Last Post 07 Jun 2009 02:11 PM by  OneEyeMedia
WTF Honda! 90 front brakes...
    OK, WTF :(
    So I have to do this to change brake rotors and pads huh? What engineer thought this up?
    Remove brake caliper assy with mount
    Remove CV shaft main nut.
    Disconnect lower arm ball joint.
    Pull out CV shaft from hub.
    Remove 4 pcs bolt from nehind knuckle.
    Tap out the bearing assy with hub and rotor.
    Remove rotor holding bolt and rotor can be removed from hub.
