Last Post 29 Nov 2017 02:13 PM by  capvid86
FS: 1988 Honda CRX Si ITA Race Car w/ Spares- Revised
capvid86
05 Dec 2007 10:28 AM
    Please contact me if you have any questions or to get updated parts & spares lists.
    Full Roll Cage w/ NASCAR Driver Doorbars, Harness mounts & seat bolt directly to cage, Phoenix Halon 1301 Fire Suppression System, Roll Cage-Full 8 Point Triangulated & Reinforced, Welded in Sunroof Panel-Repainted Roof, UHF Radio Antenna w/ Harness, Complete Brake Upgrade F/R-90/91, S/S Brake Lines F/R, Used T.C.Kline Engine-Balanced & Blueprinted, RC Matched Injectors, Mugen Engine Mounts and Bushings Throughout, Oil Coolers- 2 Front Mounted, Aeroquip Lines, Remote Firewall Mt'd Oil Filter for Fram HP1/PH3, Oil Temperature Gage, Oil Pressure Gage-mechanical w/ Aeroquip, Voltage Gage- VDO, Coolant Pressure Gage-Aeroquip, HalTech Air/Fuel Gage, New Lightweight Battery, OPM 4 into 1 Header-JetHot Coated, SuperTrapp Muffler, Factory Service Manual, SCCA Log Book, SCCA AMB Transponder, Carrera Adjustable Aluminum Threaded Spring Perches, Carrera Aluminum 5 way Adjustable Shocks- 5 way-All Fresh Rebuilt, Carrera Springs-400F/600R, DC Sports Frt. Strut Brace, HD Aluminum Rear Sway Bar Mounts, Honda Factory IMSA Firehawk Gas Tank, Honda Factory IMSA Firehawk ECU Computer, New Honda OEM Clutch, Fresh Transmission Rebuild w/ New Axle Seals & Main Shaft Seals, Houseman Machine Final Gear Set, OPM Limited Slip Differential, Heat Treated Front Hubs, Frame Straight-Never Damaged-Corner Weights Well, Revolution Light Wt 14x7 Wheels w/ Kumho Victoracer Shaved Tires-Set of (4), Revolution Std Wt 14x7 Wheels w/ Toyo Proxes Full Tread Rain Tires-Set of (4) and (1) Spare Toyo Proxes Full Tread Tire Only, OEM Steel Wheels w/ old Tires for Shop Rollers
    HERE IS LIST OF SPARES INCLUDED: Battery Tiedowns, Battery Tray-OEM Steel, Brackets, Cigarette Lighter Socket, Crank Bolt Fender Plugs, Front Bumper Marker Lights-88/99, Front Bumper Marker Lights-90/91, Front Wiper Motor, Fuel Gauge-OEM, Gas Cap, Horns, Nuts and Bolts, Rear Cross Member Reinforcement, Relays, Plugs, Switches, Side View Mirrors LH & RH, Caliper Bolt Bellows, Caliper Line Crush Washers OEM# 46472-568-000, Calipers Front LH & RH- Reman.-90/91, Brake Discs-Frt-Recut(10), Brake Discs-Rear-(2), Front Caliper Bleed Bolts 90/91, Front Caliper Piston Modified 90/91, Front Caliper Pivot Bolts 90/91, Front Caliper Rebuild Kit 88/89, Front Caliper Rebuild Kit 90/91, Master Cylinder-88, Master Cylinder Outer Seal OEM# 46185-SE0-003, Power Boosters, Proportioning Valve-88/89, Race Brake Pads- Frt- Most New or Just Bedded (8 Sets), Race Brake Pads- Rear- Most New or Just Bedded (4 Sets), SS Brake Lines Rear - 88/89, Coolant Catch Tank, Heater Hose w/ Valve, Radiator Cap, Radiator Plug, Water Pump, Alternator, Alternator Belts, Distributor Cap Gasket Sets OEM# 19222-634-000, Distributor Ignitor, Distributor O Ring OEM# 30110-PA1-732, Distributor Rotors, Distributors, ECU Computer 88 CRX-Si, Radiator Fan, Spark Plug Wire Set, Starter Motor-89, Engine Block-Oversize Bored Cylinders, Engine Block Long Assembly-Complete, Cam Belt Cover-Lower, Cam Belt Cover-Upper, Cam Sprocket, Cam Sprocket Cover, Clutch Friction Disks-Misc, Clutch Pressure Plate -Misc, Crank Pulley-88, Dipsticks, Exhaust Hangers, Exhaust Manifold Gaskets-OEM Steel, Exhaust Tips and Downturn, Fly Wheel Dowell Pins, Fuel Filter, Fuel Injector Set-OEM, Head-Complete, Head Seal Kit, Head Valve Seals, Intake Manifolds (2), Intake Manifold-Modified, Intake Manifold Gaskets-OEM, Oil Pumps (2), Oil Pan Drain Plug, Steel Coolant Bypass Pipe, Thermostat Gasket, Thermostat Housing-Modified, Throttle Body, Throttle Body-Modified, Throttle Body Gaskets, Throwout Bearing, Valve Cover, Valve Cover Gaskets, Valve Cover Spark Plug Seals, Valve Cover Stud, Valve Cover Stud Seal, SuperTrapp Disk Set, Alloy HT Front Hub, Axle Boots, Bushings, Carrera Shock Parts, Control Arms-Front, Control Arms-Rear, Control Rods-Forward Front, Front Axle Nuts, Frt. Knuckle Ball Joint, Frt. Knuckle Ball Joint Covers, Frt. Swaybar Bushing Brackets, Knuckle Assemblys, Knuckle Assembly w/ HT Alloy Hubs, Lower Control Arms-Rear-88, Misc. Swaybar Bushings, Rear Sway Bar Bushings, Rear Swaybar Bushing Brackets, Shock Alum. Carrera-Spare Front, Shock Alum. Carrera-Spare Rear, Trailing Arms Rear-88- L&R (2 w/ Drum Brakes), Swaybar Connector Parts, Tie Rod, Upper Control Arms-Front, Upper Control Arms-Rear, Upper Shock Mounts-Modified Set, Wheel Lug Nuts, Wheel Studs, Wishbones-Front-L/R Sets, Axle Boot Clamps, Axle Snap Rings-OEM# 44319-SA2-000, Differential Bearings, Shifter Rod Spring Pin, Shifter Shaft Seal OEM# 91208-PB6-005, Speedometer Cable Firewall Boot, Speedometer Gear, Speedometer Gear O Ring, Transaxle-LH&RH, Transaxle Transport Tube-LH&RH-PVC, Transmissions Complete-Basket, Transmission LSD-OPM-included in Basket, And Many More Bits & Pieces!!!!!!! Vehicle may need minor updates to meet current rules depending on sanctioning body.
    Priced to Sell at $4,995.00 OBO
    PayPal accepted.
    Extra Revolution Light Weight Wheels / Race Tire Sets and other Honda parts also available.
    Located in Jacksonville, FL
    Thanx for looking!!
    capvid86
    08 Dec 2007 12:57 PM
    Price Drop!!!
    capvid86
    10 Feb 2008 04:56 PM
    Priced Drop To Sell !!!
    Listed on eBay:
    capvid86
    19 Feb 2008 09:51 AM
    Car tentatively sold.
    I will update when final.
    capvid86
    22 Feb 2008 02:20 PM
    Car and all spares sold.
    Still have:
    (8) Revolution Lightweight 5-Spoke 14" x 7" wheels with worn Toyo Proxes tires.- $600/ set of 4
    Photos of wheels on 'sold' car: http://www.flickr.com/photos/211040...256851685/
    (4) pc set of OEM 1988-91 Factory Aluminum Wheels & Caps, 14" x 5.5", Bare, Very Good Condition- make an offer.
    capvid86
    Everything is sold.
    Thank you.
