Last Post 02 May 2013 05:05 PM by  Sho Torii
LI alignment shop recommendations?
07 Apr 2013 07:07 PM
    Hey all,
    Any recommendations for alignment shops on long island?
    - weekend appointment, before/after printouts, knows how to adjust camber bolts properly etc...
    Thanks!
    07 Apr 2013 11:15 PM
    I've been going to these guys in Lynbrook http://www.cambertoe.com/wordpress/?page_id=38. They can do all the 3 things you asked. Not sure what level of service you expect, but they definitely know their stuff.
    Their machine measures toe in degrees, FYI.
    12 Apr 2013 09:44 PM
    I have used Camber Toe as well, good shop..
    14 Apr 2013 08:29 PM
    Thanks for the info guys!
    ...also considering John Kurtzke of Goodyear Jericho if Camber Toe doesn't have an appointment open.
    15 Apr 2013 04:42 PM
    Www.tkxperformance.com
    TKX does great work, it is just tough to get an appointment since they are always busy...
    16 Apr 2013 07:25 PM
    I'll check out TKX as well, thanks for the info Adam...
    21 Apr 2013 03:20 PM
    Posted By Paul B on 14 Apr 2013 08:29 PM
    I have used John a few times and he is very good. be there early and you sit in car while he does his stuff. Make sure that you tim him well If/because he does good work. Ask him for before and after printouts and you get them.
    02 May 2013 05:02 PM
    I had gone to John for years until I moved to NJ in Dec 2010.  As a matter of fact, I was his first custom alignment customer.  I talked him into letting me sit in the car while he align and ignore the factory specs.  First he was reluctant but learned the ropes quickly.
    If you know what you want (alignment specs), go to John and pay a half of what TKX would charge and be happy.  However, if you need to consult someone on your alignment specs, $150 with TKX will be very well spent.  If you go to John, tell him Sho said hi.
    If you know what you want (alignment specs), go to John and pay a half of what TKX would charge and be happy.  However, if you need to consult someone on your alignment specs, $150 with TKX will be money very well spent.  If you go to John, tell him Sho said hi.
