Last Post 02 Jan 2013 08:19 AM by  85rx-7gsl-se
Opinions on the best rallycross tires?
loudes13
30 Dec 2012 09:18 PM
    I just bought a beater e36 325i for rallycross. It needs tires, so what do you recommend?
    Are performance all-seasons better than snows?
    www.allenskillicorn.com
    Bullitt2954
    31 Dec 2012 01:11 AM
    They (all seasons) will probably last longer - and be cheaper for a given size than snows - but I would not say they are "better". Do you plan to remain in Stock?
    P. Lier
    31 Dec 2012 03:46 PM
    We run Firestone WinterForce on our Neon dirt cheap and hold up reasonably well. We do trailer though so it has no road miles if you plan to drive to and from events on them.
    Peter
    loudes13
    31 Dec 2012 08:01 PM
    My old honda was consistently more competitive on mismatched all seasons than a set of fresh winterforces. I have no problem buying some Alitmax Artics, but snow and dirt have different needs...
    meckert
    01 Jan 2013 01:03 AM
    If you're consistently running hard pack surfaces like in the pic, then all-seasons may work better. If you run loose surface areas, I think a snow like the winterforce will be better.
    irish44j
    01 Jan 2013 09:00 PM
    depends on where you run and what the surface is, and what class.
    You can sometimes find used rally tires from stage rally teams for pretty cheap. Winterforce or other squared-off snow tires work well on loose and mud.
    loudes13
    01 Jan 2013 09:35 PM
    ...but aren't mud and snow conflicting environments? Snow tires are designed to pack snow into the thread, so it can grip. Mud tires are designed to fling mud out of thread.
    And don't winterforces have too floppy a sidewall? I wasn't impressed with the set I had.
    85rx-7gsl-se
    It sounds like you have already made up your mind so just get what you like :)
