Last Post 25 Mar 2015 02:36 PM by  OZMDD
Help -- BFG Rivals on 7" wide wheels
VettesRule
25 May 2013 09:13 PM
    What tire pressure should I run in my STR Miata.  15x7 RFP1 wheels, 700# front and 450# rear springs, Fat Cat non adjustable shocks.  Stock weight and ride height with lots of negative camber.
    Thanks in advance!
    Danny
    VettesRule
    25 May 2013 09:15 PM
    Tried 32 all around, 30 / 28 and I don't think I am there yet.
    Do these tires need a lot of runs before they come into their own? I guess I am too used to A6s.
    VettesRule
    27 May 2013 10:53 AM
    Tried up to 35 / 33 and didn't feel a huge difference. Settled in on 30 / 28 with good use of the entire tread width.
    davebs14
    01 Jun 2013 09:01 PM
    I'd suspect mid to low 30s on a miata would work. Mine were quick from the start but got fasta t about 10-15 runs in. your results may vary
    Nathan Atkins
    30 Oct 2014 02:00 AM
    Just get a probe type pyrometer and gather data, they cost a fifth as much as a set of tires and it sure beats guessing.
    Boxologist
    04 Nov 2014 05:35 PM
    Why the 7" wheels? Using 205 width? The hot ticket is the 225 on 9" where 27-29psi should be sufficient. If you are stuck with the thinner tires, I would suspect 32-34psi is going to be the sweet spot unless it doesn't fit your driving style. More importantly, remember that Rivals want to be audible when driven to get the most out of them. Make sure they howl nearly everywhere.
    OZMDD
    Skidpad.
