Last Post 25 Nov 2013 11:08 AM by  47CP
Dunlop ZII pressures
Cito
27 Aug 2013 12:40 PM
    I am running 275/35/19 ZII's on a 3500 pound Mustang.  It is in RTR, but I thought I would post here given the street tire knowledge in this section of the forums.  Anyway, I am wondering what sort of pressures people are running in the ZII's if anybody else is running them.  I went with 40f and 38r with what seemed liked mixed results.  Any thoughts would be appreciated.
    Brent
    engineered
    27 Aug 2013 01:10 PM
    On my 3200lb E46 325ci, with -2.5 camber in front, and on Dunlop Z1's, I run 39/35 psi front/rear.
    Milan
    27 Aug 2013 01:28 PM
    i run 28f &27r on a 2300 lbs. RTR car with 205/50/15
    and, about the same for a e36 m3, 3200 lbs, with 255/35/18
    27 Aug 2013 05:51 PM
    We run 42f 36r on our 2012 Mustang RTR car with ZII's
    Kirk
    28 Aug 2013 09:46 AM
    I run 44f and 36r on my 3300lb e46 330i in RTR (0.7 deg neg camber front, 1.5 deg neg camber rear).
    Carl Kirkegaard
    Cito
    28 Aug 2013 09:52 AM
    Wow, great information. Thanks so much to everyone.
    Brent
    Dallas J
    09 Oct 2013 03:56 PM
    I use to run in the low 30s cause the tire temps (probed after skidpad) was showing real funky temps on the inside and lower brought mid and outer temps closer. Tried 40 and it was no longer funky and temp distribution was much more linear. Now Im settled at 40ft/38rr, 3050lb Evo on 255 ZIIs w/ 10" rim.
    Impala SS AutoXer
    09 Oct 2013 07:17 PM
    38F and 31-33R on a 3260lb car (V6 Genesis Coupe R-Spec), 19x8F/8.5R, 245/40R19 all around, -2.1deg Front.
    We've tried higher rear pressures, but for us it was making the car less stable trying to get power down early on corner exit.
    Han Solo
    25 Nov 2013 10:53 AM
    Posted By 47CP on 27 Aug 2013 05:51 PM
    Dave,
    Do you adjust to these pressures after each run?
    Are you running the 275/35/19?
    Posted By Han Solo on 25 Nov 2013 10:53 AM
    Dave,
    Yes, we go back to that pressure after each run and yes, 275/35/19.     We have tried other pressures to adjust balance and it hasn't seemed to make any difference.
    G-Loc Button
