric fuel pumps in fuel cell
    <!--[if !supportLists]-->Ø <!--[endif]-->Fresh fuel cell foam
    <!--[if !supportLists]-->Ø <!--[endif]-->400+ HP motor
    <!--[if !supportLists]-->Ø <!--[endif]-->Barry Grant Carb
    <!--[if !supportLists]-->Ø <!--[endif]-->Longtube equal length headers, merge collectors, Dr Gas X-pipe, Stainless Aeroturbine mufflers
    <!--[if !supportLists]-->Ø <!--[endif]-->Custom pulley and belt setup for proper waterpump RPM.
    <!--[if !supportLists]-->Ø <!--[endif]-->Canton road race Pan
    <!--[if !supportLists]-->Ø <!--[endif]-->Accusump
    <!--[if !supportLists]-->Ø <!--[endif]-->Light starter
    <!--[if !supportLists]-->Ø <!--[endif]-->DUI ignition (ultra! Reliable)
    <!--[if !supportLists]-->Ø <!--[endif]-->MSD adjustable Rev Limit
    <!--[if !supportLists]-->Ø <!--[endif]-->Full Instrumentation: oil, water temp, water press, fuel press, warning lights, tach, shift light, brake pressure gauges, hours meter
    <!--[if !supportLists]-->Ø <!--[endif]-->Military spec lit switches
    Also, we freshen this car for the runoffs, not in the off-season. Everything was gone thru for Topeka, including fresh shock oil.
    This car is at the beginning of a maintenance cycle, not the end of one.
    More info and pictures available. It is only fair that many specifics will only be available to the buyer. As part of the final arrangments, a test drive at a local track is welcome. Also, delivery is possible.
    Also I should mention this car has never been wrecked. Yes, we’ve done some rubbin’ needing fender work or a bumper cover, but for reference, this has never been hit or had an off that even changed the alignment.
    Asking $33000
    Please Email me at Kyle sensibleautomotive com if interested.
    Kyle
    KW78
    22 Dec 2007 02:30 PM
    Still available. Price reduced, car needs to go to make banker happy.
    Kyle
    KW78
    Still available!
    Here is the car in action:
    2005 runoffs start
