AspireTec Engineering  468
Last Post 30 Jan 2010 03:51 PM by  atcovan
Towing with a lifted truck?
ratt_finkel
27 Jan 2010 06:16 PM
    <!-- / icon and title --> <!-- message --> I'm looking at purchasing a 02-04 ish F250 4dr turbo diesel. Most of the examples I've looked at have about 100-150k on the clock. I've also found some in my price range with 3"-12" lifts on them.
    This will be my 1st truck and primarily used as my dd. But will be towing a 5k lb trailer twice a month.
    Question is, what should I lookout for and what if any complications are there in towing with a lifted truck.
    Scoob
    29 Jan 2010 01:20 PM
    I'll refer you to the Ford Truck Enthusiasts forums, http://www.ford-trucks.com/forums/index.php. Everything you wanted to know about towing with lifts can be found on there.
    Me? I bought a RWD Excursion diesel that sits lower than my old Expedition 4WD and I expect it to tow much better.
    Chris Raglin
    29 Jan 2010 04:35 PM
    Nothing gets better for towing when you lift a truck. It's more a question of how much worse did it get. Typically, the taller the lift, the softer the springs, which is bad. Not only does lifting raise the CG a lot, and typically doesn't raise the roll centers, but it also messes with some of the braking dynamics when you add a normal height trailer. With the trailer pushing significantly below the tow vehicle's CG, you can get some wierd reactions. I'd keep looking for a stock height truck.
    -Chris
    EWCMR2
    29 Jan 2010 06:32 PM
    ratt_finkel wrote:
    <!-- / icon and title --><!-- message -->Question is, what should I lookout for and what if any complications are there in towing with a lifted truck.
    I see lifted trucks towing toyboxes all the time in SoCal, usually upside down in the median...
    Dave Hardy
    30 Jan 2010 06:00 AM
    On the one hand, lifting a truck will hurt the towing dynamics. On the other hand, you're talking about only 5K pounds with a truck that should be good for twice that or more, so you aren't really pushing it. My gut feeling is that it would be fine, but unless you want the lift, I'd prefer a stock height one.
    I've thought about going the other way. I can't help but think my truck would be way cooler dropped about 6" on some 20" rims. But that would mean spending money that would otherwise go to the racecar, so instead it rolls stock.
    atcovan
    30 Jan 2010 03:49 PM
    Ha, ha!
    atcovan
    I had an '04 Excursion towing my Z06 in a 20' enclosed. It towed wonderfully! All I added was a big Hellwig rear bar and Airlift system.
