Last Post 12 Sep 2008 11:14 AM by  StewartDevelopment
Spec Miata Shock Blueprinting Service
StewartDevelopment
    Don’t let a defective or “out of spec” shock ruin your efforts. Professional racers won’t run a lap with shocks that have not been “verified” on a dyno.
    Under approval of Spec Miata, Stewart Development is now providing repair and dyno service for all Bilstein Spec Miata shocks. Standard service includes seal and suspension fluid replacement along with dyno testing. A graph of the damping values will be provided for each shock to document that they are performing properly and within spec.
    Utilizing the most advanced equipment in the industry, Stewart Development is able to remanufacture your shocks to factory specs, and within the rules of your sanctioning body. The shocks are reassembled the same as at the Bilstein factory with no external modifications.
    With years of experience in all forms of racing from NASCAR to IHRA, Stewart Development has the expertise to help you make sure your suspension is performing correctly.
    www.StewartDevelopment.com
