Last Post 21 Nov 2013 04:33 PM by  xnamerxx
STF 2013 plans and setup and such...
Page 1 of 512345 > >>
davebs14
06 Feb 2013 01:43 AM
    Another year polishing our turds...what have we all done...what are we doing setup wise?
    Still have the 2011 mini with the following:
    - 15x7.5 konig wheels (roller or litespeeed wheels) with the 225 hankooks
    - filter on a stick with a rear muffler delete from the HS days
    - bilstein sports with swift springs, vorshlag camber plates and hotchkis race rear bar
    WISH LIST:
    - race seats
    - replacement header, cat and exhaust
    - ECU reflash
    - lightweight battery and other lighter odds and ends
    - some replacement engine mounts and such
    - more wheels
    August 2013 update:
    - Installed Recaro Pole Position on driver's side to hold us in better (http://www.proamauto.com). Thanks John for the awesome seat and bracket.
    - Rear LCA's. H-Sport brand. BIG thanks to Way @ Way Motorworks (http://www.waymotorworks.com) for the quick delivery on this. Helped stabilize the rear of the car and allowed me to not rely on the factory bolts so much.
    - Short shifter by cravenspeed for a more solid feel. Also from Way Motorworks. This has drastically reduced my 2-3 3-2 missed shifts
    - we also got a set of 6UL wheels from 949racing.com. They are nice and light and work great on the rear where I need to tuck it in as tight as possible.
    and last but not least...
    - BFG RIVAL TIRES!!! Holy smokes these things have been great. It's hard to tell when they fall off because even when they do fall off a bit they are still fast.
    Senior Member
    Senior Member
    06 Feb 2013 10:27 AM
    My header is on its way to a new home...and it is an autocrosser.
    xnamerxx
    06 Feb 2013 10:29 AM
    Yep.
    For my 08 Yaris I've got the following happening this year.
    - 15x7 Kosai wheels with 195 Toyos and 16x7 OZ Chrono with 225/45/16 Z2's
    - KNN filter
    - Custom Bilstein Struts/Shocks with Draco Springs and TRD Swaybar
    - Custom Long Tube Tri-Y header and custom 2.25 exhaust
    - 1lb lipo battery
    WISH LIST:
    - CAI
    - ECU Reflash/Piggyback
    - Lighter seats
    - More TIRES!!!!!
    Was sitting at 2160 at nationals last year hoping to break 2100s.
    bharmer
    06 Feb 2013 12:21 PM
    Here is what my setup for my 2005 Toyota Corolla S will be at the start of the season. Anything in bold is new for the year:
    Engine:
    PPE ceramic coated header
    PPE mid pipe with high flow cat (no resonator)
    Burns Stainless muffler
    Camcon CC-101 VVT-i controller
    Injen CAI wrapped in gold foil
    Energy Suspension Motor Mount inserts
    Braille 6 lb battery
    Suspension:
    Koni 8611 Double Adjustable inserts up front in custom strut housings (valved to handle high spring rates)
    Ground Control threaded sleeves
    Swift Springs 14 kg/mm (784 lb/in) springs up front
    Front sway bar removed
    Crash bolts
    Energy Suspension Polyurathane Control Arm Bushings
    Hotchkis rear sway bar
    KW coilovers shocks and threaded collars
    Swift Springs 7 kg/mm (392 lb/in) springs in the rear
    Energy Suspension Polyurathane Axle Bushings
    Wheels/Tires:
    Dry
    SSR Type C 15X7.5" Wheels
    BF Goodrich G-Force Rival Tires in 225/45/15
    Wet
    Stock Celica GTS Wheels
    Continental Extreme Contact DW in 205/50/16
    Interior:
    Corbeau Forza fixed back seat with mounting bracket
    Schroth 3 point harness
    TRD short shifter
    Last year at Nationals I was at 2346 lbs. I should be at 2300 lbs even.
    Wish List:
    Camber Plates
    Lighter passenger seat
    Greddy Emanage Ultimate
    fsp leaker
    06 Feb 2013 12:43 PM
    I have purchased better camber plates
    Still waiting to see what will be the fast tire
    Wish list: Faster Driver, ECU Reflash, Lighter seats.
    Looking forward to running with you guys again at the Nationals.
    Dan (Skid) Marx
    cwhill21
    06 Feb 2013 04:03 PM
    2006 Mazda3 hatch setup for 2013-
    Cornering stuff-
    Mazdaspeed Accessory (KW V3) double adjust dampers
    Corksport camber plates (-3 or more)
    Hotchkis rear bar
    SPC rear camber arms
    Hankook R-S3s on 18x7.5 RPF1s
    HPS pads w/ stainless lines
    Go fast(er) stuff:
    Mazdaspeed Acc. CAI (removed fog light for air directly to filter)
    Borla CBE
    Highflow cat
    Hypertech reflash
    Braille battery
    Solid motor mounts all around
    Soon to come stuff:
    Custum rear spring perches
    Hyperco springs - 500f/600r
    Mazdaspeed Acc. short shifter
    Car weighed 2780 at Dixie NT last year. I believe I'm close to 2700 with exhaust, intake, battery, fogs, and removing plastic covers. I haven't dyno'd the car yet with all the new stuff, but previous results on similarly modded 3s say 145+ to the ground.
    TPColgett
    06 Feb 2013 08:20 PM
    Have a 2008 Honda Fit Sport 5mt
    Current setup on the car is as follows:
    Engine:
    AEM CAI Intake
    DC sport 4-1 ceramic header
    Skunk2 60mm cat back exhaust
    PWDJDM Battery relocation with Odyssey PC 680 Battery
    Re Flashed via Hondata Flashpro
    Suspension:
    Swift sport mach lowering springs
    Tokico HTS adjustable dampers
    Progressive Rear Sway Bar 22mm
    Camber bolts to achieve -3.0 degree front camber and set at 0 toe
    ARP Extended lugs
    light weight open ended aluminum lugs
    Resistance:
    OEM brakes (pads,rotors, lines. )
    15x7.5 +32 Konig 3rd party rims (Look like slipstreams)
    195 50 15 Toyo R1R
    NO Clue what it weighs, but its not the lightest...
    Future plans inlude:
    4-2-1 Long tube header with high flow cat and re tune
    Full custom coil over suspension using Koni inserts and Swift springs (NEED this)
    Race Seats
    fastmike
    07 Feb 2013 08:51 AM
    Chevy Volt set up for wet conditions. Michellin PSS's.
    Senior Member
    Senior Member
    07 Feb 2013 01:14 PM
    This is shocking!!
    fastmike
    07 Feb 2013 01:34 PM
    Andy Hollis wrote:
     This is shocking!!
    Yes, you need to wear insulated boots when approaching the car when it is wet....
    xnamerxx
    07 Feb 2013 02:14 PM
    fastmike wrote:
    Andy Hollis wrote:
    This is shocking!!
    Beware of your current surroundings...
    ecugrad97
    07 Feb 2013 03:20 PM
    xnamerxx wrote:
    fastmike wrote:
    Andy Hollis wrote:
    fastmike wrote:Chevy Volt set up for wet conditions.
     This is shocking!!
    Seems weird to amped up about a Volt. Lets at least hope you listen to Tesla while staging.
    fastmike
    07 Feb 2013 04:05 PM
    Hey? How do you know that? Did you hack one of the two cameras in the car?
    xnamerxx
    07 Feb 2013 05:54 PM
    No I think he just had an Ohm-man. You should pay more attention to the circuit, it might hertz if you don't get a farad vantage.
    85rx-7gsl-se
    07 Feb 2013 06:00 PM
    Goo
    Bobzilla
    11 Feb 2013 03:50 PM
    2010 Forte SX Sedan. Still deciding on suspension for it. Wheels have are already in the garage.
    17x7.5 Kosei K1's 225/45/17 RE-11's mounted (BFG Rival's will be ordered later in the season).
    Likely Stance or Megan coilover's to start the season
    19mm rear sway bar added to the torsion beam.
    Not decided on cat-back as of yet.
    stock intake with some minor modifications.
    Hoping to make it to Wilmington, Peru and Nationals this year.
    TPColgett
    14 Feb 2013 06:53 PM
    Well, STF is sure looking up in the SFR region! We had 5 cars and 6 drivers. 2 are in our regional novice program so there is a solid chance for the group to keep growing. Cars were 2 RSX type S, one GD Fit, one GE Fit and an '03 EP Civic Si!
    xnamerxx
    14 Feb 2013 07:38 PM
    Send em south we need more STF competitors for the Tour and Pro!
    TPColgett
    14 Feb 2013 08:09 PM
    I will TOTALLY try! I have to decide which one I am coming to. Currently I was planning to head to the Tour at the end of Mar... I doubt I can afford both weekends though : /
    xnamerxx
    14 Feb 2013 09:55 PM
    If I had to choose, I'd pick the pro only because its not on Easter but both should be fun.
