Last Post 16 Apr 2013 05:49 PM by  ron
Stock Class, 18x9, 265/35/18 or 285/30/18?
OasisTan
15 Apr 2013 02:50 AM
    If you were running stock class with an 18x9 rim, would you run a 265/35/18 or a 285/30/18(basically same height at 25.0/24.9)?
    265/35/18 (4)
     50%
    285/30/18 (4)
     50%
    Stock Class on18x9 wheels, -1.0 camber up front, fairly stiff suspension, AWD, 3000lbish car, 250ish HP.  Tire choice is a BFG 265/35/18 or 285/30/18?  Both sizes are basically the same height at 25.0/24.9" tall.  BFG seems to run wide as well.
    Which would YOU go with?
    snaponbob
    15 Apr 2013 10:36 AM
    Oh ......... gee. Why do you ask?
    snaponbob
    15 Apr 2013 10:42 AM
    Posted By OasisTan on 15 Apr 2013 02:50 AM
    More seriously, assuming R-comps, WHICH one? Also, clearance is a serious issue sometimes. (Recall LAST SUNDAY !!!) BAsed on the size choices, you are looking at BFGs. (No surprise THERE.) Less "pinching" = more less sidewall deflection.
    ratt_finkel
    15 Apr 2013 01:02 PM
    I voted the 265. The 285's are massive. And even on 10.5" rims are not stretched.
    Jeremy Foley ASP#180
    gbeaird
    15 Apr 2013 01:11 PM
    I didn't vote, but I'd also start with the 265s.  Remember that you have modification limitations in Stock classes, so bigger tires usually make up for other ills in a particular car's chassis design/layout.
     When we autocrossed our 86 SVO, I was able to fit, and the car was faster on the 265s we were using, vs. the 245s we started with (stock tire was a 225).  But on that car, there was no opportunity for camber adjustment over the stock range, so even with the top of the struts pushed fully-in towards the center of the car and the bottom of the strut-to-spindle mount pushed fully in at the top, we could only get about -1/2 deg.  So, the bigger tire still put more tread on the ground in the turns, which really helped with turn-in.
     So, I'd start with the 265s and see how that fits all the way around the car, then try a set of 285s when the first wears out, if you have space.
    The Nebulizer
    15 Apr 2013 04:44 PM
    I can't understand why, aside from fitment, you would choose a 265 over a 285 on an 18x9. Plenty of wheel for this tire.
    newportroyal
    15 Apr 2013 08:20 PM
    285's.
    ratt_finkel
    16 Apr 2013 12:50 PM
    Posted By The Nebulizer on 15 Apr 2013 04:44 PM
    Numbers lie.  These are not traditional sized 265 or 285's.  Craig knows this.  But you do bring up a good point, there are numerous examples of large tires and small rims equaling a winning combo.
    The Nebulizer
    16 Apr 2013 04:45 PM
    Posted By ratt_finkel on 16 Apr 2013 12:50 PM
    I'm running 295 A6 on 18x8 which is not uncommon. I don't know anything about the BFG though. How do their sizes compare?
    snaponbob
    16 Apr 2013 05:37 PM
    Having pounded around with 295 and 315 x 18 A6s on various width rims, squeezing 295s on 18x8s "works", but 9s or 10s would REALLY wake them up.
    ron
    265 they aren't designed like the hoosier with the cantilever bead design and they run wider
