Last Post 30 Sep 2013 02:24 PM by  Renegade
Legal to remove radio bezel
Renegade
27 Sep 2013 07:12 PM
    Looking to remove part #5 in the drawing
    http://www.hondapartscheap.com/part...er/console
    I want put an aluminum sheet metal plate for switches and such. The original part is made of plastic and should weigh less than 1lb, I'll weigh one later on. Etiher way the sheet metal may way as much or close to the original part once it is populated.
    thanks
    Renegade
    27 Sep 2013 07:14 PM
    Here is a picture of what I'd like to remove
    http://www.ef-honda.com/main/viewto...hp?t=39929
    drdisque
    29 Sep 2013 09:09 PM
    I'm sure nobody would object, especially if you replaced it with a piece of similar heft.
    Renegade
    Thanks. I am trying to avoid having to carry the part around so it can be weighed to prove the new plate weighs the same or more as what was removed.
    I can use the radio block off pate in the meantime, just wanted to have more area to mount without rear obstructions for the wiring.
