Last Post 28 Jul 2013 09:48 PM by  stx wgn
Rule clarification
stx wgn
12 Jul 2013 11:11 PM
    [ Only air-to-air intercoolers may be used. They must fit completely within the bodywork. They must be cooled only by the atmosphere. The use of coolants such as water, dry ice, ice, etc. is prohibited.]
    What about intercooler sprayers? Can they be added?
    I know a few cars came stock with them. . Just not mine
    Robert Puertas
    13 Jul 2013 12:27 AM
    You mean that poorly aimed windshield washer? ;-)
    stx wgn
    13 Jul 2013 11:54 AM
    It be more like poorly aimed rear window sprayers
    SmokingTires
    24 Jul 2013 01:00 AM
    It doesn't specifically say you can, so you cannot add one. Cars that came with them can use them because they are factory.
    For the most part in autocross competition, you're not likely to be running a car hard enough or long enough to heat soak most FMIC.
    rosejm
    26 Jul 2013 12:04 PM
    You'd have as much benefit, I believe, keeping that extra weight out of the car and spraying with ice/water/alcohol in the grid for those few times when it's needed.
    stx wgn
    It's not a front mount,
    It's an mr2 so it's a side mount in the engine compartment
    And the other part to it is I was feeling like being lazy and
    Creative at the same time. Then lazier set in so I never did it
