AspireTec Engineering  468
Last Post 02 Apr 2009 05:15 PM by  Deviousfred
Wheel and Tire size recommendations
Deviousfred
31 Mar 2009 11:10 AM
    Hey guys and gals. I'm hoping to come out the beginning of next year and start out in the rookie class. My car should be about ready in December or January.
    I'm here looking for some advice on wheel and tire size recommendations.
    My car is a 1965 Mustang Coupe which modifications include:
    Front Suspension:
    Global West Tubular Upper Control Arms with Negative Roll System
    620lb coil springs
    1 1/8" sway bar
    Manual steering box with Shelby Quick Steer Pitman and Idler
    Poly Bushings on everything
    Pro-Motorsports Bumpsteer Kit
    Rear Suspension:
    5 1/2 leaf mid eye springs (rated at 300lbs I believe)
    Poly shackles
    3/4" sway bar
    Chassis:
    Subframe Connectors
    Chassis Stiffener
    will be adding a minimum 8 point cage
    Powertrain:
    Slightly modified 302 (5.0)
    5-Speed Manual trans
    9 inch rear end with 3.70 gears
    will be adding a locker or limited slip diff soon
    Brakes:
    Currently 4 wheel disk swap but looking to upgrade to Wilwood 11.75" front Dynalite Pro Series and 11" rear
    I'm looking at some 15" steel wheels, specifically Cragar Soft 8s. 15x7 front and 15x8 rear.
    Should I be looking at 16 or 17 inch instead for the SOLO events?
    Fred
    VettesRule
    02 Apr 2009 12:41 AM
    With all the modifications to stock you have done I would recommend that you plan your class after sitting with the rulebook. After you have your class in mind, make some templates that will give you a better feel about what will fit and then get the lightest wheels inside the Hoosier A6 autocross tire.
    Hope this helps!
    Deviousfred
    Looks like it is going to be street modified. Handling wise, would you recommened I try and go with a 15, 16, or 17 in wheel?
