Last Post 16 Oct 2008 03:45 PM by  mavisky
Time to move onto a new project, making room, car for sale as is.
mavisky
22 Sep 2008 10:41 AM
    I've had this car since October of 1998. I've slowly built it from a bone stock 2.0 into the wild ride you see before you now. The car's won a bracket racing class at the 2002 DSM Shootout, Placed 9th overall and 1st place Team Domestic at the Winged Warrior II challenge ([url]www.wingedwarrior.net)[/url], and has since competed at multiple autox events doing the best it can to fend off those pesky awd's. Bottom line is that I'm just itching for a new project and can't afford to keep this around. The car is full of custom and one off modifications and now is your chance to take my place and take this car to the next level. You cannot buy a better modified fwd car for this price.
    Current mods:
    Engine:
    2.0 4G63T
    2.0 NT throttle body
    TD05H-18G Turbo
    HKS 272's
    ARP Head studs
    Upgraded turbo outlet elbow
    Balance shaft removal
    90 oil filter housing
    Diamond Star Motorsports oil cooler
    Forced Performance turbo oil feed line
    B&M power steering cooler
    Energy Suspension Polyurethane motor mounts
    Nissan 300zx TT radiator cap
    Mishimoto Aluminum radiator
    Mishimoto single radiator fan
    Dual stage electronically switched mbc (17psi in 1st and 2nd gear, 20+ in 3rd through 5th)
    Custom catch can below battery
    Intake:
    Custom upper ic piping
    Custom lower ic piping
    Dejon Powerhouse intercooler
    HKS SSQV blow-off valve
    Custom intake pipe
    2.5" inlet K&N filter
    Exhaust:
    2g ported exhaust manifold
    2g O2 sensor housing
    2.5" Buschur Racing downpipe
    2.5" Buschur Racing test-pipe
    2.5" Custom side exit utilizing dynomax mufflers
    Electronics:
    Maft v 2.0.1
    GM 3" MAF
    Custom chipped eprom ecu with injector compensation, NLTS, and 4500rpm studderbox
    Autometer Pro-Comp EGT
    Autometer Sport-Comp electric oil pressure on -4an remote mount
    Autometer Pro-comp boost 30-0-30
    HKS Type-1 turbo timer
    Palm M100 runinng Pocketlogger software
    Longacre water temp warning light
    Longacre oil temp warning light - missing sending unit
    Longacre oil pressure warning light mounted on -4an remote mount
    Fuel System:
    Re-wired Toyota Supra fuel pump
    SX adjustable fuel pressure regulator
    FIC 650cc injectors
    Suspension:
    17x9" Mustang FR500 wheels
    275/40-17 Falken Azenis RT-615 tires
    Hawk HP+ front pads
    Akebono Pro Ceramic rear pads
    dual piston brake upgrade
    Earl's stainless steel braided brake lines
    Aftermarket power steering cooler
    Custom Re-inforced rear panhard bar
    Disturbed racing coilovers utlilizing:
    Koni Yellow shock absorbers
    Hypercoil springs
    Disturbed Racing caster/camber plates
    Eibach camber bolts
    Energy Suspension Polyurethane suspension bushings
    Suspension Techniques adjustable rear swaybar
    Megan Racing front strut tower brace
    Megan Racing rear strut tower brace
    Transmission:
    91 FWD GS-Turbo transmission
    Centerforce Dual Friction pressure plate
    Stock replacement disk
    Phantom Grip lsd
    Phantom Grip Race Springs
    Skate board bearing mod on shift cables
    Solid bushings on shifter base
    Interior:
    Corbeau Forza driver's seat
    Modified factory passenger seat
    G-Force 5 point camlock harnesses
    Carbontrix 3 guage pod
    Custom Palm M100 mount
    Galant VR4 shift knob
    Custom gutted but carpeted interior
    Exterior:
    Fiberglass intake scoop for passenger side headlight
    Vis Invader carbon fiber hood
    JNZ mirror blockoff plates
    Carbon fiber convex mirrors from a Formula Ford
    Front bumper vents to feed radiator
    Rear bumper vents to reduce drag
    Red front tow ring
    Hidden mounts for front splitter
    Graphics by Tom at Signs & Wonders
    Graphics install by Michael's Tint
    The car can be seen in last year's 2007 DSMTuners calendar as well as the 2008 DSMTuners calendar.
    The Bad:
    Currently the clearcoat is peeling on the rear hatch and wing. Obvious small scratches and scuffs from hitting cones at 60mph. Left front bumper was torn after catching one really bad, still visible but has been fiberglassed from behind so is structurally sound and not noticeable from 20feet or more. Hood has small hole from beta testing suspension components. Trans grinds going into 5th, needs new synchros. Extremely easy to install, I even have brand new locking nuts for the trans. Was going to do it next time the trans came off but never got to it. Engine is down on power, after it's last event in May I brought it home and the cold compression numbers were #1-125 #2 -110 #3 -75 #4 -120. This was a 3 year old motor that I did a very very basic rebuild so I'm not surprised to see this after the abuse it's seen. Block is still clean and with some new rings it would probably be fine. That last outing yielded a 14.5 @ 96mph on pump gas and 20psi (car has gone 13.1 @ 112.4 on pump gas before the cams, pump, chip, wheels, tires, suspension, and further weight reduction). O2 sensor and bung are stripped out.
    As it sits it still runs, just down on power. I decided to stop racing it this year to keep the motor from any further damage but just last month it fired right up, backed down the drive, and had no issues whatsoever. I daily drove this car from May til November in 2007. Still has front speakers along with cd player. Cruise and Heat are still functional. Nearly every part of this car has come off, been cleaned, replaced, or improved over the course of the last 10 years. Selling the car as it sits for $6000. If you think that's too much, fine, don't post. I'll just hang onto it and fix it and re-list it for more later. Most of you though should see this as a great opportunity to steal this car.
    Title in hand - no test drives - no payment plans. Cashier's check and you get the title once it clears the bank or you can feel free to show up with a stack of bills.
    FMIC
    Headlight intake - comes with matching driver's side and marker lights.
    Carbon fiber mirrors and JNZ blockoff plates
    Interior showing carpeted rear section, camera mount, guage pod, warning lights, and palm pilot holder.
    Another shot of the camera mount and carpeted rear interior
    B&M oil cooler
    Mount for front splitter
    Longacre warning lights
    Disturbed racing coilovers (Hypercoils on Koni's)
    Contact me via e-mail at beavemavis@gmail.com if interested. Only interested in trades for clean or swapped 70-78 240z, 260z, 280z cars.
    mavisky
    Willing to entertain reasonable offers. Please e-mail beavemavis@gmail.com .
