The MAC is recommending Legends cars in FMod-from March Fastrack
"The MAC is recommending the following rule change proposal (ref. #2231), which is being published here for member
feedback:
- Add the following new section 18.6:
18.6 LEGENDS AND DWARF CARS
Vehicles conforming to the US Legends Cars International racing series specifications (
http://www.uslegendcars.
com), with exceptions and requirements as noted in Appendix A, are eligible to compete in Modified Class F.
Vehicles conforming to the Western States Dwarf Cars Association specifications (
http://www.dwarfworld.com/
WSDCA-07.html), with exceptions and requirements as noted in Appendix A, are eligible to compete in Modified
Class F.
- In conjunction with the above, add the following in Appendix A, Modified Class F (current section D should be increased
one outline level to be under item C):
D. Dwarf Cars and Legends/600Racing Cars
Vehicles built and prepared to Western Dwarf Car Association or United States Legend Cars International
specification are assigned to class F Modified.
NOTE: If any conflict exists between the Dwarf Car Rules or US Legends Rules and the Solo Rules, the Solo Rules
shall take precedence
Cars prepared to these specifications are required to comply with the appropriate rules from their sanctioning body,
except for the items listed below:
SCCA FasTrack News March 2011 Page 14
Any tire (including recaps) meeting the applicable portions of 3.3 are allowed.
Any differential and rear end ratio may be used.
Any shock absorber may be used.
Any wheel up to 10” wide and any diameter may be used.
Any anti-roll bar may be used.
Engine does not need to be sealed, but must conform to the appropriate rule set.
Minimum Weight – 1250 lbs with driver.
Any air filter is allowed.
Any ballast is allowed provided it is mounted securely per Solo rules.
Any battery may be used.
Dwarf Car or Legends specific items not required are as follows:
INEX Approved Manufactured Metal Seat. Mounting guidelines still apply.
Seatbelt harness aging requirements
Quick Release steering wheels
Fire extinguishers
Fire Retardant driver’s suits and gloves
Neck Braces
Head and Neck Restraints
Current Solo Rules override Dwarf/Legends rules for the following items:
Helmets
Car Numbers
Exhaust system, muffler and tailpipe"
