Last Post 04 Nov 2011 10:14 PM by  Han Solo
Road course spindles for late model stockcar
Han Solo
04 Nov 2011 04:29 PM
    Not sure if this is the right place to inquire.
    Where do I get road course spindles for a late model stockcar? What info do I need to source them. This is a townsend chassis with stamped steel big spring lower control arms and 5x5 hubs.
    04 Nov 2011 05:27 PM
    There are several places that are a bonanza for stock car parts......
    www.colemanracing.com
    www.lefthanderchassis.com
    www.stockcarproducts.com
    I am a web type of guy, but it is worth getting a catalog from the first two. I haven't done much with SCP lately (since they became Carls) I only mention them because IIRC they had an unmachined cast spindle that looked decent.
    Do you know what is different in your spindles from side to side? I always thought they did the offset in the control arms. Are they fabricated or cast/forged?
    HTH,
    Han Solo
    04 Nov 2011 09:40 PM
    These are fabricated. For one thing the spindles are at different heights on the left and right. I assume the left has some positive camber built in looking at it and the way most left hander spindles I've seen are. The control arms measure the same left and right. I don't like the uppers because the ball joint is angled downward and looks like it's at the end of it's travel with the front jacked up. I will most likely replace both spindles and upper control arms at minimum.
    Thanks for the links. I think I've already checked those out but I'll look them over again.
    04 Nov 2011 10:11 PM
    Not sure if it is relevant, but I used Coleman's fabricated asphalt spindles on my car.
    IMO you might want to put all the measurements in some kind of suspension analyzer program so you know what you are changing. It doesn't take too much change to really dick up roll centers and such.
    Also remember that you will need much less travel than they would on dirt.
    Han Solo
    I should be able to put something together from here if I can figure out which parts I need.
    http://www.colemanracing.com/Spindl...P3706.aspx
