Last Post 14 Mar 2013 03:25 PM by  CHRISFP78
BFG R1-S
white_turbo
20 Feb 2013 05:06 PM
    I am looking to try out the R1-S this season and it appears that the specs on various vendors are not consistent with the BFG official website. The size I am looking at is 285/30/18.
    BFG website: http://www.bfgoodrichtires.com/tire...spec_table
    Part #: 05904
    Wheel width range: 9.5"-10.5"
    TireRack (or various other vendors) website: http://www.tirerack.com/tires/tires...Force+R1-S
    Wheel width range: 10"-11"
    So a couple of observations/comments:
    1) According to BFG website, it appears that for the same size 285/30/18, the minimum wheel width is different between the R1-S and R1.
    2) Seems like all the vendors are showing the incorrect specs for the R1-S if it is indeed true that the same size has different minimum wheel width requirement
    3) Are the R1-S really wider than other brands for the same size (i.e. if I ran V710 in 285, I should run 275 for the R1-S)?
    I have emailed BFG about it, but they didn't really answer my question on why TireRack is showing different specs than their website.
    Just want to hear your opinions/experience.
    Thanks.
    conekiller2
    20 Feb 2013 05:40 PM
    We have been running the r1-s in our BSP S2000 for almost a year. They definitely run wider than hoosier and kumho. We started with 275/40/17 on 17x10 last year and compared to a 275/40/17 a6 they were considerably larger. We made the switch to 18x11 using 275/35/18 for this season. When discussed with bfg we were advised that the 285/30/18 was large and would not fit on a e46 3 series and that the evo guys were also running the 275/35/18. Due to the gearing we choose the 275/35/18. They are large and required aggresive fender work to clear the s2000 fenders. They are slightly stretched on a 11" wide wheel and would probably be square on a 10" wheel.
    Sacha
    BSP 86
    white_turbo
    20 Feb 2013 11:53 PM
    Thanks.
    Did you measure how much wider? So I am guessing a 275 R1-S is equivalent to 285 V710 on the same wheel?
    RSAutoX
    06 Mar 2013 09:41 PM
    Tire Rack no longer lists the R1-S? Anyone know what's going on?
    atcovan
    14 Mar 2013 01:58 PM
    Posted By RSAutoX on 06 Mar 2013 09:41 PM
    Checked their site today and seems fine.
    CHRISFP78
    Yes the BFG R1s run on the large side. I am trying the 285-30-18 on the rear of my car. The 285 is 11.4 inches wide across the tread surface mounted on an 11" wide wheel.
