Last Post 14 May 2013 08:54 PM by  Murtz
Which class - 92 Honda Prelude
Murtz
14 May 2013 02:43 PM
    Which class would the following car belong in:
    Engine:
    JDM H22 from HMotorsOnline.com
    Custom intake and filter
    modified factory intake manifold
    custom catch can
    Walbro 255 lph fuel pump
    No AC or power steering
    New brake master cylinder and brake booster
    new hoses all around
    new water pump
    new timing belt w/ H23 manual tensioner
    removed all unnecessary sensors
    Electrical:
    P28 ecu w/ custom tune on Chrome
    Longacre racing kill switch
    Braille 9lbs battery in custom lowered tray
    Suspension:
    Custom rebuilt Koni yellow shocks, rebuilt and shortened by Koni USA
     Koni adjustable sleeves for springs
    custom made aluminum isolators on tops of springs
    SPC camber kits on front and rear (caster & toe stock adjustable front, toe stock adjustable rear)
    McKinney Raceworks spherical radius rod bushings
    Hard Race front lca, rear lca, and rear trailing arm bushings (all spherical/pillow ball)
    Brakes:
    96 Vtec brake upgrade in front
    Carbotech XP10 front pads and XP8 rear pads
    ATE Super Blue brake fluid
    Safety:
    Custom built in roll cage to SCCA and NASA
    Ultra Shield 16" 20 deg Pro Road Race Seat w/ gray cover- Driver
    Ultra Shield 17" 20 deg Rally Sport Seat w/ gray cover- Passenger
    G-Force pull down cam lock 5 point harnesses for driver and passenger
    Custom adjustable rear seat brace for drivers seat
    Window net for driver
    Center net
    I/O Port camera mount
    NRG steering wheel and quick disconnect kit
    PS: Listed all the mods so as to be sure of which class to run it in.
    Thanks in advance!
    TPColgett
    14 May 2013 02:55 PM
    For SCCA Solo I'm thinking SMF... Check on the minimum weight, but I think you should be fine. You'll want R comp tires for that though if you aren't running them already.
    Murtz
    Posted By TPColgett on 14 May 2013 02:55 PM
    Thank you for responding - this would be for the W2W competition.
    G-Loc Button
