Last Post 17 Jun 2013 11:00 AM by  JTM
Tire Debead Form
Jerry Doctor
28 Apr 2013 02:06 PM
    As many of you are aware, there is now a Tire Debead Data Form that must be completed whenever an entrant suffers a debead at an SCCA RallyCross. Over the last several years there has been considerable discussion about the need for a rule on tire pressures. The RXB decided to first collect some actual data to see if such a rule is justified before passing a rule that would prevent experienced drivers from setting up their cars as they deem proper. In other words, before we "do something," let's find out if something needs to be done.
    This form has been distributed electronically to all Divisional RallyCross Stewards. It is also available online. On the SCCA home page click on the "Downloads" tab, then scroll down the page to the RallyCross section.
    My thanks to SCCA RX organizers and Safety Stewards for helping us with this project.
    Jerry Doctor
    Chairman, RX Safety Committee
    vreihen
    30 Apr 2013 07:07 PM
    Ironically, at about the same time that this was posted we had a car de-bead a tire at our event!  (New York Region/PSCC chapter)  The data was collected by the RX SS, and I assume is in flight to be one of the first forms submitted.
    Here is a direct link to the report form:
    http://scca.cdn.racersites.com/prod...lable).pdf
    JTM
    Maybe it's way too late to point this out, but your form should also ask for wheel width. Whether a given tire at a given pressure will debead depends on wheel width.
