Last Post 21 Mar 2012 09:56 AM by  viccath5@yahoo.com
ST tire information
edrice
14 Mar 2012 01:36 PM
    Andy Hollis has done some in-depth testing of different tires that can help you make a decision on which tire is best for your car and conditions.
    http://www.facebook.com/notes/holli...8598916447
    E30bulldog
    16 Mar 2012 03:22 AM
    good read Ed...so running a 225 rs3 on a 7" wide rim is bad :)...maybe I need to be like you and get some 9"s
    cmt52663
    16 Mar 2012 04:17 AM
    from 1st hand experience... running the 225 rs3 on kosei k1 15x7 is bad, and also running the 225 R1R on that rim is also bad...
    two seasons invested in stubbornness, and even my hard head had to admit that the outcome was clear
    i'm headed to 15x8 personally. enough!
    edrice
    16 Mar 2012 07:37 AM
    Gene you are a true artist at the wheel and a exception to every rule. For you discussing the technical aspect of the car to find a explanation for great results would be like asking Ernest Hemingway what brand of typewriter he used to make him such a good writer. :)
    tgeorge
    16 Mar 2012 09:29 AM
    Nice analogy Ed.
    DJF1GP
    16 Mar 2012 10:01 PM
    great article, need to add a section entitled " what to do when you're on cords and your rs-3's are on backorder until may:" , i could sure use help with that lol
    tgeorge
    17 Mar 2012 10:46 AM
    you could try other suppliers like treadzone.com. They sell alot of hankooks. edited: looks like they have them for $128.00 each thats $10 cheaper than tire rack.
    edrice
    19 Mar 2012 06:36 PM
    Thanks for the link, they sold their last a set of 15" RS3's on Thursday but had two left and I bought them.
    They say June for the next shipment.
    vtecyo
    20 Mar 2012 12:00 PM
    Eric Trigg is selling a set of 15" rs3s...
    http://gulfcoastregion.proboards.co...amp;page=1
    E30bulldog
    21 Mar 2012 02:01 AM
    hmmm..... I needs them....so tempting
    July! REALLY! mine are almost donesky
    viccath5@yahoo.com
    Good information!
    With my RSX, I have always set front tire pressures to run to the pointers molded in the tire. With the Star Specs I just finished with that ended up being 38 psi on a warm dry day. I just ran my first event on the new RS3s and found I needed 39 psi to run right at the pointer. The article indicated much lower pressures worked well on the RS3s. Should I not use the pointers as a guide and instead explore the limits beyond the pointers? I run -2.6 camber on the front with 400 psi springs, although I suspect I could use more static camber.
