Last Post 23 Jul 2013 10:13 PM by  lycanthrope
1995 Dodge Neon Sport Coupe $1400 OBO
turboshadow
22 Jul 2013 06:16 PM
    Car was my dd/autox car for the past few years.  The main issues are the paint and few cosmetic body issues.  It runs great and I use drive it every day with no issues. Odometer shows 210k but its higher due to speedometer not working all the time, engine is fresh from head gasket and timing belt in spring 2012  along with a lower mileage head 70k. Water pump was done in spring 2013.  It has a top end tick on accel it's been doing it a few years it hasn't gotten any worse.  The tires are decent but mismatched 195/70/14 on front and 185/60/14 on rear.  Transmission works well but can be tricky getting into reverse sometimes.  Car has performance driven X-Highs and kybs on rear and konis on front; it also has bigger rear sway bar, and 4 wheel disc with ABS.  It needs the driver side front strut mount replaced a new mount comes with the car.
    It make a great Autox beater with some wheels and tires or maybe a rally cross project?
    Work
    Water Pump –Spring 2013
    Struts, Mounts, Springs- Spring 2011
    Control arms with bushings-Spring 2011
    New Headlights with turns.
    Engine Mounts
    2nd Gen Seats
    Head with 70k -Spring 2012
    Head Gasket-Spring 2012
    Timing Belt-Spring 2012
    Front Brake Rotors-Spring 2010
    Brake Lines-Spring 2010
    Alternator-Spring 2012
    Radiator/Thermostat-Spring 2012
    Battery- Fall 2011
    Cam Sensor-Spring 2012
    Oxygen Sensor-Spring 2012
    Stop Tech front pads- Summer 2012
    Performance Parts
    Exhaust Manifold Ebay Shorty
    Iceman Intake
    Auto TB
    Semi sold bobble strut
    Black Konis Front
    KYB Rear
    Performance Driven X-Highs
    Mopar PCM
    Muffler Summit Street/Strip
    Booger Bushings
    Rear Sway Bar Suspension Techniques
    Front and Rear strut tower bars.
    Extras
    MSD Ignition
    Head-Original
    Tie Rod Ends
    ST Front Sway Bar with Bushings-New
    Stock PCM
    Rear EBC Yellowstuff Pads
    Stock Rear Swaybar
    The Bad
    SOHC top end tick
    Bad paint
    Wrinkle behind passenger door
    Rear ended with damage to bumper cover and crash bar, the muffler hits it a litter over large bumps.
    Trailer hitch mark on front bumper.
    Dent in front driver side fender.
    Speedo works about 50% of the time
    Driver side window needs a little hand adjustment to go up all the way.
    Headliner is gone.
    Cruise and A/C is gone.
    lycanthrope
    great car and a great deal. someone should pick this up quick. i hope it stays in the region as it has sort of become one of those cars i half expect to see at every event.
    G-Loc Button
